Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 24th December 2006, 09:57   #31 (permalink)
vid6639's Avatar
Yes the sony S series available in india is the 2005 model. The current model in India is KLV-S32A10 there are 2 more models after this and the latest one for 2007 is KLV-32S200A.
Same goes for the V series. In india we have the KLV-V32A10. whereas the latest revision of this is the KLV-32V200A.
There is a huge improvement in the newer Bravias. the ones in India are like the first gen Bravias.
Samsung products are more up to date.
You are also correct about the M6. It does have a better picture quality. The only drwaback is the brightness and contrast levels when you see a dark scene are not as good as the bordeaux.
The M6 has the my colour option which allows it to give a better colour rendering looking more real.
Also the M6 is the 2005 model and will stop soon. maybe thats why the link is not working.
__________________
Let's get "instigated".....
\ / ][ |) `/ [_] "!"
vid6639 is offline   Reply With Quote
Old 24th December 2006, 10:14   #32 (permalink)
gkrishn's Avatar
hmmm... then sony is clearly out of consideration now.
Ok, then I will wait till neo mosel's 32 inch debut, look at the price dynamics at that time and will decide for which one to buy.
__________________
In the Indian system of education, it is only a technique of cramming, retrieving and reproducing.
gkrishn is offline   Reply With Quote
Old 24th December 2006, 10:28   #33 (permalink)
vid6639's Avatar
I too was thinking of the same thing to go in for the Neo-Mosel F series. I saw both of them here and on normal set top broadcast as well as DVD the difference is not so great.
The image appears more finel thats all but not so perceptible. The picture quality will only be visibly better when you play HD-DVD or bluray which makes full use of high definition true 1080.
For normal viewing the Mosel N series should suffice.
I am now contemplating that. but there will always be that must have latest and best mindset.
__________________
Old 27th December 2006, 13:18   #34 (permalink)
cooldude1988765's Avatar
OFF topic but i dint want to start a new thread :
Anyone using sony Grand Wega ( projection lcd ) They have a fifty inch for a lakh or lesser. Need advice as i am planning to buy it soon
__________________
I never thought it was humanly possible, but this both sucks and blows.
- Bart Simpson
cooldude1988765 is offline   Reply With Quote
Old 27th December 2006, 14:38   #35 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
buy a 42inch plasma instead. theyre less than a lac.
akshay1234 is offline   Reply With Quote
Old 27th December 2006, 22:00   #36 (permalink)
Wat is the main difference between an lcd, plasma and a projection lcd
Which one is the best overall ???
__________________
- Bart Simpson
Old 27th December 2006, 22:05   #37 (permalink)
vid6639's Avatar
Thats going to be very long to explain to you. Projection lcd is the poorest in quality whereas plasma and LCD are very close in delivering good quality.
LCD is the priciest then plasma. Projection LCD is the cheapest.
Suggest you go for Plasma if your budget is tight.
Ill post some links later on to tell you the difference.
__________________
Old 27th December 2006, 22:12   #38 (permalink)
akshay1234's Avatar
i dont think you should go for a projection no matter what. they are very bad. u cannot view them from close by. their picture is not clear.
out of lcds and plasmas lcds are newer and better. they are lighter, consume less electricity, give a brighter picture. they also have a longer life.
the only downside to lcds is the price. they are pricey but worth it. the other thing is the response time which is 8miliseconds. the plasmas response time is 0ms so there is no lag.
if you watch alot of sports buy a plasma because of the response time. but even the lcds response time will become better.
Old 29th December 2006, 12:42   #39 (permalink)
So now it boils down to which 42 inch plasma lg, sony or samsung ????
__________________
- Bart Simpson
Old 29th December 2006, 13:03   #40 (permalink)
The integra series from videocon are retailing for less ( 26 inch 30 K) and 32inch for 40+K. At the present moment they are selling cheaper than the other brands. Sansui is also compettitive.Any drawbacks with the Videocon integra series..
__________________
If it Aint Broke, Break it and Fix it.
muni is offline   Reply With Quote
Old 29th December 2006, 14:04   #41 (permalink)
Default Suggestions
1. Figure out the source of content that you end up watching most
- If the source quality is bad, then some good TV's could end up looking worse than ordinary TV's - noise filtering, signal conditioning, colour gamut etc.
- Most TV manufacturers expect a certain minimum quality and do not design it for bad signals..
2. Once you figure out the source (say DTH, or cable STB, or DVD's or VCD's), use that to compare sets
- Most people watch the demos with great DVD players and pre-selected demo DVD's and get dissapointed with the quality of cable programming for eg.
3. Trust your eyes!
- When you buy audio equipment or video equipment, dont buy based on specs (except for i/p's, o/p's, standards etc.), but trust your eyes and ears - they are eventually what you are going to use for your pleasure.
- I had a friend who built some speakers for me using Indian components from SJP road and a majority of visitors say it sounds better than high end expensive speakers.. Specs is not everything..
- I tried to find the difference between a bravia and a bourdeux as the specs of the samsung should have blown away the bravia, but it was not the case..
4. It is subjective
- Dont go by what "experts" or the salesman or friends say.. See and hear it for yourself and make the decision.
- The hollywood "golden eyes" was a method to determine the quality of film - a bunch of people brought into a room and a statistical method across them determined the quality
5. Narrow it down based on some base criteria
- Decide on some specs that you need - eg. will you connect a PC, the number of connectors you need based on the sources and outputs, Do you have HDMI sources - how many do you need? Is DLNA important to you, What resolution do you anticipate you need from 480p to 1080p and all the variants in between (obviously 1080p is going to be the most expensive and not easily available in India) etc...
- Look at the other aspects - after sales service etc.
- Once you have some of these as must haves, desirable and dont care.. then shortlist the brands/models and then do the visual/aural test..
6. Match the outcome of the shortlist by rating all this with your wallet and then decide. If not able to decide, wait for some time and repeat exercise till successful ;-)..
rangaraj is offline   Reply With Quote
Old 29th December 2006, 14:19   #42 (permalink)
You may want to consider the Philips pixelplus range..
I was in the process of purchasing a large screen tv about 2.5 years ago. After much research, found a Philips PixelPlus 36" wide-screen CRT tv in the market that seemed to fit my bill (I was a little paranoid with all the tube life statistics about LCD and plasma tvs at that point ) and thought a CRT TV might be a safer bet.
Cons of my purchase: the TV is very bulky - it is about 86 Kilos in weight!
But, I really do like the clarity it offers..
I can't comment on the service as fortunately, we did not require any servicing so far. But, I would recommend getting a householder's insurance policy on the TV.. (it will add to your perception of being covered!)
kgc_cool is offline   Reply With Quote
Old 30th December 2006, 03:12   #43 (permalink)
Cant beat a good old CRT.
How much did this one set you back ?
Also are there any other 36" monsters from other manufacturers ?
bigman is offline   Reply With Quote
Old 2nd January 2007, 11:08   #44 (permalink)
It was 94K (and surprisingly, the only discount I could wring out of the dealer was a stabilizer and a dinner set.. :( Apparently, the model was just introduced back then and nobody was willing to give a better deal.. )..
Another minor nit: All these new age TVs apparently lack even the most basic of indigenisation features - all TVs manufactured in India include a antenna/cable signal spike protector. (Prevents your TV from toasting incase there is lightning and your TV is supplied with a very high voltage supply via the antenna jack).
I went to SV Road in Bangalore to purchase an external protector (it plugs inline into your cable input for 50 rupees).
Old 2nd January 2007, 12:10   #45 (permalink)
Rodeo's Avatar
Even i am planning to buy 32 LCD but confused with what to go with. I am generally not happy with Samsung and LG as i have used quite a few of their products and they are no great. That only shows about the companies quality levels. Its like if you get a Honda or a Toyota, you can be assured of a trouble free product...
LG and Samsung must be having a huge market share in India but i dont think they have any thing for quality conscious customers...
Rodeo is offline   Reply With Quote
Thread Tools
Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS jassi Shifting gears 57 13th October 2009 20:06
LCD Display for Santro shashankre Ask the Gurus 15 26th June 2007 11:40
LED alloy wheels that can display virtually any image while you drive! Neo. Tyre & Alloy wheel Section 26 17th August 2006 16:12
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
