Old 1st February 2007, 15:04   #1
esteem_lover's Avatar
Thanked: 451 Times
Post Home Wireless A/V
I have Dish DTH at home installed in my living room. There is an option from Dishtv for the 2nd, 3rd & 4th connections. But all these involve cables running into the other rooms as well from the dish and they involve an initial expense of Rs.4k plus a recurring expense of 100 p.m as subscription. I have been thinking of something along this line
Philips SLV5400 Video Sender
But the problem is where to source it from & it is damn expensive too. I would like to know if anyone has tried something like this &
1. How is the clarity of sound & picture ?
2. What are the advantages & disadvantages ?
3. how much does it cost ? (Not the exact same model in the link)
4.Where is it available ?
I have a budget of 6k, slightly expandable for a simple & effective solution.
Any suggestions ???
Old 1st February 2007, 15:29   #2
khanak's Avatar
Thanked: 130 Times
so this will take the signal from your set top box and send it to your other tvs eh....well if you want something cheaper you can go in for the kind of amplifiers they use at electronics stores where one tv connection is used on all the channels..the only problem with any of these solutions is with just one tv tuner you will have to watch the same channel on all your tvs which kind of defeats the purpose of taking the connection on another tv as well....
khanak is offline   Reply With Quote
Old 1st February 2007, 15:31   #3
Thanked: 451 Times
Not only that, there is lot of cabling involved which i want to avoid.
Old 1st February 2007, 18:42   #4
Raajiv's Avatar
Any suggestions ???
e_l,
Good but see the bottom line below in the Web Page reading "Out of Stock".Guess it would be.
Raajiv is offline   Reply With Quote
Old 1st February 2007, 20:04   #5
Sahil's Avatar
Thanked: 2,742 Times
Tho you will be able to connect your 2nd TV through his wireless with your single set top box, you will not be able to change channels on your 2nd TV.
Which basically means that both TV's will be viewing the same channels, if you change the channel on the settop box both will change simultaneously. Pretty useless imo, just get another box installed.
Old 1st February 2007, 23:17   #6
Thanked: 451 Times
I think there is a remote which operates through this gadget & controls the parent device.
Old 3rd February 2007, 16:47   #7
Thanked: 23 Times
There are cheaper brands available that do the same job. In England you can pick them up for the equivalent of 1800RS.
Many have a remote control dongle which can be used to control sat receiver in another room.
bigman is offline   Reply With Quote
Old 7th February 2007, 14:04   #8
Thanked: 451 Times
That is what i am looking for. any idea about its performance ?
Old 7th February 2007, 16:07   #9
vivek_pinkoo's Avatar
Let's Automate. Wireless Video Sender with 4 source inputs, Video Sender, Wireless Sender, AV Sender, 2.4GHz
Here it is available. Not out of stock.
vivek_pinkoo is offline   Reply With Quote
Old 7th February 2007, 16:59   #10
Thanked: 451 Times
Thanks vivek. But, iam not sure about the compatibility with our DTH. Here is something i googled & found
Electronics Infoline Home : : Wireless AV Sender : : RC227
has anyone used this & how good is it ??
Setting up a Home Wireless Lan ajmat Gadgets, Computers & Software 299 12th October 2014 12:35
Wireless Home Networking Akshay1234 Gadgets, Computers & Software 35 31st May 2013 23:14
Linksys WAG 200G Wireless Home Gateway+MTNL Triband: settings required nishantgandhi Gadgets, Computers & Software 9 3rd June 2009 19:34
Wireless Speakerphone for your Car goldsun Gadgets, Computers & Software 1 18th August 2006 06:11
Wireless LAN protocol sandeepmdas Shifting gears 3 22nd September 2005 12:15
