| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #1531 (permalink) |
| BHPian Join Date: Jul 2006 Location: Sydney / Secunderabad
| Even I am facing the same issue as vvrchandra,I ain't using BigTv but TataSky,the problem is with the channel logos,a way I sort this issue is I play a channel for 15-20 minutes using the zoom option and make sure there aren't any still images . |
| | #1532 (permalink) |
| BHPian Join Date: Jun 2007 Location: Bangalore
| guys to clarify - this is not a problem, it will stay for sometime (2 mins or so) and then go away. However in the first 100 hrs if you keep a constant image at a stretch for 8-9 hrs and keep doing it regularly, you may end up with an image for the life of the tv. After the first 100 hrs, the phosphors are set and you don't need to worry that much. I already use my plasma as a computer screen and for tons of gaming and have no problems, apart from the rare 2-3 min image retention. Also - in the first 100hrs as a precaution, I followed DVR's method as mentioned above when watching some movies or channels with very bright and constant text or logos. I used to change the aspect ratio so that the logo or text went out of display area. Last edited by jassi : 6th October 2008 at 02:01. |
| | #1533 (permalink) |
| BHPian Join Date: Dec 2005 Location: Hyderabad
| Well, i started having this issue only when I started using BIG TV and that too I noticed it yesteday only. When I used hathway set top box earlier on my 42PV80, i did not have any issues. Even, I kept the picture mode in cinema mode for more than 100 hours (bought my tv on 8-Aug-08) and big tv was installed only on 22-Sep-08. Since the tv is on for 8 to 10 hours(avg) to 12 hours(occasionally), and the BIG TV logo is present on all the channels at the same location, what do you suggest me or in what way can I avoid this to the max possible extent? Zooming the channels so that the BIG TV logo is not present on the screen is some what helpful, but the image appears out of proportion sometimes. Any other better way to avoid this..please.. Last edited by vvrchandra : 6th October 2008 at 09:56. |
| | #1535 (permalink) |
| BHPian Join Date: Apr 2005 Location: Bangalore
| I am planning buy lcd/plasma. Last week visited Panasonic dealer and eZone in Koramangala. Looked at 42PV80H, asked the person at shop to switch to sports channel and watched F1 live (Singapore GP, the first under the lights) for few mins. I could see the small square patches on screen. When I questioned, the guy told me that single TATA Sky connection is provided for all the TVs, and that is causing this. Is that true for Plasma's? There was 42PV700 (Full HD) TV next to it, which looked lot better than PV80. Then went to eZone, and asked them to switch to F1 and observered that Sony-40v400 and Samsung 40A650 almost similar and didnt like what I saw. I could see more number of square patches on this. Now I am really confused which one to buy. As Pan 42PV80H is not full HD, and if in next one year if we get HD feed from satellite broadcasters, am I going to loose something? Or, go for Full HD LCDs? |
| | #1538 (permalink) | |
| BHPian | Quote:
Go Full HD only if you're planning to buy anything over 42'' and your viewing distance is atleast 10 feet. Anything below that there is no noticeable difference in HD Ready and Full HD. I'd recommend the Sony Bravia Range of LCD's as the first choice over Samsung. I've heard Samsung makes those panels for Sony, but the picture quality of the new Samsung line is grainy and the blacks are not the best.
__________________ _________________________ 2008 Honda Civic 1.8S 2005 Hyundai Santro Xing XG 2000 Honda City Type2 1.3EXi | |
| | #1541 (permalink) |
| Newbie Join Date: Sep 2008 Location: Mumbai
| I recently purchased Samsung 46'-5 series model and i must tel you that it has fantastic picture quality...People say Sony is better only because of the Brand name but all you are doing by purchasing sony is purchasing the brand name...same lcd of sony would cost around a lakh or so but i got my samsung for 85,000 contrast ratio of 30,000:1. if u go in for samsung 6-series you will get contrast ratio of 50,000:1 but u pay 20,000-30,000 more for that. When you see the LCD's in the showroom you will be able to see the difference between 5 and 6 series when they are put side-by-side. But at home no one will be able to tell if u got 6 or 5 series. As far as i know sony doesnt give contrast ratio of 50,000:1. buy Sony if you are brand concious or else go in for Samsung which gives Value for money |
| | #1542 (permalink) | |
| BHPian Join Date: Nov 2007 Location: Noida/Delhi
| Quote:
New plasma's or LCD's are hi-definition TVs (whether Full HD 1080p or just HD 720p). The DTH signal in India is below even standard definition. I define standard definition as DVD quality (480p). All those TVs you saw are fine. Give them a good signal and they will give you a good picture. Go back to the shops you went to and ask them to play a DVD on those TVs and see the difference for yourself. I have a Sony Bravia LCD and Tata Sky. The pixellation issue bothered me at first as well. But you don't see it much at normal viewing distance i.e. a few feet away. And you'll see less of it when you reduce the contrast, brightness and other settings to suit the lighting in your home. Don't worry about it and buy the TV you want. It'll be a while before good HD programming is available in India. I suggest save the extra money you'll spend on a Full HD set and go with the cheaper HD ready option because you really can't exploit a full HD tv's abilities here. Last edited by StarScream : 7th October 2008 at 18:17. | |
| | #1543 (permalink) | |
| Quote:
I'm one of those `brand conscious' people who bought a Sony Bravia last year. The toss up was between a Samsung Bordeaux and the Sony. The reason I went for the latter was because of its significantly better sound quality. The Samsung was quite anemic and tinny sounding. Perhaps they've improved! | |
| | #1544 (permalink) |
| @selective - I am not sure what you saw at the panny stores, however as per my experience, having used a sony bravia and panny 42pv80h, the plasmas are much better at handling regular cable/dth signals. The only thing that comes close to plasmas are the Sony bravia SXRDs. However at the shops they split signals between 10 tvs using really long cables and hence the quality is bad irrespective of plasma or lcd. I am currently on travel, but I am sure in the meanwhile you can find one of the many recent pv80 buyers to help you with a visit ![]() As starscream said, full hd doesn't really matter at 42". @etch - Also for lcds the contrast ratios are nothing but dynamic contrast ratio. You need to check the panels contrast ratio and I can guarantee you it will be no where close to the plasmas. LCDs have still not reached the black levels on plasmas. However if i ever get back to LCDs, i am sure it is going to be sony and not samsung. the panel is the same, but the bravia engine on the sony is much better in color reproduction!! Last edited by jassi : 7th October 2008 at 18:29. |
« Pics Of My Over The Top Gaming Rig and My Torrent / Browsing Rig
Will a GPS PND bought from abroad work in India? »
| Thread Tools | |
Similar Threads | ||||
| Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS | jassi | Shifting gears | 57 | 13th October 2009 20:06 |
| LCD Display for Santro | shashankre | Ask the Gurus | 15 | 26th June 2007 11:40 |
| LED alloy wheels that can display virtually any image while you drive! | Neo. | Tyre & Alloy wheel Section | 26 | 17th August 2006 16:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
