Old 12th August 2015, 22:50   #676
Thad E Ginathom's Avatar
Thanked: 7,467 Times
Default Re: Inverter or generator?
Smaller generators usually run on petrol or kerosene, their life is quite short and the fuel cost very high, so in the end they are not worth the investment.
How short is short, there?
Old 12th August 2015, 22:57   #677
ortho_surgeon's Avatar
Thanked: 66 Times
Honda EU 30is key start costs ₹97 and the kick start costs ₹80.
The EU 65is costs ₹1.8.
AMF panel costs ₹30-35 for upto 10kv
ortho_surgeon is offline   Reply With Quote
Old 13th August 2015, 03:41   #678
Feeling my way in the dark here...
I need to be able to run a pump for draining the garden during storm-time power cuts. Currently we have only 0.5hp, but will probably upgrade to 1 or 2hp.
It would be nice to have something that, rather than stand idle for the rest of the year, could run an AC or two during the summer months.
I get, so far, that diesel would be better than kerosene or petrol. What should I be thinking next?
Old 13th August 2015, 09:34   #679
Thanked: 252 Times
Where does the garden drain to? If it is a point lower than the garden it would be better to get drainage plumbing laid out. Maybe even including a means to siphon the water out without using any power at all except perhaps to start the siphon.
anupmathur is online now   Reply With Quote
Old 13th August 2015, 10:29   #680
Thanked: 1,011 Times
Approximately 1/5 that of diesel, and rebuild rarely available. Diesel generators are generally built for sustained running and long life. With proper care and maintenance a diesel generator will run for at least 30 years or more.
Old 13th August 2015, 13:01   #681
Thanks Aroy: that is really a substantial difference, and suggests that the lower prices are for a throw-away product.
There are a number of places in Chennai where, due to non-removal of existing surface, houses have found themselves below the road level. It happened to us in one go. By what mad reasoning the authorities decide to add a couple of feet to road levels I do not know, but they did. Initially, even our septic tank was filling from the outside drain until we had it's overflow raised and fitted with a valve. We also have to close the drain outlet when it rains, or else it becomes an inlet: better we have a garden full of rain rather than everybody else's drain water, which probably includes sewage.
In normal circumstances, our household water will drain to the outside, but when it rains heavily, the garden (protected from inflow from the road by a hump) just becomes a tank. So far, the house itself remains a few inches above serious threat, but I would be much more comfortable if I knew I could pump out the water almost as fast as it fills.
Old 13th August 2015, 13:16   #682
Prowler's Avatar
Thanked: 286 Times
In normal circumstances, our household water will drain to the outside, but when it rains heavily, the garden (protected from inflow from the road by a hump) just becomes a tank. ...but I would be much more comfortable if I knew I could pump out the water almost as fast as it fills.
Sometimes it might be easier to look for simple solutions.
I have the same problem. I suppose you are talking about an independent house. What I suggest is build a rain water harvesting thing which will take care of all the rain water issuing forth from your house. It is a one time cost.
As for the roads, the corporation is building such things in my area - every few hundred feet. As usual they have dug up pits for now. They will build the rain water harvesting contraption after a few weeks. So until that time, we have to become a monk - for not using bad languages in trying to avoid these pits.
Prowler is offline   Reply With Quote
Old 13th August 2015, 14:14   #683
We have a rainwater harvesting pit. We also have flooded plots (and a canal) nearby, and there is water just a couple of feet below ground level. Even without that situation, it would not be a solution to draining water quickly, eg emptying nearly 2000 sq ft * 3-6 inches within an hour or so.
Old 13th August 2015, 14:25   #684
Thanked: 252 Times
.... eg emptying nearly 2000 sq ft * 3-6 inches within an hour or so.
Ha ha, we're looking at about 30 tons of water to be drained in an hour!
Nothing short of an industrial centrifugal pump will achieve those numbers.
Old 13th August 2015, 15:04   #685
Yes I have seen Aurobindo Marg in Delhi raise itself by nearly a meter in 40 years. Unless corporations go in for the new technology, where the road is cut to a predefined depth, material recycled and a new pavement laid at the same level, your only recourse is to reconstruct the house, this time at least 4 feet above the road level. Better still; as is now mandatory in Delhi; with the ground floor on stilts for parking.
This is invetiable, as the road will keep rising, water table along with it and soon your house will require expensive water proofing and "Flood Control" treatments every few years.
Best of luck.
Old 15th August 2015, 17:08   #686
Thanks. We cannot possibly afford to rebuild our house, so we will need the luck, the pump ...and the generator.
Does anyone have any comments on the different brands of diesel gensets, the smaller ones, ie 5Kva or slightly more? Even better, does anyone know a good dealer in Chennai who can advise as well as sell?
(Ultimately, I am guessing that as we get older and poorer, and our area becomes more desirable, some sort of redevelopment deal might be appropriate to fund the rest of our lives, but we will sacrifice our 2,000sq ft of garden with tears.)
Old 15th August 2015, 21:19   #687
Gansan's Avatar
Thanked: 883 Times
Why not just get a portable diesel pump set and be done with it? Like this, for example:
http://www.usha.com/agri-business
Old 15th August 2015, 22:19   #688
That's what we were thinking. The trouble with ideas is that they tend to grow, in size, scope and cost!
Old 16th August 2015, 14:10   #689
Prowler's Avatar
Thanked: 286 Times
I can feel the pain. I have about the same size 'garden' with a few fruit bearing trees. I have had no issues with dogs and cats as I own the premises. This kind of 'freedom' is unthinkable if I go for redevelopment.
Old 26th August 2015, 14:42   #690
Owning the place stops problems with dogs and cats? Not for us! We have the cats that move in, and the cats that want to, including one which, currently, attempts to eject the incumbent with extreme violence!
But we do not have any upstairs or downstairs neighbours with loud televisions etc. Nor does anybody else park in my car-parking space!
Of course, there are neighbours (actually, we are lucky: not too noisy) --- but it is always so much worse when they are only a wall or a ceiling away.
But, in the end, we did go for a portable pump, spending only 14k on a petrol/kerosene pump. Maybe that is not the nest possible buy, but it may (hopefully!) only be used a few times a year.
It took us a while to get the thing set up for working. We had to replace the supplied foot valve and learn how to prime it properly before we got it gushing. It's only been used for test so far, because, although it was forcecasts of possible torrential rain that got us running to the shop, there has actually been almost no rain since the day we bought it.
So, Chennai will be cursing us for stopping the much-needed rainfall!
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Inverter Batteries Tarun Gadgets, Computers & Software 1143 12th January 2018 11:02
Myth: UPS can't run on inverter? linuxtechie Gadgets, Computers & Software 17 24th October 2008 15:47
