Old 13th July 2009, 22:22   #421
Thad E Ginathom's Avatar
Thanked: 7,457 Times
despite having decided not to buy Samsung AC again, I've just bought a Samsung LCD Monitor.
I spend a lot of my life, one way or another, in front of this screen, and had longer-term ambitions for something rather upmarket to look at, however, the sudden total failure of my old NEC CRT 17" made a same-day buy necessary and I bought a Samsung T220 at Rs13,250. For two days it gave me a headache, but now my eyes and brains have adjusted and we get on much better with the thing. I is nice having so much more screen!
Old 10th August 2009, 11:21   #422
lurker's Avatar
Thanked: 641 Times
I have a problem with my LG 240l frost free refrigerator. And even the LG service personnel who are prompt to turn up at any complaint are not able to diagnose the problem.
the problem is once in a week, the fridge turns off all of a sudden. The compressor stops working for a long stretch of 6-8 hrs sometimes 12 hrs together. Everything inside the fridge spoils, except what is in the freezer, because items in there are kept at cooler temps than the rest, nothing else.
the service personnel tells me that they have been given a 4-point check instruction wrt fridges. One they check the timer, two they check the relay, three the compressor and four the coil. They say since the fridge is cooling well and there is no excess formation of ice around the coils when it is working all the four checks are satisfied (and when the technician comes, the fridge does indeed work well)lol.
they have also suggested problem with the voltage or the point at which the fridge is connected. I have changed the points and know for certain that voltage is satisfactory since I have a three phase connection and normal mains voltage is brighter than my inverter output which is 230-240v.
the problem of cut-off for long hours happen during the night time or during early day time at which hours the technician is unreachable. I am at my wits end now since it is again happened for the umpteenth time. What could be the problem ?
lurker is offline   Reply With Quote
Old 10th August 2009, 14:12   #423
lurker's Avatar
Thanked: 641 Times
ok. After 12 hours of continuous non-operation in absence of any abnormalities (viz low voltage, malfunctioning power point) I just called a non-LG technician. And within minutes the fridge starts working again.
Seriously guys, I am at my wits end.
Old 10th August 2009, 15:41   #424
sgiitk's Avatar
Thanked: 3,793 Times
Infractions: 0/1 (5)
I would suspect severe iceing in the coils, which when it enters a defrost cycle takes that long to melt out. Once the fridge enters a defrost mode, it will not restart until the coils are above 0C.
Old 10th August 2009, 20:40   #425
lurker's Avatar
Thanked: 641 Times
Yes, the technician also inspected that coil by removing the freezer panels (behind where the coils are placed) and there was not any icing over that part, which again compelled him to meet his 4 point manifesto and confused everyone including him.
It is highly confusing to say the least. I am suspecting voltage problem but I do not suspect any drop in tubelight brightness or performance of any other object. My neighbours refrigerator also would suffer from any such problems arising from low voltage etc but they do not report any such problem nor does anyone else in my area. Moreover the substations and a 110 kv transformer supplying power are within a few hundred metres of my residence.
But there is one thing, that when the refrigerator starts to work after its long hibernation. It works on continuously for more than 12 hours at a stretch. When it switches off it is also for similar amount of time. There is no problem with cooling because when it works it cools very well.
Old 24th August 2009, 11:13   #426
Thanked: 60 Times
hi everybody want to buy aside by side 2door refrigerator for a family of 5-6 persons?which do u all recomend
drchernish is offline   Reply With Quote
Old 24th August 2009, 12:00   #427
kb100's Avatar
Just picked up a Siemens WM 12E160N 7kg fully automatic front loader. Costed 29,700/- nett.
kb100 is offline   Reply With Quote
Old 24th August 2009, 12:19   #428
KITE RUNNER's Avatar
Thanked: 7 Times
Samsung has got good side by side refrigerators in the indian market. Available in sizes 560 L upwards.
KITE RUNNER is offline   Reply With Quote
Old 24th August 2009, 21:50   #429
Thanked: 60 Times
between lg n samsung which is better?in context to side by side refrigerators.anybody using them?any personal experiences will help.thanks.
Old 24th August 2009, 22:07   #430
Vid6639's Avatar
Thanked: 19,591 Times
Just the model I was looking for as well. Did you buy it directly from rbs appliances?
I am also considering the new Samsung range of front loaders. Did you see those before finalising?
http://www.samsung.com/in/consumer/s...WF7652SUV/XTL#
Old 25th August 2009, 12:52   #431
mithun's Avatar
Thanked: 49 Times
Samsung is a better bet !
Old 25th August 2009, 14:11   #432
mithun's Avatar
Thanked: 49 Times
Having one doubt...
Why there is no inside light for Freezer compartment in 2 door fridges ?
Old 25th August 2009, 14:22   #433
shankar.balan's Avatar
Thanked: 5,331 Times
can never figure that one out.
also, why cant the freezer be kept at the lower portion of the double door fridges instead of above? after all one usually uses the "fridge" part more than the "freezer" part under normal circumstances.
Originally Posted by mithun View Post
Having one doubt...
Old 25th August 2009, 14:26   #434
sgiitk's Avatar
Having one doubt...
Interesting point. I suspect it is too cold so the filament may burn out or the heat may be too much for the temperature. May be they can think of LED lights!
Old 25th August 2009, 14:40   #435
Vid6639's Avatar
All the panasonic fridges have this layout with the freezer below.
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
