Old 8th July 2014, 20:43   #7471
mayankk's Avatar
Thanked: 3,561 Times
Went with a Samsung 42 in pdp with 3d. Dropped the idea of the projector for sometime later as I was getting too confused, and went to check TVs only.
One toshiba guy was offering a sweet deal on a 40 in smart 3d, but only had the display piece, for 55k. Fished some more and picked up the Samsung for 42k, 2 years warranty, 2 active 3d glasses included.
mayankk is offline   Reply With Quote
Old 10th July 2014, 13:10   #7472
mayankk's Avatar
Default re: The TV Thread - LCD, Plasma, LED etc.
This TV is turning out to be quite fun.
It does render good 2d to 3d conversion. I painted a 10x8 ft section on the wall behind the tv black, and with a dark room, it was quite good fun to watch a non-3d Gatsby rendered by the TV.
Just wanted one clarity, though. This rendering, its more of a depth effect, than a pop-out you typically associate with #d movies?
Will getting a proper 3d content file playing on it give the pop-out effect?
Old 12th July 2014, 00:30   #7473
S_U_N's Avatar
Thanked: 383 Times
I would suggest try the sample 3D videos from LG and Samsung. They are pretty good and you can test them out personally and see the results.
Videos should be easily available for download through some sites.
S_U_N is offline   Reply With Quote
Old 14th July 2014, 09:19   #7474
Thanked: 219 Times
Experts,
Kindly advice on below toshiba model.
Toshiba LED
In General, How;s toshiba LED;s . I am more of a CRT guy and prefer simple stuff in life. Most probably Max experiment, I will do with this TV is Hook up a home theater and a USB 1 TB Disk .
Not sure how Much HDMI / USB i need But is there any standard available as this is minimum which must be there in a LED? .
.sushilkumar is offline   Reply With Quote
Old 14th July 2014, 13:53   #7475
Thanked: 1,068 Times
I have a Samsung smart TV (Series-6, 40F6515). When I use the YouTube App on the TV, is there a way to control the resolution? Is there a way to make sure that the 1080p clips available are actually streaming at that resolution?
StarrySky is offline   Reply With Quote
Old 14th July 2014, 14:33   #7476
Awaiting Email Confirmation
Thanked: 351 Times
I think, it is dependent on bandwidth that you have. If your network is capable of delivering more speed, your video quality changes. Also youtube provides option to change the same manually. My experience after using 2 mbps and 15 mbps connections back to back on same PC.
gemi_kk is offline   Reply With Quote
Old 14th July 2014, 14:45   #7477
Bandwidth is not a limiting factor for me. However, I have noticed that when I play YouTube videos on my PC, they do not start playing at 1080p by default. I have to manually change it to 1080p (as you also mentioned) and then it streams in HD without any issues. I suspect that when I play HD YouTube videos directly on the TV, it doesn't start at 1080p either. However, I do not see any option to manually change the quality setting when I play YouTube videos directly on the TV.
Old 14th July 2014, 18:12   #7478
thewhiteknight's Avatar
Thanked: 199 Times
Guys, any information/recommendations about 20 odd inch touchscreen monitors? I am assuming all of them would come with atleast one HDMI in.
The plan is to connect the Android stick and mount it either in the Kitchen or a kitchen trolley which the wifey or I could wheel around as required. Since I have a pretty reliable wifi connection in the house, having an arrangement like this would work awesomely to watch a cooking show in the kitchen or a movie in the terrace.
Any thoughts? I've seen a couple online but I'm not sure if a price of around 20K is a good buy.
thewhiteknight is offline   Reply With Quote
Old 14th July 2014, 18:19   #7479
mail4ajo's Avatar
Thanked: 261 Times
Anyone figured out a way to connect your Apple devices to the TV wireless apart from Apple tv? I use youtube.com/pair for video. Works well. But cannot find any other screen mirroring options.
mail4ajo is offline   Reply With Quote
Old 15th July 2014, 16:07   #7480
iTNerd's Avatar
Thanked: 505 Times
Hello everyone, I wanted to buy a 65" or higher LED TV (full HD) with additional features of 3D, Internet TV etc within the budget of 2 lacs. But it seems I have to increase my budget for at least a lac to get one. The only one I am getting within the budget is the Plasma TV SamSung 64F8500 series 64". I was wondering if any one of you have this particular model and how good and reliable it is? (picture quality, brightness and for gaming).
iTNerd is offline   Reply With Quote
Old 15th July 2014, 17:46   #7481
khoj's Avatar
Thanked: 1,258 Times
For this size you should look at Panasonic for Plasma and Sharp, Sony & Hitachi for LED panels. Having said that, in terms of the latest connectivity/smart features Samsung is unbeatable.
Old 21st July 2014, 21:33   #7482
sumeethaldankar's Avatar
Thanked: 1,161 Times
Guys which is the most reliable and long lasting LED at budget of 40K and 40 inch size ? For me only size and reliability matter.
sumeethaldankar is online now   Reply With Quote
Old 22nd July 2014, 08:07   #7483
diyguy's Avatar
Thanked: 181 Times
Got a 42" Samsung for 43.5k two months back, grey market. Check this thread for reliability, If you are particular about it go with an extended warranty option with sellers like Croma, but then price is different.
diyguy is online now   Reply With Quote
Old 22nd July 2014, 10:06   #7484
akshay380's Avatar
Thanked: 664 Times
You can check Toshiba P2305 or L3300 series. Comes with 3 year warranty.
akshay380 is offline   Reply With Quote
Old 22nd July 2014, 20:05   #7485
mail4ajo's Avatar
Thanked: 261 Times
How are you concealing the wires when you install the TV on the wall. Also are these types of low profile wiring ducts available in the India? These can be painted to match the wall color.
Best Movies, Documentaries, games, etc to Showcase your hi-def plasma/lcd & HTS jassi Shifting gears 58 28th December 2010 19:11
Underglow Thread: Please post pics & info of underglow(neon/LED/etc.) kit on your car DIY Guru Modifications & Accessories 1 18th November 2010 03:08
LCD TV or (LCD montior+VGA Box) for Wii? ashwin489 Gadgets, Computers & Software 0 20th July 2009 14:33
