Old 3rd January 2007, 22:39   #16
Thanked: 11 Times
Originally Posted by wolfinstein View Post
For Optimum Disk Utlization, Run a Defrag..Once a month
Give a try to Diskkeeper to defrag the files.
Mugen.
Mugen_Power is offline   Reply With Quote
Old 3rd January 2007, 22:45   #17
normally_crazy's Avatar
Thanked: 389 Times
OFFTOPIC
There seems to be a problem with my external HDD. The laptop sometimes detects it at the 1st go , and other times it just refuses to detect. And also the HDD makes noises like its running.
What could be the problem ? And how do I recover my data if there is a problem with the HDD ?
Thanks in advance guys.
normally_crazy is offline   Reply With Quote
Old 3rd January 2007, 23:33   #18
tsk1979's Avatar
Thanked: 15,683 Times
Most probably your HDD is loose in the casing. When its working recover all data from HDD. After than you can experiment
Old 6th January 2007, 22:27   #19
krazykul's Avatar
See some of this links for increasing the performance of your computer Search Results
krazykul is offline   Reply With Quote
Old 11th January 2007, 14:31   #20
katalyst's Avatar
Some operating systems impose a 137GB limit. Try partitioning.
Read this from the seagate website:
137 GB Limitation
The Serial ATA BIOS is not subject to the same limitations as the Parallel ATA BIOS. However the 137-GB limitation imposed by most operating systems still applies.
Please refer to the following Microsoft Knowledge Base articles for assistance with the Windows Service Packs and enabling 48 bit LBA support.
Windows 2000
[COLOR=#0000ff]http://support.microsoft.com/default.aspx?scid=kb;en-us;305098[/COLOR]
Windows XP
[COLOR=#0000ff]http://support.microsoft.com/default.aspx?scid=kb;en-us;303013[/COLOR]
Windows 98 and Me do not provide support for 48 bit LBA. There are no Service Packs or patches available from Microsoft to enable this support.
Mac OS X natively supports 48 bit LBA. This allows the drive to be recognized with the full capacity available at installation.
Note: Serial ATA host controllers that identify themselves to the system as emulated SCSI devices and will not be subject to the 48 bit LBA limitations imposed on Parallel ATA drives.
Many of the newer onboard Serial ATA chipsets use Parallel ATA emulation. If the Serial ATA controller drivers are not loaded during the operating system installation, the Serial ATA drive will only show the capacity supported natively by the operating system version being installed.
katalyst is offline   Reply With Quote
Backup Solutions : Windows 2003 compatible External HDD ? Need help ! FlyingSpur Gadgets, Computers & Software 36 11th November 2009 15:35
Computer Experts. HELP!!!!!!! SRK Gadgets, Computers & Software 49 7th August 2009 16:55
HDD password break for IBM Laptop-- Help Needed invincible7 Gadgets, Computers & Software 17 6th June 2009 01:10
Help formating laptop HDD abhibh Gadgets, Computers & Software 10 6th August 2007 13:54
Kenwood AMP/ICE advice plz plz cuteavaya In-Car Entertainment 9 10th January 2007 11:52
