Old 1st February 2007, 19:50   #16
Sahil's Avatar
Thanked: 2,249 Times
v1p3r, which phone do you have?
Old 1st February 2007, 20:50   #17
v1p3r's Avatar
Thanked: 27 Times
Tum log naa... See first post... I have a 6233 from our Finnish friends.
Old 1st February 2007, 21:26   #18
Akshay1234's Avatar
Thanked: 6,727 Times
thank you for your forgiveness.
Old 2nd February 2007, 06:00   #19
devarshi84's Avatar
Thanked: 119 Times
Depends on which kind of design you like. All have different designs. Select 2-3 based on your preferences and then let me know.
I personally prefer siemens just because I get the option to use my own headphones or use it in car, inhouse, on pc with the bluetooth.
THe best quality though was jabra/motorola.
I have not tried most of them.
devarshi84 is offline   Reply With Quote
Old 2nd February 2007, 09:36   #20
jesal's Avatar
have used the jabra and can vouch for it. its damn neat for sure. was 6000 in august now am not sure about the pricing of the same.
jesal is offline   Reply With Quote
Old 2nd February 2007, 09:47   #21
netarchie's Avatar
I am using the SE HBH DS -970, and its doing its job perfectly well. It’s lightweight and has very high sound/music quality and can pair up to 10 devices concurrently.
netarchie is offline   Reply With Quote
Old 2nd February 2007, 10:17   #22
Thanked: 1,503 Times
First choice Motorola, 2nd Sony Ericsson.
However, I think the iTeq range (yes they have a decent RANGE of stereo bluetooth headsets) are "cheap and best" - they even had a noise cancelling one.
Steeroid is offline   Reply With Quote
Old 15th March 2007, 11:44   #23
spadival's Avatar
Thanked: 15 Times
I have been searching far and wide for a A2DP headphone in India, but none of the usual mobile shops have any in stock.
V1per, Did u manage to buy one?
spadival is offline   Reply With Quote
Old 15th March 2007, 11:48   #24
navdeep's Avatar
It should not be a problem.. if its nokia.. goto any nokia priority.
Try any websites like ebay.in
navdeep is offline   Reply With Quote
Old 15th March 2007, 14:59   #25
v1p3r's Avatar
Thanked: 27 Times
No, it seems no one in India listens to music wirelessly. And the Nokia ones don't have FWD/REV.
Old 24th September 2007, 18:56   #26
extreme_torque's Avatar
Thanked: 1,389 Times
Guys,
Please suggest me a good bluetooth headset to be used with my SE P990i.
DSP or noise cancellation would be an obvious added advantage, along with LCD display for caller ID.
I have shortlisted Motorola HS 850, HS 300, Logictech Mobile Traveller, LG HBM-500 with an OLED screen and Jabra JX10.
Please give me your inputs among these or the one you have used or prefer?
I will be getting the headset from US.
Lavkesh
extreme_torque is offline   Reply With Quote
Old 24th September 2007, 22:13   #27
Mpower's Avatar
Thanked: 1,682 Times
How does the sound quality in one of these (good ones) compare with that of an I-pod. From an SQ point of view is this a viable alternative to an I-pod.
Old 28th September 2007, 12:52   #28
grvanand's Avatar
Go in for Motorola S9, the one Abhishek wears in moto ads. Its sound quality is much better than the wired headset I got with N95 and also another Nokia one (must be BH 501 model I think) and the build and features are the best currently available.
grvanand is offline   Reply With Quote
Old 28th September 2007, 13:21   #29
cutdcrap's Avatar
Exclamation
I have a Samsung SCH-W339, or Duo as it is called. It has A2DP. Now my stupid question is that can I hear music on a normal Bluetooth headset as well? BTW, I have a Motorola H500
I tried but it didnt work, if it does, can anyone please suggest what wrong am I doing? Although I am able to connect as a bluetooth device over voice calls.
cutdcrap is offline   Reply With Quote
Old 28th September 2007, 13:28   #30
Is your Motorola listed in your device as "Handsfree" or "Headset" ? If the former, you will only be able to take calls.
Very few regular BT Handfree sets support a headset profile, but you may get lucky!
Which bluetooth headset to get CaliAtenza Gadgets, Computers & Software 47 24th September 2013 19:46
Bluetooth headset + driving illegal? Yup, details on pg. 4 finneyp Shifting gears 76 6th July 2013 14:51
bluetooth headset problem vivekiny2k Gadgets, Computers & Software 0 15th October 2008 00:43
Which bluetooth headset? extreme_torque Shifting gears 1 24th September 2007 17:08
Bluetooth Headset VMG Gadgets, Computers & Software 15 9th March 2006 01:57
