Old 19th June 2014, 16:33   #4411
mail4ajo's Avatar
Thanked: 238 Times
Default Re: The Home Appliance thread
Any idea on what are the new trends in Lighting? I know LED has arrived. Are they affordable and reliable as regular home lighting solutions. Not looking at anything fancy, but just replacement for old tech tube lights/CFLs.
Also what are the good brands in ceiling fans? Do we have modern choices or older brands like USHA, CG, Khaitan.
mail4ajo is offline   Reply With Quote
Old 19th June 2014, 17:14   #4412
JMaruru's Avatar
Thanked: 103 Times
Thumbs up Re: The Home Appliance thread
For ceiling fans, look no further than crompton greaves. Best of all that is available in the market!
JMaruru is offline   Reply With Quote
Old 19th June 2014, 17:27   #4413
mail4ajo's Avatar
Thanked: 238 Times
Thanks JM. Also need help to choose a chimney/Hob. I guess Hob is easier to choose. I basically need a glass type, inbuilt, 3 burner will do.
I know the basics of a Chimney, I guess I need to look out for min 950 m3Hr suction, Baffle filter, 60 cm. Any suggestions from Faber/Kaff?
Old 19th June 2014, 17:38   #4414
JMaruru's Avatar
Thanked: 103 Times
Smile Re: The Home Appliance thread
I have been using faber 1000m3/hr chimney of baffle filter type. I get it serviced once in 6 months. No issues.
The hob is also from faber, but here i had some issues with the auto ignition. Most of the times, it queaks on it's own. The service guys say that is coz of water/moisture seepage into electricals. We need to keep the surface clean.
Old 19th June 2014, 17:54   #4415
mail4ajo's Avatar
Thanked: 238 Times
Thanks JM, do you remember the model, size (60/90) or the price range?
Old 20th June 2014, 10:03   #4416
sgiitk's Avatar
Thanked: 3,793 Times
Infractions: 0/1 (5)
1. Yes, LED's have arrived. Cost is about Rs.650-700 per watt. I know flats being done up with all LED!
2. I am in love with Crompton-Greaves. We have been using them since 1967 (our house in Lucknow), and our current home is also CG.
Old 20th June 2014, 10:12   #4417
drsingh's Avatar
Thanked: 468 Times
I went through the costs of lighting a couple of months ago . Led lighting makes sense if you're going for custom lighting fixtures as custom fixtures with CFL and flourescent tubes may be as expensive as LED. For standard lighting the best option is t5. Or even 18 Watt t8 instead of CFL lamps.
drsingh is offline   Reply With Quote
Old 20th June 2014, 11:19   #4418
khoj's Avatar
Thanked: 1,253 Times
Recently replaced a 15W CFL with a 10W LED, make Osram, cost 600 odd bucks. Light output is much better and the bulb does not heat up.
Old 20th June 2014, 18:06   #4419
manim's Avatar
Thanked: 378 Times
Post Re: The Home Appliance thread
I have been changing some of my incandescent/CFL bulbs to LED in my home.
Bought Philips-make from Amazon.in which fits the regular bulb-holder 'B22 Base'.
Bought 10W, 7W, 2.5W and 1W.
The 2.5 Watts is itself very bright!
The 1W one is for night-light but still bright enough to interfere with sleep!
It also produces less heat.
Another main advantage of LED over CFL's are they do not reduce in life for frequent switching on/off.
Tried two colors, Cool-Day-Light replacing CFL's and Warm-White replacing incandescent.
But for serious work and reading the 10 Watt LED still cannot beat the regular 36Watts Tubelight.
manim is offline   Reply With Quote
Old 20th June 2014, 18:35   #4420
Thanked: 1,527 Times
I have a ceiling fan that has 4 thread bulbs holder
I don't want to put yellow bulbs in it, as I hate yellow light. Also, normal bulbs of 25/50W each would take the total consumption to 100W or above. I was thinking about getting LEDs.
Would 4 x 2.5W LEDs suffice to light up a room of 15x10ft? Or Do I go for powerful ones? Can I use CFLs instead?
Also, which one to go for, Cool-Day-Light or Warm-White?
ani_meher is online now   Reply With Quote
Old 20th June 2014, 18:35   #4421
mail4ajo's Avatar
Thanked: 238 Times
I see Havells has Tube lights that can be retrofitted on the normal system. Cost around 3K.
Old 20th June 2014, 19:24   #4422
Thanked: 93 Times
Warm-White is yellow, so you should prefer cool day light. Again the wattage of the lights would depend on how bright you would like the room and if there are any additional lights to supplement the light in the fan.
ksmrsm is offline   Reply With Quote
Old 20th June 2014, 19:42   #4423
sgiitk's Avatar
Is any of the cheaper brands having yellow or 2700K LEDs? I have a Osram 7W as well as a couple of bathroom lights (6W I think). Also, what about fitments, bayonet, large screw and small screw! I feel that the cool daylight, etc. are not suitable for home use.
Old 20th June 2014, 20:13   #4424
shashi63's Avatar
Thanked: 238 Times
Originally Posted by richie4u View Post
Can somebody please recommend me a Good top loading fully automatic washing machine below 20K, I have been using a Samsung one which I bought for 15K a couple of years back,but of late it has been conking off so I'm thinking of replacing it. Two brands I'd like to stay away are Samsung and IFB so now whats my choice?
Secondly is buying from Snapdeal smarter specially incase of bulky stuff like A washing machine? Do companies provide support properly when you buy from Online stores?
Hey not sure if you have already brought one but i would recommend you have serious look at Godrej as well.
shashi63 is offline   Reply With Quote
Old 20th June 2014, 20:43   #4425
Thad E Ginathom's Avatar
Thanked: 7,460 Times
Warm white is actually equivalent to sunlight. Cold white is much more harsh on the eyes. However, the neutral white that is used in graphics/arts studios etc is something else again!
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
