Old 12th April 2010, 15:54   #241
sumannandy's Avatar
Thanked: 219 Times
Default Terrible experience with SBS Inverter in Bangalore
We had purchased an inverter with sealed battery from SBS electronics in Bangalore. Yesterday it caught fire.
When contacted, the customer service was very very very rude. they first said they cannot provide service on Sunday. Luckily my landlord helped me to switch it off. Then they sent somebody who came after 2.5 hours and said it happened because the 5 AMP refrigerator connected to the line actually takes 15AMP and it burns the unit.
When said it is never possible or else the whole house would be burnt out or the fuse totally tripped, he started giving lame excuses like the installation was not correct. And finally he agreed to take back the unit and refund the whole amount.
Today morning after making multiple calls they said they would deduct 2500 and then pay the rest for 2 months usage. They also said calling them is a WASTAGE of their time and they do not want a customer like us. We could not believe that any company can say that to their customer.
Any inverter catching fire should be a design problem in our opinion. And instead of pacifying the customer, they are saying that it is a wastage of time and they do not want a customer. If the whole house is burnt, I don;t know who will take the responsibility.
They have a very very poor service and there are some problems in the unit as well. We have used so many inverters but not a single one even caught fire.
I lodged a complaint with the consumer forum. And definitely do not recommend that to anybody. I am wondering if the consumer forum actually works.
sumannandy is online now   Reply With Quote
Old 12th April 2010, 16:01   #242
benbsb29's Avatar
Thanked: 4,277 Times
Suman, there is a reason why people tend to pay a premium for a branded product. Not trying to rub salt into the wounds, but there are many more reliable products which you could have probably tried out.
As for the issue at hand, there should have been an overload sensor which should have cut the power the moment it sensed an overload. Such a feature exists with other inverters such as APC, Sukam etc.
Lets hope for a speedy redressal to your case filed with the consumer court.
benbsb29 is online now   Reply With Quote
Old 12th April 2010, 16:05   #243
Thad E Ginathom's Avatar
Thanked: 8,377 Times
Amazing. Surely, overload protection (if this was caused by overload) is a basic? This is something we should all check on before buying such a unit.
The company sounds like one to be avoided.
Congratulations on Your lucky escape from what could have been a catastrophe.
Old 12th April 2010, 16:11   #244
Thanked: 146 Times
And which is this company?
SBS Inverter or SBS Electronics? You have mentioned both these names.
HappyWheels is offline   Reply With Quote
Old 12th April 2010, 16:27   #245
Spitfire's Avatar
Thanked: 707 Times
Isnt SBS Sukam? Or is this a different company?
Spitfire is offline   Reply With Quote
Old 12th April 2010, 16:28   #246
Alter_Ego's Avatar
Thanked: 98 Times
I agree to a certain extent with Ben but that does not give any customer care, even though the non branded ones, a right to speak to a customer like this.
I was planning to get an inverter for my house.Thanks Suman.I have one cheapo off my list now.
Its much convenient to decide now
Alter_Ego is offline   Reply With Quote
Old 12th April 2010, 16:31   #247
sumannandy's Avatar
Thanked: 219 Times
I actually thought they are good company. They said that they have clients like Infosys and others, so we got that. This was our mistake for sure.
Next time we will surely go for branded products.
Thank you.
Overload protection should be basic. All inverters we have ever used had this feature so we did not think that we needed to check that.
SBS Electronics and equipments pvt. Ltd. We even talked to the owner, he was also very very very rude. If this happened in other countries, there could have been lawsuits.
Old 12th April 2010, 16:41   #248
Thanked: 146 Times
Suman,
Would have been great if you had placed the correct name of the company (atleast SBS Electronic) in the header.
Anyway, in the market for an inverter and will be avoiding these people.
Old 12th April 2010, 16:57   #249
Thanked: 198 Times
Originally Posted by lohithrao View Post
Anup, the xenon has 18months warranty and the local battery has 2.5years..
I spoke to another dealer he offered me a local tubular battery + 800va xenon inverter + the trolley for 15k.
Surprisingly the xenon dealer told me the tubular battery the maintenance is more and it takes les load just the life is more but local dealer told that tubular is better in all terms...not sure whom to believe
Local Tubular battery are good the only hitch is that you need to top it up with distill water once in 4-5 months. Other wise the performance is pretty good and in case of cell failure, local battery can be repaired easily. At my inlaws place the local tubular battery is going strong for the last 4 years.
tj123 is offline   Reply With Quote
Old 12th April 2010, 21:04   #250
khoj's Avatar
Thanked: 1,258 Times
Thanks guys.
Inverter am more inclined towards "Xenon" on the battery the dealer was suggesting some local tubular battery.. still confused on the battery:0
Ideally inverter and battery should be from the same manufacturer. You can contact another dealer or go to Xenon direct.
Xenon ::Customer Care::
Another option is Videocon. Their inverters are with FCT based conversion techno;ogy which is better than the MOSFET based technology found in other inverters. As you can see from the link they now provide you with batteries too and the availability should be better too.
http://www.videoconworld.com/index.p...id=83&cat_id=9
Old 13th April 2010, 10:24   #251
lohithrao's Avatar
Thanked: 163 Times
Am already disappointed on the Videocon, the customer care has no info on pricing nor the dealer.
I guess Xenon might be the optiion, though am not sure if i want to buy the non tubular batt from Xenon...
lohithrao is online now   Reply With Quote
Old 13th April 2010, 13:33   #252
Chipz's Avatar
Sumannandy. How much watts is your inverter. Did it really burst into flames or was there only smoke. Does it have a plastic case.
Some points to check before buying inverter;
1. Overload protection.
2. Short circuit protection.
3. Surge suppression.
4. Full charge cutoff, trickle (this is basic).
5. AC bypass option.
6. Auto restart after overload or trip.
7. Do some research with friends and neighbors. Mostly avoid new brands and new technology. They are mostly doing R & D on customers and you dont want to be a guinea pig.
Will give more as it comes to my mind. Till then happy power cut.
Chipz is offline   Reply With Quote
Old 13th April 2010, 14:27   #253
Abes's Avatar
Thanked: 57 Times
And the inverter need good ventilation.
Abes is offline   Reply With Quote
Old 13th April 2010, 14:30   #254
lohithrao's Avatar
Thanked: 163 Times
Thats bad Suman, i guess most of the Indian products is backed by a very bad after sales!
Now am quiet certain that going for a "non branded" batts are dangerous?
I havent got good review on "Sukam" batteries, that leaves me with "Exide & the Amaron"
Old 13th April 2010, 14:37   #255
Chipz's Avatar
Thanks abes, but these were meant to be done before buying an inverter.
Will put another post for things to be done after buying an inverter.
Inverter Batteries Tarun Gadgets, Computers & Software 1285 16th July 2018 12:20
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Myth: UPS can't run on inverter? linuxtechie Gadgets, Computers & Software 17 24th October 2008 15:47
