Old 7th January 2013, 23:32   #3406
diyguy's Avatar
Thanked: 123 Times
Howz it? Could you please let me know the model number? Also, are the strips easily available in india? What is the approx. cost for say, 100 strips?
http://m.healthkart.com/mobile/produ...tReferrerId=14
This is the one. Strips freely available. Check a few sites, think saw this on rediff for 1400 or so.
diyguy is offline   Reply With Quote
Old 9th January 2013, 08:41   #3407
ramki067's Avatar
Thanked: 25 Times
Default Re: The Home Appliance thread
One basic question regarding Godrej Fridge Eon model two door(upper and lower). In the upper compartment which is a freezer, ice is formed and it is sticking to the compartment sides. Is this an issue as i haven't seen ice formation till now(in freezer) after we brought the fridge 4 years back.
Also, i have set the adjust knob to "Normal". The knob also has Ref Max and Max Freeze as other options to set.
Thanks,
Ramki
ramki067 is offline   Reply With Quote
Old 9th January 2013, 09:12   #3408
sgiitk's Avatar
Thanked: 3,792 Times
Infractions: 0/1 (5)
Looks like the drain bit is clogged. The best solution is the allow the unit to warm up.
Old 9th January 2013, 09:25   #3409
ramki067's Avatar
Thanked: 25 Times
Sorry for not including that my fridge is Frost free. And how do i do the warm up?
Thanks,
Ramki
Old 9th January 2013, 09:27   #3410
Thanked: 282 Times
Thanks,
Ramki
I also also frosting problems. There are a couple of reasons for this - seals getting spoilt or the door alignment going bad.
http://www.team-bhp.com/forum/gadget...ml#post2928157 (The Home Appliance thread)
http://www.team-bhp.com/forum/gadget...ml#post2933201 (The Home Appliance thread)
carboy is offline   Reply With Quote
Old 9th January 2013, 10:17   #3411
ramki067's Avatar
Thanked: 25 Times
Thanks carboy. Will surely check for any rubber worn out issue or else will call the technician to check on vertical play.
Thanks very much.
Ramki
Old 9th January 2013, 11:12   #3412
khoj's Avatar
Thanked: 1,253 Times
The bimetallic timer switch that controls the defrosting heater seems to have gone kaput. The Godrej technician should be able to provide a replacement easily.
Thanks,
Ramki
Old 9th January 2013, 13:33   #3413
ramki067's Avatar
Thanked: 25 Times
Thanks Khoj.
Will call the technician this weekend and check with him of the issue. If its indeed the switch, any idea on how much it costs?
Thanks very much.
Cheers,
Ramki
Old 9th January 2013, 13:56   #3414
sgiitk's Avatar
I assumed a Frost Free. Here the FF design relies on cold air being cleaned up before circulating. This is removed by periodically warming up the evaporator coils. But if the system gets overloaded then the drain chokes, and you have to allow the system to warm up - switch off and use a hair dryer if required. Also, a fe trays of hot water in the compartment can help. I had this problem in my LG 4xx litre frost free after we left the freezer door ajar overnight, and this is exactly what I did. Of course the tier / heater switch can also be kaput.
Old 9th January 2013, 14:51   #3415
Thad E Ginathom's Avatar
Thanked: 7,452 Times
This is the way to test for fridge-door seals that look all-right but aren't!
Take a slip of paper, several inches long and an inch or so wide. Shut the fridge door on it, and make sure you can feel resistance when pulling the paper out. Try this all the way round: you will find the place where the seal is deficient. Where the seal is not gripping, it is also not sealing.
It may not be the seal. Continued use over years can put the door slightly out of shape. Engineers have a shove-and-push with knee and hand technique ...but they also have practice, so it may not be the thing to try DIY.
Old 10th January 2013, 11:36   #3416
ramki067's Avatar
Thanked: 25 Times
Thanks guys. Will check the paper technique.
However, wanted to inform that our freezer compartment is fully loaded all the time with flours.
Old 10th January 2013, 19:03   #3417
Thanked: 1,011 Times
You need some space for the air to circulate in a frost free freezer. So I would suggest that you keep the freezer only 3/4 full.
Old 12th January 2013, 13:44   #3418
Thanked: 187 Times
Symptoms - Heavy ice formation in my direct cool LG fridge's freezer even though thermostat is set to less than MIN. Also irritating rattling noise once compressor begins functioning.
Solution proposed by a repair walla - change the thermostat. cost - 950/-
Is he taking me for a ride?
WindRide is offline   Reply With Quote
Old 12th January 2013, 22:07   #3419
condor's Avatar
Thanked: 4,413 Times
Am planning on going for a Siemens or Bosch dishwasher. Both are pretty much identical.
I have an LG dishwasher bought three months ago for about 28k.
SG sir & Viddy, could you give the model numbers of the one that you got ?
And any such problems:
Originally Posted by diyguy View Post
I got a Samsung dishwasher .. Tea vessels and milk boiled ones won't get entirely done. You have to clean the spray arms and filter regularly. Use lesser powder than recommended.
Old 12th January 2013, 22:34   #3420
diyguy's Avatar
Thanked: 123 Times
We are very happy with the Samsung dishwasher. I would be very surprised if the other models don't have the same issue as the Samsung. I've used ones in the US too and burnt vessels and tea ones will have to be done manually.
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
