Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 7th November 2008, 09:00   #1861 (permalink)
sj_koova's Avatar
Originally Posted by kaushik_s View Post
Are these lines that you people are mentioning are white colored line running through whole screen and actually not very much noticeable? If so then probably it's the feature to help the plasma panel not to have burned pixels(or burn in). Just check the manual if it says anything about it.
About the buzzing sound, my hunch is that most probably the grounding of your system is not proper(either the STB or the Panel). I'm using Hathway STB connected to a HT and not having any such issue.
I do not think it is a Plasma feature. It is only with Hathway. Every other PV80 owner with a DTH says their picture quality is perfect.
DVD/S-Video/PC works just perfect.
Yesterday I connected my Laptop to PV80 and set the resolution to 1280x800 (I have a widescreen laptop) and the image quality is crisp and clean. I had to do some advanced color settings in the plasma (including white balance). Available under PC setup.
I watched my Sony camcorder content yesterday on my plasma and now I am happy with the purchase of PV80.
My Sony SR300 camcorder's video is shown with full grace on the Plasma. Earlier I used to watch camcorder on my laptop and was disappointed with the picture quality of SR300. Now I realize, both my TV and camcorder are just perfect. With the advanced color settings in PC setup, I could get the real colors. Especially the deep blue sky after a heavy snow fall.
As I explore more and more, PV80 has started revealing it full capabilities.
Only small disappointment for me is the Hathway on PV80.
__________________
Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac.
SJ
sj_koova is online now   Reply With Quote
Old 7th November 2008, 10:13   #1862 (permalink)
Smile
lets take this a step further - how old is your hathway box - maybe it is too old and incapable - I am using a 10 month old hathway box (model is humax nd-1200c) and I have no issues on pv80. Also even if you do have the same hathway humax nd-1200c, the firmware on it maybe older. I have a 2nd 5 month old hathway box (same model) but the firmware is new and look/feel of GUI on that is totally different.
I asked the hathway guy to firmware upgrade my older hathway to new firmware and they said no such option.
So you see there are multiple factors here - your hathway box model, firmware, rca cable. If you can't find the culprit call the hathway guy and threaten him a bit
jassi is offline   Reply With Quote
Old 7th November 2008, 10:25   #1863 (permalink)
sj_koova's Avatar
Mine is more than 2 years old. Do not have the model number handy.
Also another observation is the poor signal quality via direct antenna port even on my Sony CRT. But this CRT does a good job with the composite output from hathway.
So it is either the STB or the distribution system which is bad in my case.
My only way out is a DTH I guess. Which one and when is the question I have. Should I wait for an HDMI ready STB?
__________________
SJ
Old 7th November 2008, 10:51   #1864 (permalink)
Smile
i would suggest if you can then do wait - dishtv was going to launch a dvr capable dth with hdmi out, however it got delayed. But now that tatasky plus has arrived (non-hdmi dvr dth), dishtv will be launching its hdmi dvr dth soon. Also the other guys like airtel, etc will soon follow suit and hathway hdmi stb may not be far behind. So its only a matter of time
One more pointer if you have an HT with av switching and hdmi or component out - try connecting your stb to that and from HT connect to PV80's hdmi - might help
Old 7th November 2008, 11:58   #1865 (permalink)
sj_koova's Avatar
HDMI port on STB would require Analog-Digital conversion right?
I guess this is the reason our providers are refraining from providing HDMI on STB.
This is not going to be so cheap also. Lets wait and watch.
I am happy with PC and DVD connectivity on my PV80. PC was much better than I expected with the advanced color and gamma settings.
__________________
SJ
Old 7th November 2008, 12:29   #1866 (permalink)
kb100's Avatar
The latest AV receivers have video processing built in. The reviews say that the video processing technologies like the "Faroudja DCDi Video Processing" etc are very effective upscaling regular SD video to full HD 1080p
I am looking at this option
Here is a brilliant explanation.. the white paper itself!
Genesis Microchip Inc.
__________________
A closed mouth gathers no Feet.
kb100 is offline   Reply With Quote
Old 7th November 2008, 16:21   #1867 (permalink)
kb100's Avatar
The Panny Distributor just called -- My PV80 is on its way!!!!
An hour at most!cheers:
__________________
Old 7th November 2008, 16:25   #1868 (permalink)
Smile
An hour at most!
welcome to the club cheers:
Old 7th November 2008, 16:33   #1869 (permalink)
kb100's Avatar
Danke Jassi!!
I am thinking of not using the wall mount because both my walls are perpendicular to a huge west facing French window. It get really bright and the reflections can be maddening!
Anyone using the pedestal stand here - the one it comes with? Is it nice and stable??
__________________
Old 7th November 2008, 16:36   #1870 (permalink)
sj_koova's Avatar
Hey congrats on your new buy.
__________________
SJ
Old 7th November 2008, 16:50   #1871 (permalink)
Smile
Danke Jassi!!
i don't trust wall mounts - i use the pedestal stand and its nice - can be rotated if needed - besides its the same glossy black color as pv80 and goes very well with the over all setup
Old 7th November 2008, 17:00   #1872 (permalink)
kb100's Avatar
Moreover its a rented house - I assume the bolts are rather thick so the landlord isn't likely to be too happy when we vacate ( tentatively in another 6 months)
I have another issue - I have a 'tree stump' TV stand - which is quite high off the floor. This is what my 20 odd kgs CRT is perched on . While this will get the plasma at the perfect viewing height, I am worried about overall stability. I was wondering if it'd be worthwhile investing in a TV Stand/Trolley of some sort.
__________________
Old 7th November 2008, 17:33   #1873 (permalink)
Smile
i am in a rented house too also my pv80 with pedestal stand as well as previous sony 42" 3lcd and 29" samsung crt have all been sitting on a nice glossy black trolley (with wheel locks) made out of wrought iron - don't risk it get a trolley!!
Old 7th November 2008, 18:17   #1874 (permalink)
kb100's Avatar
The Plasma has come - but my Tata Sky set top box still hasnt ! - and if the call centre is to be believed then it'll be next saturday by the time it gets activated!!
__________________
Old 7th November 2008, 18:45   #1875 (permalink)
Mission_Safari's Avatar
This is strange. The activation for me was done by the installer in few minutes after the installation. Also I bought the STB from a nearby shop in the evening and the installation was done the next day around 10AM.
__________________
Mission Safari -> Mission aborted
Mission Scorpio -> Mission ON
Mission_Safari is offline   Reply With Quote
Thread Tools
Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS jassi Shifting gears 57 13th October 2009 20:06
LCD Display for Santro shashankre Ask the Gurus 15 26th June 2007 11:40
LED alloy wheels that can display virtually any image while you drive! Neo. Tyre & Alloy wheel Section 26 17th August 2006 16:12
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
