Old 20th August 2010, 16:14   #361
Thanked: 19 Times
8 hours of power cut everyday forced my wife to force me to buy an inverter.
I bought Luminous Sine Wave inverter 1.4KVA along with Amarraja (Amaron) 90 VA x 2 battery + free installation+wiring+switchboard + free maintenance every 4 months + 2 years warrantee on inverter + 3 years warrantee on batteries + a plastic stand with wheels
Square wave will create "huming" sound from the tubes and fans within few days of use. Sine wave inverter will not have this issue.
I went for 1.4KVA becasue we wanted to run Refregirator and Food Processor apart from home lighting (tubes, CFLs, Fans), TV and PC+ Broadband+wifi router.
I bought this from a dealer who has office near ISKON, Installation was done within in the same day. I ordered it at 12 noon, installation was over by 9 PM.
If anyone needs contact details please send me a PM.
now we have two happy people (at home) plus one with some more reduced bank balance ( and he is writing this post)
StarVegabond is offline   Reply With Quote
Old 20th August 2010, 17:45   #362
Chipz's Avatar
Originally Posted by mkh View Post
Buying a sinewave inverter is better than the square wave.
ya the sinewave is always better than a square wave, square wave will not have humming sound with electronic choke, but with the ballast it has some noise. Fans too have some humming sound with it, and it is said that square wave harms the electronic regulator of a fan (though i have not seen one yet).
However the best brand apparently is APC and they currently do not have a sine wave model
Did you find this information in APC website . Luminous, Su-kam, Microtek, APC, are all good brands, but check which brand has service access to your area, that makes the difference. Also check out the home UPS model, that way you wont need a UPS for your computer.
Amaron battery is better than others, but even exide is great. I guess buying a tubular battery is recommended for sure?
Tubular is the king for inverters. In my opinion no one can beat exide in tubular. Check out their EL series. They have 4 and 5 years guarantee.
Looking at a 800 VA model, current owners/experts please help
If you have time go through this whole thread. Hope this helps.
Chipz is offline   Reply With Quote
Old 20th August 2010, 18:44   #363
mkh
Thanked: 107 Times
no did not get the info from APC, just heard around that's all. One thing is established, need a sine wave inverter. Battery- even SMF are good as they are maintenance free? Amaron makes SMF which are good i guess? Will check out Exide also as that too have heard is equally good.
I think 800 VA is good for me as plan to run lights, laptop maybe and maybe a DVD player with Flat Panel screen and no computer (PC)
Anyone has dealers around CV Raman Nagar, Indiranagar who are good?
mkh is offline   Reply With Quote
Old 21st August 2010, 13:19   #364
mkh
Thanked: 107 Times
Got a few quotes,
Seems like a combination of Sine Wave 800 VA with Tubular Battery( exide) will cost around 18,500 with trolley. Not sure if this is an ok price?
Cost is lower with Amaron Battery that is semi tubular. I thought it would be easier than its turning out to!
Old 21st August 2010, 18:23   #365
Chipz's Avatar
What is the model of the exide you are getting. the price depends on the model and the battery ampere. Semitubular always cost less than tubular. Better buy the tubular, you wont regret it.
Old 21st August 2010, 22:39   #366
anku94's Avatar
Thanked: 33 Times
Got a few quotes,
We got our Su-Kam sine wave (Falcon, was it ?) and a Su-Kam 800VA battery for ~14k. 11k after exchanging the old battery and inverter. Backup power lasts a lifetime (It has to, if you have to survive the Punjab summers and power supply).
BTW, what're the pros of a tubular/semi-tubular over the traditional design ? Googling returned surprisingly low number of relevant results on this one.
anku94 is offline   Reply With Quote
Old 22nd August 2010, 18:35   #367
Chipz's Avatar
@anku: How much Ah is the battery. You stated 800 va, it is for the inverter.
Check this thread for your battery related query
http://www.team-bhp.com/forum/gadget...batteries.html (Inverter Batteries)
Old 22nd August 2010, 23:47   #368
anku94's Avatar
Thanked: 33 Times
Oh, my bad. The battery is 165 Ah if I remember correctly.
Old 23rd August 2010, 14:00   #369
Prowler's Avatar
Thanked: 286 Times
My 3 KVA UPS batteries conked off on friday. They are Prestolite 88 AH x 4 batteries. I had replaced them with Amaron 80 AH Hi-Way batteries. It cost me Rs.18,800 after deducting Rs.1000/- per old battery. I can see from the warranty card that these new batteries are actually automobile batteries.
Automotive batteries are not designed for deep discharge usage. The previous batch lasted about 4 years. What is the view of the gurus about using automotive batteries for the UPS ?
Prowler is offline   Reply With Quote
Old 23rd August 2010, 14:17   #370
mkh
Thanked: 107 Times
Well the dealers here are discouraging buying Exide. They say support is bad etc, got this from 3 dealers now. I got a quote for exide battery from one of them he told me model name- 1500+ IN with 2 years warranty but not the EL series, but the 6EL is costing 17K for the battery only and gives 4 years warranty
Can you suggest some good models?
Apart from exide any other decent brands? Got a couple of quotes for Prestolite battery with inverter for about 14-15K
Looks like may have to go for a non exide battery but dunno which is the next best in tubular( prestolite, micron?) Most dealers are moving away from exide due to the bad support they are giving off late.
Old 8th December 2010, 22:38   #371
xingamazon's Avatar
Thanked: 110 Times
Default Re: Inverter or generator?
Today I got quotes from local inverter seller, he says follwing quotes which also includes wiring:
100 ah = INR 11500
135 ah = INR 13500
150 ah = INR 14500
The battery he provides is SF sonic, 600 va. He says there is no brand by name Exide, and all exides come in the brand SF now, is that true.
Let me know if the price he has quoted is good enough.
xingamazon is offline   Reply With Quote
Old 9th December 2010, 09:49   #372
Gansan's Avatar
Thanked: 883 Times
100 ah = INR 11500
135 ah = INR 13500
150 ah = INR 14500
What brand is this? I paid ~ Rs 12500 for 150AH three years ago (Usha Zentra).
Old 9th December 2010, 14:33   #373
xingamazon's Avatar
Thanked: 110 Times
Thanks for the help.
I am planning to buy Microtek or Everest both are available for same price. He mentioned other few brands which I had not heard of, so I ignored them.
The price that you mentioned does that include installation/ wiring charges.?
Old 9th December 2010, 15:32   #374
Gansan's Avatar
Thanked: 883 Times
I think I paid Rs 500.00 for that. I wanted some fancy footwork from the installer - I wanted specific points at specific rooms (3 bed, 1 hall,1 dining, 1 kitchen and 3 bathrooms) to be connected to inverter, while excluding others.
I also paid Rs 900.00 for a stylish Usha Zentra trolley which conceals the battery and houses the inverter on top, and we can move it about while cleaning the room. I bought the whole set-up from Ratna Fan House, Pondy bazar.
At that time home UPS were not available but they are now. Check them out. Also, please remember that irrespective of what people tell you, the average life of the battery will be ~ 2.5 years. Avoid dry type / maintenance free (Korean) batteries and opt for normal type, preferably Amaron shield. Avoid the temptation of housing the set-up on some loft, as maintenace of battery will become cumbersome. I maintain the battery myself.
Old 9th December 2010, 17:51   #375
xingamazon's Avatar
Thanked: 110 Times
Hi Gansan,
Thanks for the pieces of advise.
Are the Exide SF Sonic batteries that type that you mentioned, I mean (dry type / maintenance free). Or are you meaning what people call as Tubular battery?
Is yours also 6oo vh? what is the battery make that you have is that Exide?
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Inverter Batteries Tarun Gadgets, Computers & Software 1143 12th January 2018 11:02
Myth: UPS can't run on inverter? linuxtechie Gadgets, Computers & Software 17 24th October 2008 15:47
