Old 10th March 2014, 15:39   #4291
Thanked: 33 Times
Default Re: The Home Appliance thread
We use the vacuum cleaner (eureka fobes dry-wet model) 3-4 times a year. Primary usage:- Cleaning mosquito mesh, cleaning cobwebs, cleaning fans, cleaning pillows and mattresses. Its tough to justify the high costs, but I see no alternative to achieve the above stated goals in a better way.
amohit is offline   Reply With Quote
Old 11th March 2014, 11:13   #4292
theexperthand's Avatar
Thanked: 1,140 Times
Originally Posted by arsudarsan View Post
We have a Eureka Forbes trendy steel for 4 years,
to vacum all the stuff and dispose.
Thank you guys. I know the use will be limited but at times, we do really need one - to clean the French window mosquito mesh, clean the window rails, clean those hard to reach areas etc.
So, gave in to the temptation and ordered the Panasonic MC-CG303 from Amazon.in and opted for the next day delivery. Hope this will serve my purpose.
--Anoop
theexperthand is offline   Reply With Quote
Old 11th March 2014, 15:18   #4293
Thad E Ginathom's Avatar
Thanked: 7,451 Times
Default New Digital EB Meter.
Not getting around to things can sometimes be good.
Some time ago, I got a bad shock from the case of our EB meter. The local engineer said it should be replaced, we had to write to this officer, that officer, waiting list (of course there was an alternative to the waiting list ) etc etc etc. We didn't get around to it.
Yesterday, an EB man just turned up at our house with a new meter, part of the scheme now in effect to replace all the old mechanical meters, which I had read about but didn't think would actually happen.
So, we have a new meter. Apart from not trying to kill me if I accidentally touch it, it also has a button that cycles through heaps of different readouts. Some I think I can intuit --- but does anyone have the manual, or reference, or simply enough electrical engineering knowledge to list out what is being displayed, please? It is a Secure Swift 350.
Old 11th March 2014, 17:44   #4294
sgiitk's Avatar
Thanked: 3,791 Times
Infractions: 0/1 (5)
@Thad; I have the manual of some Secure unit with me. I will try and fist it out. The sequence may be different but all info should be there. Can you PM me your id, so that I can scan and mail you a copy. I think I know where it should be.
Old 11th March 2014, 19:13   #4295
That's very kind. PM about to be on its way
Old 11th March 2014, 19:50   #4296
naveenroy's Avatar
Thanked: 697 Times
Guys, planning to get a Faber baffle chimney. They say that it costs 500 just for installation and any parts will be charged extra. Any idea how much it costs finally for fitting and installation?
naveenroy is offline   Reply With Quote
Old 11th March 2014, 20:18   #4297
Thanked: 33 Times
I did it on my own for my house. Main challenge was getting the hole done in the wall.
Additional cost will include doing the hole in the wall (if needed). Doing this with a drill will cost around 1000. Cost of 4inch plastic pipe (3ft costed 100 Rs). If your requirement is to have longer duct (which is going to be visible), you may want to go for aluminium pipe (looks good, otherwise no additional benefit over plastic pipe). No idea about the cost of this pipe.
Old 11th March 2014, 20:38   #4298
naveenroy's Avatar
Thanked: 697 Times
Thankfully, there is a hole for the chimney duct. Also, I think it is better to go for the aluminium pipe from a safety perspective. Don't think it is a good idea to have plastic and hot exhaust mix :(
Old 12th March 2014, 08:27   #4299
rjstyles69's Avatar
Thanked: 791 Times
Ensure you ask them to make use of industrial grade aluminium pipe for the exhaust. Usually dealers try and push cheaper stuff to prospective buyers.
Old 12th March 2014, 10:01   #4300
sgiitk's Avatar
If it is a recirc type then it just involves fixing four screws to the wall. The template is provided. I did my own in 2001 when Faber were not in Kanpur. When I replaced a year ago, the same screws worked!
Old 12th March 2014, 11:09   #4301
Check with them how much do they charge for the aluminium pipe per ft and the cost for the end cap. I recently installed an Elica chimney - the installation was 400, aluminium pipe rate was 50 rs per ft and I paid 150 rs for a plastic end cap and making the hole bigger for routing the pipe (the hole was small and the guy had to remove the plastic pipe and make a bigger hole, plus he had to use multiple clamps to fix the pipe since the length was around 16 ft).
Not sure about Faber but usually Elica gives 10 ft pipe for free if you bargain when you buy the chimney.
--Anoop
Old 12th March 2014, 14:51   #4302
naveenroy's Avatar
Thanked: 697 Times
Thanks for the updates!
Ok, need to check that - I have seen them use the aluminium pipe at a friend's house.
No, this is the one with a duct. Only problem is the drill - don't own one.
--Anoop
Ok, need to check how much they can provide me for free. And end cap - can you explain? Is that something fitted on so that nothing can get from the outlet?
Old 12th March 2014, 15:30   #4303
Yes - it is a simple plastic cap they put at the end of the aluminium pipe so that small birds or debris cant enter the pipe from outside.
Also, do bargain on the rate for pipe also - I got varying quotes from 100 rs per ft to 50 rs per ft from different outlets.
--Anoop
Old 14th March 2014, 15:36   #4304
Any one using Usha 5 Star Technix Ceiling Fan, I am not getting any reviews from net.
satran is offline   Reply With Quote
Old 18th March 2014, 12:18   #4305
sgiitk's Avatar
Default Bulb adapters, anyone
I was at a holikdahan celebration nd was cribbing about the need to keep bulbs/cfls in three sizes - bayonet, small screw and big screw. Someone stated that adapters for putting the small screw bulb into a bayonet holder are now available. Availability and price!
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
