| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #406 (permalink) | |
| BHPian | Quote:
That is the time when companies will try selling up their piled stocks. | |
| | #407 (permalink) |
| BHPian Join Date: Jun 2007 Location: Pune
| Since last year I am waiting for SED TV from Toshiba, these guys are now stuck up in legal battle over IP infringment. This was expected in NOV2006. Will wait for more 1-2years for the same before evaluating Sony OLED (if they fix life of blue OLED) and plasma (life and burn-in issue), LCD (response time and angle of view) at that time. |
| | #408 (permalink) |
| BHPian Join Date: Feb 2005 Location: Bangalore
| Very True... I have been waiting for last couple of years to get a good Flat TV under a lac. But even today what you get is mostly crap. LCDs have blurring and over saturation images (unreal color), the extra brightness they offer tends to create eye strain in home environment. Plasmas still are not Full HD (1080p), are heavy and fragile, emit radiation (mfgs claim it is safe, but it still does emits radiation), limited Computer connectivity, have burn it issues, consume lots of power. Every year around this time I start looking at these TVs but still not convinced about replacing the tube with these so called upmarket gadgets :( |
| | #409 (permalink) | ||
| Quote:
There is a big difference in computer screen and TV screen and the two cannot be compared in this context. I some how now tend to agree with these posts below... Quote:
However I am yet to detail out a plasma to suggest if it is better or worse than LCD... | ||
| | #410 (permalink) | ||
| Distinguished - BHPian ![]() | Quote:
As for the blurring, Sony has this mode called DRC. This basically finetunes the image and reduces blurring. From what i've experienced, the preset video modes (soft, standard, vivid etc) are a waste. They just make the image look unrealistic and painful to the eyes. Just do a bit of manual tuning and you'l end up with a much better visual output. Shan2nu | ||
| | #412 (permalink) | ||
| Quote:
I could not find this setting in the brief stint I had with the TV. Quote:
![]() Last edited by ST7677 : 15th October 2007 at 17:20. | ||
| | #414 (permalink) |
| BHPian | Hi guys, I have a question... I'm contemplating the purchase of a 46" Samsung LCD TV - the LA46M81B, Mosel Blaque (I think). My primary use for the TV would be gaming. In games like Halo 2, & Halo 3, if I use the plasma sword (to the uninitiated, it's a weapon in the game), I notice that my current TV (an ancient, 8-year old, 29" Toshiba) has "artifacts", or skewing of color, along the sides for a while. They usually last for a couple of minutes, but have persisted for a couple of hours a few times. Would I be facing something similar with the LCD TVs also ? Has anybody faced the same ? I understand that current generation LCDs do not suffer from "burning in", is this the same with the TVs available here ? |
| | #417 (permalink) |
| In CRT, it has electron gun which uses potential difference of 17KV for beaming and accelerating electrons. Electron has to travel for ~0.5 meters distance before reaching destination. Also in electron beam, electron density is more than required, means extra electrons need to be masked before reaching phosphor screen (to which we look from other side of glass). That's why along with electron this high voltage device creates other radiations like X-ray and electromagnetic fields. But now CRT manufaturers place Boron coating on glass to reduce X-ray radiations and we have to live with electromagnetic radiations. which is at backside of CRT mostly due to PD and deflection yokes. In plasma for the electron creation, energy is very little as required and PD is very less. Also electron density is very less ( read just required). So no extra harmful radiations. Distance required to travel is just inside individual color pellet. So no comparison for CRT and plasma. As both are different. Plasma is fixed pixel display while CRT is moving pixel (raster) display device. I hope thats not that boring. ![]() |
| | #418 (permalink) |
| Sounds much better ![]() But, I have been reading that whereas radiation comes out upto a feet from CRT, from Plasma it reaches out only about an inch. That said, radiation IS THERE and the large surface area of plasma tv would only increase the exposure, to add to that there are electromagnetic radiations... Can you throw some more light on above. |
| | #419 (permalink) | |
| Quote:
In plasma it uses efficient way of producing electron in low energy and small space. So there is low radiation. But still it is there as it involves change of energy level of striking electrons. 1. First excite the electron to become free - provide energy in form of heat (CRT only) and voltage difference (this is less in plasma). 2. Direct the same towards phosphor material surface. IN CRT it is Phosphor between negative charged porous screen (Cathode) and in plasma it is transprant conducting surface with low -ve volts. 3. Electron strikes on phosphor to release its energy to phosphor to give out light (red/green/blue). Same time by-products too (X-ray, electromagnetic fields). Only difference is electron path is small and more controlled in each cell of plasma. CRT it is very much crude way of achieving same result. (means driving at 40kmph using 1st gear (CRT) and 4th gear (Plasma)). Result is same but wastage is more in by-product. Also in CRT to focus electron beam at different location on phosphor screen deflection yokes are used which are high energy magnetic field coils. It control horizontal and vertical position of illuminated spot. and moving all over the screen in top-botton and left-right direction constantly. This defletion machanism of magnetic coils is not required for plasma. Only required pixels are switches on/off and using controlled electron production light brightness is also controlled. 1. Now intensity these radiation from source is inversely proporsonal to square of distace. Means roughly- as distance increases by one unit, radation strengh decreases to 1/sq(distance) times appox. (I am avoiding all theory words). Now you know why CRT is radiating upto few feets. 2. Also while spreading if radiation of same wavelength come across in phase then then intensity increases but still it will die after some distance. Same time they cancel out each other if they are out of phase.(Similar to Bose's noise reducing headphones) So area of plasma has this effect but increment is not more than 1.25 times of original spreading of radiation in plasma. Last edited by omishra : 15th October 2007 at 20:10. | |
| | #420 (permalink) |
| Ah thanks, that was very helpful. So you mean that there is practically no harmful radiation from a Plasma Display panel and I can safely consider it with toddlers at home... (of course other issues leading to eye strain would be still there). |
| Thread Tools | |
Similar Threads | ||||
| Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS | jassi | Shifting gears | 57 | 13th October 2009 20:06 |
| LCD Display for Santro | shashankre | Ask the Gurus | 15 | 26th June 2007 11:40 |
| LED alloy wheels that can display virtually any image while you drive! | Neo. | Tyre & Alloy wheel Section | 26 | 17th August 2006 16:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
when you press the menu button scroll to the bottom most category. either there will be a power saver mode or an auto adjust.
