Old 21st February 2014, 15:35   #4246
Thad E Ginathom's Avatar
Thanked: 7,460 Times
Default Re: The Home Appliance thread
Originally Posted by Arch-Angel View Post
... I love nurturing the mosquito-sadist in me.
India, thought of by so many foreigners as the land of spirituality and peace, has turned me into a mass murderer! I used to be the sort of person that would carefully rescue one insect from the house, but have become responsible for deaths of thousands of ants, termites, mosquitoes, etc.
My racket is always within arm's reach. it is particularly satisfying when one waves it where one thinks there might be a mosquito, and sees the flash.
Old 21st February 2014, 18:47   #4247
JMaruru's Avatar
Thanked: 103 Times
Question Re: The Home Appliance thread
These days the solar heater(solarizer, 200 liters SS Model) which is of 2007 make, is not retaining the heat. We get hot water around afternoon, but early morning it is luke warm. So the solar heater is NOT able to retain the heat, overnight. Are there any work around to retain the heat? Please advise.
JMaruru is offline   Reply With Quote
Old 21st February 2014, 18:54   #4248
Akhilash95's Avatar
Thanked: 61 Times
Get the coil or rod like thing inside the solar heater changed as it get accumulated with salts even if it's slightly hard water overtime. We change it every year.
Akhilash95 is offline   Reply With Quote
Old 22nd February 2014, 12:36   #4249
JMaruru's Avatar
Thanked: 103 Times
Thumbs up Re: The Home Appliance thread
This is news for me. I thought solar heaters would NOT have the regular heater coils inside them. Even i was not told about the same during the annual service checkups. Anyways, thanks for the info!
Old 22nd February 2014, 15:17   #4250
They may be an option. We have one, but never even fitted it.
Our solar water heater has a 250ltr tank: I'd rather heat a couple of pans on the stove than attempt to heat that electrically just to use a few litres washing!
Solar heater warning: should have a sacrificial anode. Watch out for this and replace regularly. Ours was never replaced, and the result is that the life of the unit is severely compromised. Complaining gets one nowhere: the best they would do is a small discount on a new unit, which is a major investment. I'd rather not give them more money: when the leaks get too bad, we'll buy off someone else!
Old 23rd February 2014, 14:30   #4251
Thanked: 1,011 Times
Check the insulation of the holding tank. With age the insulation may have got clumped or there may be water leakage which murders the insulation.
Aroy is online now   Reply With Quote
Old 24th February 2014, 16:25   #4252
Thanked: 9 Times
My OTG has started giving problems. Whenever I switch it on, it works for some time, maybe 5 minutes, then the mains MCB gets tripped. Any idea what could be the problem? If there was a short inside, then the MCB should have tripped immediately after switching on. Is it possible that one of the heater coils has got damaged? How to rectify the problem? I am connecting it to the regular 15A outlet and I also checked rating of the MCB. Anyways, it was working fine earlier at the same outlet.
SachinVD is offline   Reply With Quote
Old 24th February 2014, 18:01   #4253
Thanked: 424 Times
Am assuming OTG = Geyser. If yes, then you need to change the heating coil/+ thermostat. I had to do the same recently and the symptoms were similar. Its fairly a simple DIY (if you ask me ) The coils & thermostat are easily available in the nearby hardware shops.
vinjosep is offline   Reply With Quote
Old 24th February 2014, 19:34   #4254
t18
t18's Avatar
Thanked: 33 Times
OTG = Oven, Toaster and Griller.
t18 is offline   Reply With Quote
Old 24th February 2014, 20:47   #4255
There is a short some where, it may be in the wiring or in the element itself.
. Open it up and check all the wires. In case some are frayed or the insulation has crumbled change the wire.
. In case all the wires are fine, then check the thermostat. If it is dirty then it may be shorting when engaged, clean it.
. If every thing is fine then the element is shorting. Change it.
Old 25th February 2014, 02:04   #4256
Cedia2013's Avatar
Thanked: 15 Times
Default Best Washing Machine-Input your guides!
People, I thought I could just buy a washing machine with a little bit of searching and reviews, but then, I got really confused. With multiple brands and technologies, I couldn't make out a decision. So I thought, I would better seek the help of my fellow BHPians and choose the best machine for my home.
Here are my needs based on what I read and understood so far:
1. I need a fully automatic machine.
2. Capacity can be as low as 5 kg as mine is nuclear family. (but there is going to be a kid coming up so I would require hot water washing)
3. Automatic water drain
4. Front loading.
Additional requirements (absence of these features wont change my buying option)
1. Child lock
2. Less water consumption (I have a good water supple but its hard water)
3. Automatic restart (like, after a power failure)
4. Ability to add clothes Mid cycle.
So based on my requirements I have shortlisted these:
1) IFB 6 Kg Elena Aqua front load
3) LG 5.5Kg F8091MDL2 Front load
3) Samsung Front load 6.5 Kg WF1650NCW/TL
Can you suggest what brand to choose? Instead of a low end front load, will a good quality top load machine work better? Kindly post your real experience if any, and help me choose a best brand. My main need is a long lasting machine ultimately with no compromise in quality. My budget is not more than 26k.
Cedia2013 is offline   Reply With Quote
Old 25th February 2014, 11:08   #4257
Thanked: 58 Times
Look for LG With inverter motor. I have 8kg with dryer. Saves power and it will serve your requirements. IFB service is bad these days LG is good on that.
sam003 is offline   Reply With Quote
Old 25th February 2014, 11:49   #4258
ramki067's Avatar
Thanked: 25 Times
Guys,
Looking to buy a 42" LED TV. Liked LG 42LN5400.
My requirements are good picture quality from all angles as we have sofas all around. True colors, value for money, good life of TV, more features than other TVs.
My view distance is from 10 to 11 feet.
Is my selection good enough, or is there any other brand TV better than this model?
Thanks,
Ramki
ramki067 is online now   Reply With Quote
Old 25th February 2014, 12:17   #4259
saket77's Avatar
Thanked: 4,598 Times
Default Re: Best Washing Machine-Input your guides!
Find out about the service standard of IFB at your place. It would be better if any friend/ relative of yours have an IFB appliance. They will be in the best position to tell you about service. If the service is good, go for IFB. The products are really good & reliable.
I would prefer it over the Koreans.
saket77 is offline   Reply With Quote
Old 25th February 2014, 13:08   #4260
theexperthand's Avatar
Thanked: 1,142 Times
Guys, I am in the market for buying a water purifier - but really confused with all the brands.
What all parameters should I look for when I choose the water purifier?
I am from Bangalore and the water is hard water.
Anoop
theexperthand is offline   Reply With Quote
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
