| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #871 (permalink) | |
| BHPian Join Date: Sep 2006 Location: Bangalore
| Quote:
BTW, had almost zeroed down to Philips 7332 or LG 32LB9 and then got confused as philips 've launched a new model 7768.And now this Plasma.Now I'm in a soup. EDIT : Also, when I checked the LG site I found that the resolution of the Plasma is 852*480 so doesn't that mean that it's not even HD ready ? Same is with their 42PC7RC.Am I missing something here ? Last edited by kaushik_s : 24th March 2008 at 17:30. | |
| | #872 (permalink) |
| BHPian Join Date: May 2007 Location: Navi Mumbai
| Hi, Here's a slightly different question. The viewing distance would be appx 12ft, so should I buy a 32" LCD or a 37" would be better? I'm in a dilemna about screen size since my budget is 40K, stretchable upto 45K, but don't want to be stuck with a wrong-sized (read: smaller-sized) screen.
__________________ A fine is a tax for doing wrong. A tax is a fine for doing fine. |
| | #875 (permalink) | |
| Newbie Join Date: Sep 2007 Location: Chennai
| Quote:
Regards, ![]() | |
| | #876 (permalink) | |
| Newbie Join Date: Oct 2006 Location: Bangalore
| Quote:
if you are looking at 720p. In fact you could even consider 480p as you won't be able to make out the difference at that distance. But keepping your budget in mind you could get a 32" and sit at a distance of around 6 ft. to get a better hdtv experience
__________________ 0-100 in 5.0 ...!! '02 Ikon 1.6 '06 Alto '06 City | |
| | #877 (permalink) | |
| Quote:
I got a chance to compare 5-6 brands side by side out of which Sony 32S310A (@Rs.44990) and LG LC7 (@Rs.42990) look good at my budget of 45K. I would prefer Sony over LG, but I want to know what is the difference between sony's v-series and s-series?
__________________ A fine is a tax for doing wrong. A tax is a fine for doing fine. | |
| | #878 (permalink) | |
| Quote:
Philips 7332 - fits into my budget nicely just 42k. Good picture quality. Philips 7762 - more features,newer tech,3 HDMI and I liked the picture quality of it's 42 inch brethren and I found the pic quality slightly better then 7332 (but that is may be due to the settings also) LG32LB9 - Picture quality same as 7332, looks nice but never used LG before so not much idea how the after sales are. Samsung LA32R8B - Bit more pricey and I didn't like the too rich picture quality of Samsung Sony - I'm fed up of paying Sony for their overpriced/overhyped models,be it TV or music systems. Regards, Kaushik How is the service of Panansonic, cause when I was looking around few of the people advised me to stay away from it as the After sales is very very poor. Is it true ? Although they did admitted that Panasonic is probably the best in the lot. | |
| | #879 (permalink) |
| Senior - BHPian | I watch my LCD ( 40 inches) from a viewing distance of approximately 12ft-13ft and it looks very nice. However, i have noticed if i inch a feet or two backwards the viewing becomes even better.
__________________ I have terrible reflexes- I was once run over by a car being pushed by two guys !!!!!!! |
| | #880 (permalink) | |
| Quote:
1) The TV size 2) Aspect ratio (16:9 is a must) 3) Display resolution 4) Viewing distance So the optimal distance is where you are not able to see the individual pixels.Lower resolution leads to higher viewing distance. ![]() | |
| | #881 (permalink) | |
| BHPian Join Date: Aug 2006 Location: Bangalore
| Quote:
I was in the same dilemma some time back, and chose LG over Sony S series.
__________________ I thought this is a free world! Outta here... | |
| | #882 (permalink) |
| Senior - BHPian | LG would be much better deal than a Sony S-series. Sony products are always overpriced and they stand by their pricing and don't offer any discounts ( even if it means low sales)
| | #883 (permalink) | |
| Quote:
1) LCDs has very poor reproduction of blacks.Darker screen images never show up as true black, but rather as various shaes of gray.Select the one which produce closer to black color. 2) Response time <= 5ms, just to avoid seeing the moving ball trail. 3) Resolution as stated previously, should be >= 720p. You get the best feel when the viewing distance is less. For the same size,higher resolution TV allows to sit closer. I own Panasonic(very good) and here are the specs; Model:TX-32LX700C Display Type:LCD Price:Rs.48500(Jan08) Response Time:5ms Aspect Ratio:16:9 Visible Screen Size: 80cm(Diagonal) Display Resolution:1366x768 Speakers:Woofer(120mmx60mm) 2 numbers, Tweeter(23mmx100mm) 2 numbers Audio Output:29W rms HDMI: 2 ports SD Card slot SRS TruSurround XT Panasonic after sales service no idea, so far no issues. Good luck for your hunting ![]() | |
| | #884 (permalink) |
| Only 48.5 k for Panasonic 32LX700 ? I was quoted something around 60K if I can remember correctly. BTW, out of all the models that I've mentioned only LG has response time of 5ms others all are 8ms. So you mean to say that should I go for LG ? LG is available for around 43k. |
| | #885 (permalink) | |
| Quote:
![]() Just by looking at response time, yes, but then check other parameters like black reproduction, display resolution,sound quality(if you are going to use TV speakers), connections like composite,S-Video,Component,HDMI(these requirements will be based on your video sources). If you have game console(PS3) look for two HDMIs For your portable video sources like camcorder you need to look at the connections on the front/side.It is lot easier to make a quick temporary connection. And for the contrast ratio there isn't a standardized,approved way of measuring, so one manufacturer's 1000:1 may not be the same as another's.Use your own eys or look at the reviews of the product. If your are going to use composite cable anytime, then comb filter is a must, minimum look for 3D-Combo. Good luck and let me know your selection ![]() | |
| Thread Tools | |
Similar Threads | ||||
| Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS | jassi | Shifting gears | 57 | 13th October 2009 20:06 |
| LCD Display for Santro | shashankre | Ask the Gurus | 15 | 26th June 2007 11:40 |
| LED alloy wheels that can display virtually any image while you drive! | Neo. | Tyre & Alloy wheel Section | 26 | 17th August 2006 16:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
