Old 12th May 2014, 15:57   #61
Thanked: 2,383 Times
Default Re: Please suggest good Air Cooler
Originally Posted by fine69 View Post
Would the coolers that are available in the market for 4-5k good enough if to be used in a 125 sqft shop? It doesn't have any window and is closed from all sides with the front having a wooden/glass door.
We don't want to get an AC right away as this business is an experiment and I don't want to splurge too much just in case it doesn't work out later on.
Would the cooler do any justice in a closed room? Ours is a ground floor shop with no direct sunlight anytime of the day.
Technically coolers work best when there is circulation of air. Since your shop doesn't seem to have provision for cross ventilation, you could try putting an exhaust fan on one corner, cooler at the other. But this arrangement would not help much during the hot & humid days.
Dry Ice is offline   Reply With Quote
Old 12th May 2014, 19:50   #62
fine69's Avatar
Thanked: 867 Times
Exhaust fan isn't an option. Would a cooler still make any sense?
I'm not able to understand why it wouldn't work, its going to pull the same cold air from within the room and throw it out, what am I missing?
fine69 is offline   Reply With Quote
Old 12th May 2014, 20:35   #63
Guite's Avatar
Thanked: 180 Times
For optimum performance it needs to pull hot air, please see discussion on previous page. Going by your description you shop does not seem to have that option available.
Guite is offline   Reply With Quote
Old 12th May 2014, 21:08   #64
Thanked: 252 Times
Indeed, an exhaust fan is not required!
If you mount the cooler at the front of the shop (like a window AC) and leave a door or window open, again, obviously at the front, the cooler will work quite well. It will throw cooled air deep into the room and push out an equivalent amount of air from the room, via the open window/door at the front.
How deep is the shop and is there place to mount a cooler at the front somewhere?
Old 13th May 2014, 09:15   #65
You misunderstood. I am not saying it won't work.
It will, but might not give you that good a cooling effect like if there was a provision for good cross ventilation. That's all!
As for exhaust, I recommended it to aid the circulation.
Old 22nd March 2015, 12:05   #66
Raja's Avatar
Thanked: 61 Times
Looking for information and advice on buying a 'Waterless' Air Cooler.
Can someone recommend from their experience if they are worth buying?
Which brand to go for?
Raja is offline   Reply With Quote
Old 23rd March 2015, 07:17   #67
Thanked: 252 Times
This has to be one of the biggest cons on the market today!
Please read the following and see if it makes sense:
.... Air Cooler PLUS is designed with a patent-pending waterless cooling chamber. The chamber houses two advanced frozen gel packs and features a powerful variable-speed fan. The gel packs are filled with advanced HD-Ice(TM), each offering more cooling than conventional ice packs. The cooled air flows through a special dry, lightweight HEPA filter to clean and cool the air.
You'll need to have frozen gel bags at the ready all the time. Where do you intend to freeze them?
Old 23rd March 2015, 09:59   #68
sgiitk's Avatar
Thanked: 3,791 Times
Infractions: 0/1 (5)
I have been using them for over 50 years. My experience:
1. Do not use them to recirculate in the room.
2. most commercial units are junk, so get your own.
3. Make sure the enclosure in large, since the size can make a very big difference to the cooling. Also, getting a decent external pump is getting increasingly tough.
4. We have a 24" fan in a 6' x 3' enclosure (5' high) and are able to cool the whole house - about 3000 sq ft. The cooler is outside the top floor landing and using the stairwell works on all floors.
These beasts tend to be a bit finicky and may need frequent maintenance. Common problems are caused by the choking of the water outlets in the pipes, esp in hard water areas.
Old 22nd April 2016, 15:55   #69
driverace's Avatar
Thanked: 142 Times
Post Re: Please suggest good Air Cooler
Guys,
Pune has killer dry-climate + heat combination. Another 2 months to go - at the least!
I am thinking of picking up an "air cooler" this weekend.
Budget = 5-7K INR
Consider this:
1. This cooler will do service in a dry / non-humid environment.
2. The temperatures are only high in 3 months of the year (Avg Max 35-40 deg C - for good 7-8 hours of the day)
3. Much needed / occassional use in the late mornings / afternoons of 7-8 months (where avg max temperatures are around 33-36).
4. Keeping air cooler is desirable + keeping it slightly on the humid side, is good for the birds we have as pets (Cockatiel & budgies)
Any suggestions/recommendations?
It will be used to cool 120sqft bedroom OR 170sqft hall area.
Typical Online search results / Local franchises of VS/Croma etc:
1. http://www.vijaysales.com/Kenstar-KC...15-Litres/3872
2. http://www.snapdeal.com/product/symp...umbLabelId:237
3. http://www.snapdeal.com/product/baja...umbLabelId:237
4. http://shop.bigbazaardirect.com/cont...r-cooler-white
5. http://www.snapdeal.com/product/maha...umbLabelId:237
I have even looked at local made ones (though this one's from Nagpur) -
http://www.ramcoolers.com/shop/room-coolers-2/uno-204/
I don't mind buying a rugged, local make one - if it comes with service & recommendations (from our group).
As it is always, with so many options & form factors around for any/all budgets, I am confused
Help me figure out,
Ace.
driverace is offline   Reply With Quote
Old 22nd April 2016, 16:48   #70
Thanked: 252 Times
Ace, the local brand looks the best to me. The larger the cooling pads the better the cooling. These can be 'serviced' by anyone or even yourself.
Of the branded ones your best bet would be this: http://www.snapdeal.com/product/symp...ler/1894397662
The cooler should be mounted in a window with the front flush with the window. The cooler must draw air entirely from the outside. It is most practical to have a ball valve fitted and give a permanent water filling connection.
A cooler will cool best when the air from it is given an exit path to the outside. This is NOT like an AC where you'd re-circulate the indoor air for best cooling.
By choosing the exit path you can control what spaces get cooled.
Old 22nd April 2016, 17:06   #71
Thanked: 55 Times
Infractions: 0/2 (10)
Originally Posted by driverace View Post
Guys,
Budget = 5-7K INR
Consider this:
Help me figure out,
Ace.
I also live in Pune since last 11 years and first time I had to purchase air cooler.
I too had similar requirement and bought Kelvinator kpc20a from Radhika Sales Corporation, Pimpri.
You can see the same model at snapdeal. Here the price is Rs. 6199/- but I purchased it in Rs. 4300/- I find this cooler very good for a room size of 16x10.
http://www.snapdeal.com/product/kelv...r/679033339768
manish_symc is offline   Reply With Quote
Old 24th April 2016, 15:57   #72
Samurai's Avatar
Thanked: 14,524 Times
Bangalore is basically roasting me and family this summer. Since I am in a rental home, don't want to install expensive AC.
So I looking for air cooler instead. People are suggesting I buy local air cooler than a branded one. But, how does one buy a local air cooler, does Bangalore even have that option?
Old 24th April 2016, 16:20   #73
I dont know about the local coolers. I have been using http://www.amazon.in/Symphony-Diet-1.../dp/B00IYD419Q and found it very good. Its good enough for 2/3 people. Btw you get better deals in brick and mortar stores.
adithya.kp is offline   Reply With Quote
Old 24th April 2016, 16:22   #74
Thanked: 94 Times
The only air cooler you get here are some branded plastic crap ,overtime the water tank sag with the weight of water,same goes to the wheels.
I bought a ramcooler nagpur aircooler online,smart 550h model.It does a good job of cooling around 450sq feet.Ambient indoor temperature without air cooler 35c and with air cooler 29c .
But humans will feel the air even cooler because the moisture evaporates when it comes in contact with your skin.
If you put in a smaller room of say 150sq feet ,then the temperature can drop to 26c.
aim120 is offline   Reply With Quote
Old 24th April 2016, 18:55   #75
Thanked: 252 Times
What you say is not correct. In a smaller room the temperature will not come down; you are equating this cooler with the principle that air conditioners work on.
And, further, if this same cooler is mounted in a window it will manage to bring the temperature down by at least another 3 to 5C.
With a large (3X3X5 feet) cooler mounted correctly in a window my entire home, including bathrooms and kitchen, (approx 1700 SqFt) is at 21 to 24C with RH in Delhi these days at 7 to 14% and ambient at 42C. Hard to beat with ACs.
The performance of an air cooler depends on the RH - the lower the RH the better the cooling. The ambient temperature is not important; it will manage to cool the house the same even with ambient of 50C.
2015 MotoGP Safety Car - BMW M4 with water injection system for cooler (intake) air syedhafeez The International Automotive Scene 0 17th February 2015 02:52
5 in 1 Printer - Please suggest a good buy ! zakaaaaasss Gadgets, Computers & Software 111 22nd September 2014 19:03
Travel to Udupi - please suggest a few good places to Stay shankaranand Route / Travel Queries 11 23rd December 2008 17:09
preparing my car for delhi traffic (suggest some good Maruti service stations please) dr.abhijeet Modifications & Accessories 38 7th March 2008 15:21
