Old 29th November 2013, 16:12   #4051
HillMan's Avatar
Thanked: 401 Times
Default Re: The Home Appliance thread
Kent water softner is a good option for washing machine. However, I'll recommend to use frond loading / low sud detergent for the wash. Froth from regular washing machine might seep into various parts doing more damage than good.
HillMan is offline   Reply With Quote
Old 29th November 2013, 16:56   #4052
saket77's Avatar
Thanked: 4,800 Times
That is what the normal logical insight is. But have been using normal detergents for at least 10 years now. The machine has never broken down, except for once when it was transported without putting on the transit bolts which damaged the motor!
Can any person who knows the front loaders inside out comment on this aspect?
saket77 is offline   Reply With Quote
Old 29th November 2013, 17:35   #4053
HillMan's Avatar
Thanked: 401 Times
I was using regular detergents few years ago when front loading powders were not so freely available at the neighboring shops.
The froth overflow finds every possible escape routes out of the machine. The situation is aggravated when heating is On. Also heavy wash cycles were to be avoided. The powder also creates a sticky layer on the machine drum in combination with hard water.
I have a tumble top machine (Kenstar) which has the drum opening on the top. In case of regular detergent, one can notice bubbles on the outer drum. Which is an indication that the detergent did not clear out fully during rinse cycles. Although it did not adversely impact the working of the machine as the electrical and motor is well guarded.
The low sud powders dissolve easily with water and clear out of the machine.
Old 29th November 2013, 17:47   #4054
Thad E Ginathom's Avatar
Thanked: 8,188 Times
It all depends on how hard the water is. If it tastes mildly salty, then a better detergent will be all that is required. If it tastes quite salty then just detergent may not do.
I think that hardness and saltiness is different. Hardness is calcium salts. I lived most of my life in a very-hard-water area (London) but there was never a trace of salt taste in the water.
If water has become contaminated with salt, though, it is certainly not good for the wash.
Old 30th November 2013, 17:01   #4055
lurker's Avatar
Thanked: 646 Times
Originally Posted by lurker View Post
Have had no issues with my Panasonic Refrigerator as well, it had 5 star energy rating and was priced very competitively for it's class. A 340 ltr refrigerator will have a PCB for auto-defrost etc, so just ensure that you have a voltage stabilizer as well. The only thing that can go wrong with auto-defrost models is the circuit board, so if possible get a spare one and store it in someplace really dry and weather-proof. That should make it 'future-proof'.
an update: The Pana refrigerator was not an auto defrost model, and yesterday while chipping away the resistant ice from the freezer, managed to poke a hole in the evaporator coil. A loud hissing sound was followed by a white cloud, which means the refrigerant has leaked and escaped from the closed loop, sealed system. Now this silly mistake on a non-autodefrost model usually means replacement of the entire fridge itself because the it isn't possible to solder the thin aluminium tubing inside the plastic insulation as found in cheaper model 190+ltr refrigerators and then recharge the gas to expect the system to not have any leaks, atleast sometime down the line, say in a month or two.
Enter the Panasonic service dude, who has promised to replace the whole freezer box itself since it is a base model refrigerator, the parts are easily available. And then recharge the gas. Total damages should be in tune of 3k or thereabouts. Service charge of Rs. 1600 will follow if I do not have physical possession of the warranty card and bill. At the moment searching for the same somewhere. But atleast the thing is repairable.
And guys moral of the story is please beware and do not poke the insides of the freezer with sharp objects to remove ice. The entire freezer area is enveloped with coils that has very thin plastic insulation and thus are not visible but even a slight poke at these ultra-sensitive areas can land one up in a lot of bother and totally unnecessary hassle.
lurker is offline   Reply With Quote
Old 1st December 2013, 00:03   #4056
So I have always been told --- and now I know from someone who learned the hard way.
Glad you could get the repair. Good for Panasonic
Old 1st December 2013, 09:08   #4057
Thanked: 43 Times
The froth overflow finds every possible escape routes out of the machine. The situation is aggravated when heating is On......
If ever you need to use normal detergent in a front-loader, try this simple trick. Put about half teaspoon of glycerin or laundry softener with the detergent. It kills the excess suds and ensures a trouble free wash.
filcord is offline   Reply With Quote
Old 1st December 2013, 12:23   #4058
Thanked: 1,046 Times
I did the same think over 40 years ago. My friendly neighborhood mechanic fixed the hole with Araldite and it worked fine. Sold it after six years. Yes do not poke to get rid of the ice. Here is what we did with older type refrigerators
. Switch the machine off.
. Open the door.
. Clear the refrigerator of every thing. This was the time when it was cleaned.
. After an hour or so the ice would start melting.
. If you want to pry the ice, use a flat spatula, no knives or sharp edges.
. Once the ice melts dry up every thing
Old 1st December 2013, 13:00   #4059
NB: do not ever use fabric softener on your microfibre cloths. It will turn them into ordinary rags
Old 1st December 2013, 14:37   #4060
sagarpadaki's Avatar
Thanked: 1,319 Times
The safest way to remove ice,however hard or big ,is to use water. Pour or splash water over the frozen ice and watch it melt magically. You can easily remove the way ice once you have splashed water on it. Of course, you should have something underneath to collect the water.
Old 1st December 2013, 21:17   #4061
DerAlte's Avatar
Thanked: 2,879 Times
The safest way to remove ice,however hard or big ,is to use water. ...
Alcohol works better or anti-freeze. In all regions where temperature remains below 0 for extended time, people used a squirt bottle with alcohol or anti-freeze to open car door locks (before electrical remote locking came in).
Old 1st December 2013, 21:31   #4062
coolclouds's Avatar
Thanked: 514 Times
I am looking for a front loading washing machine for Bangalore. I have shortlisted some IFB and Samsung models. Any pros and cons about these brands?
Kindly help
coolclouds is offline   Reply With Quote
Old 1st December 2013, 21:34   #4063
HillMan's Avatar
Thanked: 401 Times
Alcohol is fine when there is risk of damaging electrical or rusting from water. Like in car. That's because alcohol drys out much faster than water.
The basic idea is to transfer the heat to ice for it to melt. Refrigerators are designed with high moisture in mind. So it's ok to use warm, not hot, water to melt ice. The are drain channels designed for excess water.
Old 2nd December 2013, 11:07   #4064
Kindly help
I would avoid both the brands. In today's market LG direct drive has the best price and most of the models with direct drive motor have 10 years warranty, some thing not available with other manufacturers.
Old 2nd December 2013, 13:52   #4065
HillMan's Avatar
Thanked: 401 Times
The LG warranty is only on Motor. These seldom fail.
Kindly help
These are expensive equipments that should service us for at least 10years. I'll go with IFB for their reliability and availability of spare parts in long run.
I've had bad experiences with every Samsung products, so my opinion could be biased.
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 764 26th April 2018 11:37
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
