Old 13th April 2010, 14:59   #256
Chipz's Avatar
Originally Posted by lohithrao View Post
Thats bad Suman, i guess most of the Indian products is backed by a very bad after sales!
Now am quiet certain that going for a "non branded" batts are dangerous?
I havent got good review on "Sukam" batteries, that leaves me with "Exide & the Amaron"
Bad after sales are specific to the brand and the region. Not all brands have bad after sales. Some non brand products are even better than branded products. Most of the branded products are imported from china, and we know their quality, but it does not mean they are bad. They have good R&D to support them. Check with your friends and neighbors about the products they are using and chose from them. I know Sukam and Exide batteries which have gone dead.
If possible go with EL series of exide. I have heard good about them.
Chipz is offline   Reply With Quote
Old 13th April 2010, 15:36   #257
Abes's Avatar
Thanked: 57 Times
Originally Posted by Chipz View Post
Thanks abes, but these were meant to be done before buying an inverter.
Will put another post for things to be done after buying an inverter.
The inverter itself needs good cooling and ventilation - either cooling fans or good heat sinks to dissipate the heat generated in the components and slots in the encasement for cross ventilation.
The points to be noted after buying the inverter would be great.
Abes is offline   Reply With Quote
Old 13th April 2010, 18:54   #258
khoj's Avatar
Thanked: 1,258 Times
Am already disappointed on the Videocon, the customer care has no info on pricing nor the dealer.
I guess Xenon might be the optiion, though am not sure if i want to buy the non tubular batt from Xenon...
That is disappointing news regarding Videocon.
As for Xenon it is a subsidiary of the Amara Raja group who also make Amaron batteries. Infact Xenon is nothing but the Amaron Shield though in White casing. I am personally using the same and have no issues in year and a half of ownership.
Old 20th April 2010, 13:14   #259
JPZ
Hi All,
I have recently bought the following Inverter + battery.
Sukam Smiley 1.4kVA inverter UPS (2 Yr Warranty) @ Rs. 8000
Exide EL6+ 130AH Fully Tubular battery (5 Yr Warranty) @ Rs. 13000 x 2
Total @ Rs. 34,000/= (Incl. Taxes)
I am ok with them except for the following:
1) The Batteries are quite big and both cannot be fitted into a single trolley / Cover.
2) When the inverter is powered on and is in idle mode (no discharge or charging happening), there is a faint high pitch noise (similar to that buggy monsoon nights). For me thats quite irritating despite having installed the set-up in a secluded place. I am ok with mild noise when charging or discharging but not when in idle mode.
I learnt from my vendor that this is common phenomenon for inverters above 1KVA. It seems there is an addional coil for cooling purpose. This coil is mated to an IC that yells out at high frequency.
Please let me know if any of you have experienced the same and if there is any work around for this.
Thanks.
JPZ is offline   Reply With Quote
Old 20th April 2010, 16:34   #260
khoj's Avatar
Yes my Sukam 1400 va also makes a humming noise at idle.
As for the trolley get a double decker trolley it has two compartments for the two batteries and the inverter goes on top. These are available from Sukam for 1400 bucks.
Is the battery price @ 13000 each a typo.
Old 20th April 2010, 17:54   #261
Chipz's Avatar
The humming sound is because of the trickle charging. it is constant, even when the battery is not normally charging.
The exide EL series is one of the best in the market. Can you tell me the full model number.
Old 20th April 2010, 18:47   #262
JPZ
Thanks for the answers.
Each Exide EL6 130+ costed 13K.
I was told the double decker stand cannot hold 2 EL+ batteries in tandem. Going for 2 stands will ruin the aesthetics. I have decided to cover them in a ventilated closet.
Old 20th April 2010, 23:02   #263
ghpk's Avatar
Thanked: 193 Times
Can someone post how much a inverter would cost if you need to run a 1.0 ton or 1.5 ton Air conditioner ?
how many batteries it would need and how long they'll serve the purpose ?
Old 21st April 2010, 00:35   #264
I am also interested in the reply.
WanderNomad is offline   Reply With Quote
Old 21st April 2010, 03:10   #265
ghpk's Avatar
Thanked: 193 Times
seems this wild idea is not widely used,
got this while searching.
5KVA Home UPS/Inverter @ 97,800/-* Run your A.C.
10KVA Home UPS/Inverter @ 1,81,000/-*
Old 21st April 2010, 08:25   #266
Chipz's Avatar
1 ton ac will require about 5 kva inverter. 5 kva inverter can be made to work with 5, 6, or 10 batteries according to your choice. The price of the inverter increases with the number of batteries used since they have to put different transformers. I would prefer you go with 6 batteries. it will have more life. 10 battery is good too, but it will add about another 40000 to the budget. I am talking about 130 ah batteries. so 6 batteries = 10000 x 6 = 60000 plus 30 to 35k for the inverter. total close to 1lac.
If you want to cut the cost, then you can use less Ah batteries. six 80 Ah batteries will cost about 42k, but it means less backup.
These are just approximate values, depends on the brand.
Old 26th April 2010, 07:19   #267
mithun's Avatar
Thanked: 58 Times
What would be the per hour running cost of these Honda Gensets ?
When selecting gensets which is the best option, Petrol/Kerosene ?
Old 26th April 2010, 10:01   #268
lohithrao's Avatar
Thanked: 163 Times
Ok guys i took the plunge and picked the inverter setup..
Compton Greaves 800VA + Okaya 135ah tubular battery + trolley for 16500bucks.
so far so good will keep you guys posted.
lohithrao is offline   Reply With Quote
Old 26th April 2010, 10:32   #269
Thanked: 196 Times
Congrats on buying an inverter. Is this a pure Sine Wave inverter ? can please you give the cost breakup inverter & battery separately ? Thanks
tj123 is offline   Reply With Quote
Old 26th April 2010, 10:52   #270
tanwaramit's Avatar
Thanked: 387 Times
I too am looking for gensets, given the power situation now, I don't expect it to get better in june July. How much capacity genset to be used to run 1.5 ton AC? And can I get the one used to run on LPG as kerosene sourcing is difficult and petrol/ diesel will be costly.
tanwaramit is offline   Reply With Quote
Inverter Batteries Tarun Gadgets, Computers & Software 1283 15th July 2018 22:42
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Myth: UPS can't run on inverter? linuxtechie Gadgets, Computers & Software 17 24th October 2008 15:47
