Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more
Thread Tools
Old 3rd January 2007, 12:40   #61 (permalink)
Samurai's Avatar
Originally Posted by esteem_lover View Post
Guys, let me tell you something from experience. be it DTH, STB, Cable or Pure Terrestrial, the LCD & Plasms TVs just cant show them as good as the good old CRTs do. Playing DVDs or HDTV inputs is a totally different ball game on these TVs, but if you are going to be a TV viewer, even the DTH solution sometimes is a little hazy. i do speak from my experience. i have been having DTH for one year now & i recently upgraded my tv to a 100 HZ tv which is very similar to the LCDs, but i find that the channels which come in 100% strength are terrific to watch, but not the ones that are even 75%. cheers...more a little later as i am held up right now.
Let me quote my experience...
I was on 100Hz TV (29 inch Sony DRC Wega) for 2.5 years and recently switched to 50 inch Plasma. Since the local cable quality is really bad, I switched to Tata Sky before buying the plasma. Turned out to be a good decision.
Even in Tata Sky, the quality of the channels differ. The Zee channel (except Zee Studio) are usually bad, low bandwidth I suppose. But the Star channels and international channels (HBO, PIX, etc) are really good.
__________________
Samurai
The only Super Car in my book -Bowler Wild Cat
Old 3rd January 2007, 12:44   #62 (permalink)
gkrishn's Avatar
I what ways do you think they are similar???
__________________
In the Indian system of education, it is only a technique of cramming, retrieving and reproducing.
gkrishn is offline   Reply With Quote
Old 3rd January 2007, 12:47   #63 (permalink)
Samurai's Avatar
Actually, that's right. 100Hz TV is nothing but a high end CRT. They are no way similar to LCD or plasma.
__________________
Samurai
Old 3rd January 2007, 17:28   #64 (permalink)
esteem_lover's Avatar
i am not a techie to explain it in technical terms, but i will tell try. In the normal 100Hz TVs that we get to buy for a king's ransom, you get smearing of images, trails etc. This smearing is caused by digital artifacts (The set has to do digital encoding and decoding in realtime), since most of the TV signals are in analogue. A faster and better processor in the TV may lessen or resolve this issue. But while playing a DVD, it is entirely different, the picture quality is amazing with vivid colours that you can only dream of in a 50HZ TV.
Coming to LCD screens, the most vital part is the response time. That is the time taken for one pixel in the panel to go from active to inactive & back to active again. The higher the response time, more the digital artifacts as caused in the 100HZ TVs. (See the similarity ?). Now, there are excellent LCDs & excellent 100HZ Tvs, but what we see in our 'exclusive' showrooms is mostly full of sets that have a resposnse time that is not adequate to show our analog signals in good clarity. of course, the movie channels might look good, which it does for me too, but the real problem is when you watch poor quality signals (which are very much available even in DTH) & in watching sports channels with inadequate bandwidth.
It seems that the manufacturers needed a selling point that would be cheap to implement and released technology that was not ready.
cheers
__________________
"Keep your friends close, Keep your enemies closer"
Old 3rd January 2007, 17:58   #65 (permalink)
gkrishn's Avatar
Lets say if you are watching espn thru cable on your 100hz crt... Why do you think and digital encoding, decoding has to be done?? As per my understanding its analog all the way.
Your 100hz crt should be able to give amazing, vivid colours just like any 50hz tv. The difference between 100hz and 50hz in most cases where just the refresh rates. Except for the panasonic, and sony DRC model which were also HD tvs.
I extensivly looked at the panasonic model, which is discussed in the 29inch flat crt thread. It was much better than similar 50hz 29 inch panasonic models in the shop. both were playing some cable channels only.
But then what is the size of ur 100hz model? and what is the size of 50hz model you are mentionin?? In my opinion above 25 inch the quality, using normal cable network, actually drops. Actually you might start noticing the pixels...
I dont think the artifact are due to the higher response time as you mentioned. But it could be because of another reason. The normal anolog CRT has 640x480 resolution. Which they term as 480i. "i" stands for interlace. The normal cable and even DTH guys might give you feed for this resolution only.
But the LCD, 32 inches i was looking at, has 1366x768 resolution. 768 amounts to 720p. "p" for progressive. When u give ur normal cablewala feed to this LCD, it has fill up the rest of resolution. So how the final image might apear on the screen, completly depends on the LCD up conversion from 480 to 720. This is where it could result in too many artifacts. This is my understanding.
Apart form all this technicalities, I just happened to watch the Ind-SA match on star sports on a 40 inch sony "S" series connected to tata sky. The 16:9 resolution strecthed the faces little bit, and noticable when commentators apeared in close up. Other than this, the quality was really good.
__________________
Old 3rd January 2007, 19:19   #66 (permalink)
Nope, In 100 Hertz sets, the frames are scanned at a rate of 100 times per second, which is twice as often as in a 50Hz set. To be able to double the number of image frames, 100 Hz televisions use a digital memory. The digital memory converts all incoming video signals from analog to digital. It stores every new frame for a split second, so that it can be written a second time (from memory) to the screen. After that, the digital signal is converted back to analog and sent to the screen twice as fast. i guess thats where the digital part comes in.
the colours & image clarity on a 100HZ , in my opinion cannot be matched by any 50Hz or even LCD screen (the lower & middle end systems that are available in the market today). that is my opinion. I believe these TVs are built down to a budget & not built upto a standard, in which case, what we normally get is called VFM. BTW, i have a Phillips 29, which is also a HD compatible TV.
If you are happy with it, what else is required, just go ahead & buy it.
__________________
Old 22nd January 2007, 17:07   #67 (permalink)
Guys, i have been looking at 42 inch plasma tvs. Have heard about the latest LG time machine tv. Also , am considering the Samsung and Panasonic models. Any suggestions/tips/feedback/reviews would be welcome about the brands.
mrhap is offline   Reply With Quote
Old 22nd January 2007, 17:48   #68 (permalink)
akshay1234's Avatar
Infractions: 0/1 (4)
out of those samsung would have the best after sales service.. the panasonics are a bit delicate.. the samsung would be the best out of them.. but also look at lcd before you buy a plasma because the lcds are newer technology.
akshay1234 is online now   Reply With Quote
Old 23rd January 2007, 11:11   #69 (permalink)
As far as features and quality are concerned, what would people suggest. Features wise LG with its 80 gb in built hard disk sounds quite exciting, but am not sure about the picture quality....panasonic is supposed to have good quality but very dry on features, samsung is supposed to be middle of the road....comments anyone?
Old 23rd January 2007, 11:44   #70 (permalink)
akshay1234's Avatar
see the picture quality for yourself and decide.. anf after having a normal panasonic crt tv ive come to the conclusion that panasonics are delicate and dont have good after sales service..
Old 24th January 2007, 11:06   #71 (permalink)
Well, i just wanted to have some personal comments based on people's experiences. I am sure a few people on this forum must be having one of the plasma's i have mentioned?So i wanted personal experiences.
Old 24th January 2007, 13:29   #72 (permalink)
Samurai's Avatar
I compared LCD and Plasma for a long time before settling for Plasma two months back. Even plasma technology has improved leaps and bounds, and Samsung is the clear leader. The major problem with LCD is the viewing angle. If you are not sitting right in front of it, the image will suffer. While it has acceptable viewing angle along the horizontal plane, the viewing angle is very acute in the vertical plane. If you are standing in front a LCD TV placed for sitting audience, you can barely see the clarity. Even in the seating position, if you deviate from the center of the LCD screen along the vertical plane, there will be lose of clarity.
__________________
Samurai
Old 24th January 2007, 14:59   #73 (permalink)
which brand and model / size plasma have you bought? whats been your experience with the quality and other add-on features?
Old 24th January 2007, 15:16   #74 (permalink)
Samurai's Avatar
I got this one:Samsung Plasma TV | PS-50Q7H
Amazing picture quality, what else can I say. In combination with Tata Sky, it is a great experience.
__________________
Samurai
Old 26th January 2007, 23:47   #75 (permalink)
determinus's Avatar
Two issues with LCDs are that
a) The pixels can die. And when it does, you just loose one line from the display. The life/quality of any batch of transistors cannot be uniform, so dead pixel is quite a possibility. The replacement can only be done as complete panel, and costs 25k or so.
b) You cannot control the intensity of the glow, the pixel is either on or off. In plasma - technically - the voltage can be controlled for better intensity. BTW, the intensity is not a major issue in dimly lite rooms and if watching distance is 15' or more.
Plasma also has its own issues. But with Laser projection devices (touted as Plasma/ LCD killer) on the horizon, I would rather wait for 6-9 months for the Laser TV to come out. And even if it cannot kill them both, the LCD/ Plasma prices are going to come down sharply. I certainly wont mind a Bravia 40" for 75k. As for the dead pixels, I will take that chance.
__________________
Never invest your money in anything that eats or needs repainting - Billy Rose
determinus is offline   Reply With Quote
Thread Tools
Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS jassi Shifting gears 57 13th October 2009 20:06
LCD Display for Santro shashankre Ask the Gurus 15 26th June 2007 11:40
LED alloy wheels that can display virtually any image while you drive! Neo. Tyre & Alloy wheel Section 26 17th August 2006 16:12
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
