Old 9th March 2007, 19:59   #1
Default Mercury Tv Tuner Card No Audio Help
I am not able to hear audio - ( Mercury Tv Tuner Card ) but i can view the video,
I have re-install the Tv Tuner driver
{ TV Capture Card WDM Tv Tuner &
TV Capture Card WDM Video Captuer }, Window Audio Driver ( Avance AC'97 Audio )
still i am not able to hear audio.
I had install 3 part software [ ChrisTV, Nero Media Home ] still no good.
Help is need!
icar is offline   Reply With Quote
Old 10th March 2007, 03:06   #2
SLK
SLK's Avatar
Thanked: 185 Times
I have a pinnacle.. TV tunner... for me the audio works through a line out port in the TV tunner............. which i connect to the line in of my sound card.... using a short wire that came along the package.
Check if its the same for your too...
SLK is offline   Reply With Quote
Old 13th March 2007, 18:32   #3
esteem_lover's Avatar
Thanked: 447 Times
It is the same for mine as well. i have the pixelview. So, did that work ??
Old 13th March 2007, 21:37   #4
aZa
aZa's Avatar
Thanked: 17 Times
try this s/w = DSCALER
Old 14th March 2007, 00:45   #5
amitverma's Avatar
there should be a little wire in the package with 2 jumper jacks on either side. one should go into the line-out port on the tuner card [not on the backside but on the card itself. u should see it when u plug the card in the PCI slot.] and the other end of the wire should go into the Line-in of ur sound card [similar as above]. this should make it work.
i dont know how the settings work in Mercury but in my Pinnacle Tuner's settings there is an option to switch the audio output to the tuner card itself. do check ur settings too.
i know it sounds a little confusing. pics would definately help. but....u know....laziness....man....im already tired of typing....
kidding. lemme see if i can find some examples.
amitverma is offline   Reply With Quote
Which TV tuner card? Shan2nu Gadgets, Computers & Software 22 10th April 2011 14:55
Which cities in U.P. can issue Smart card or Plastic card driving license (DL) ? zook09 The Indian Car Scene 11 24th November 2010 15:21
LAN card to LAN card sharing abhibh Gadgets, Computers & Software 15 21st December 2008 01:55
Need Advice on TV tuner CARD for Laptop wmax Gadgets, Computers & Software 1 7th August 2008 16:18
Lost : TV Tuner Card Driver CD mithun Gadgets, Computers & Software 3 10th April 2006 15:17
