Old 10th November 2014, 10:12   #4741
saket77's Avatar
Thanked: 4,804 Times
Default Re: The Home Appliance thread
I generally add a cup of vinegar during an empty running load in my front loader to de-scale it. Otherwise, de-scaling powder is available for 150 (or 200) bucks at IFB.
saket77 is offline   Reply With Quote
Old 10th November 2014, 11:01   #4742
hillsnrains's Avatar
Thanked: 279 Times
Originally Posted by moralfibre View Post
Any recommended brands? We face a lot of problem due to scaling in our washing appliances as well as on tiles, etc. Are there any chemicals that can be used to remove scales from tiles as well?
Hi moralfibre,
I use "Scalegon" for descaling my Washing machine (LG front load) once in 45 days. I generally buy it from ebay link here
For the tiles and other kitchen equipment like hob, chimney I use "Cif" an Hindustan Unilever product. You can get this in any decent provisional store.
Hope this helps!
hillsnrains is offline   Reply With Quote
Old 10th November 2014, 18:32   #4743
sgiitk's Avatar
Thanked: 3,855 Times
Infractions: 0/1 (4)
For hob etc I find Blue Harpic pretty effective.
Old 10th November 2014, 22:38   #4744
Default Re: LED bulbs
Originally Posted by BenjiRoss View Post
I am looking to buy a couple of LED bulbs for my home. Will a 5 watt bulb be enough? I am looking for a soft lighting option and not too bright. Should be equivalent to a regular 40 watt bulb or a 11 watt cfl.
It's probably a bit too late, and you might have already purchased the bulbs, but I expect a 5W bulb to be a little too dim (~350 lumens for Philips) compared to a 40W incandescent (~500 lumens) or an 11W CFL (~600 lumens). A 7W or 7.5W LED should be closer.
... remember LEDs are in cool daylight, warm daylight and warm colours. For domestic use prefer the latter two!
If by "warm daylight" you meant 4000K colour temperature, I'd be interested to know where I can find such LED bulbs. AFAIK, Indian suppliers (Philips, Havells, ...) only market cool white (6500K) and, sometimes, warm white (2700K). I've had hard time finding even the warm white kind for all wattages (even in Philips showrooms)!
meerkat is offline   Reply With Quote
Old 10th November 2014, 23:05   #4745
Thad E Ginathom's Avatar
Thanked: 8,208 Times
I bought a couple of LED floodlights recently. We had a high-power thing with a tube in it that was as hungry for electricity as an AC machine, and which had also been badly eclipsed by a new car port. In monsoon times, we do sometimes need to work in the garden at night. With the road built higher, our garden has become a tank, so we have installed a pump to empty it, hopefully making sure that it stays out of the house.
I had been thinking that I might need something like 100W, but I bought one 30W and one 20W for trial. The 30W is plenty for lighting up the drive, gate, pumping area; the 20W is plenty for casting a lower light on the rest of the garden. Not very bright, but enough, for instance, to spot an intruder (usually, they have four legs: somehow dogs occasionally jump in, and are then baffled as to how to get out again).
This is nameless Chinese stuff from a local lighting shop. For as long as it goes on working... I'm happy. In fact, I'm very pleased with it, and want to fit some more, eg for terrace lighting.
I'm yet to try LEDs for interior lighting, but quite looking forward to it.
Old 11th November 2014, 11:52   #4746
rohan_iitr's Avatar
Thanked: 406 Times
For washing machine - IFB descaling powder does the job.
For cleaning tiles - Regular (blue) Harpic is very effective. But recently Harpic has also launched a red Harpic especially for cleaning tiles etc. You may give it a try.
Mr Muscle Scale remover spray also comes handy for removing scales.
Rohan
rohan_iitr is offline   Reply With Quote
Old 11th November 2014, 12:51   #4747
sgiitk's Avatar
I also heard that many LEDs are pretty inefficient, hardly better than CFLs. I hear 70 lumens per watt is the minimum required.
Old 11th November 2014, 16:01   #4748
Jaguar's Avatar
Thanked: 150 Times
Are the safes available in the market fire proof? I am looking for something to store important documents and stuff. Don't need theft protection, just safeguard from the elements.
Jaguar is online now   Reply With Quote
Old 11th November 2014, 16:41   #4749
HillMan's Avatar
Thanked: 401 Times
Did you try Godrej?
A quick Google got me this URL.
http://www.godrej.com/godrej/gss_sin...frfc_frfc.html
HillMan is offline   Reply With Quote
Old 11th November 2014, 22:20   #4750
BenjiRoss's Avatar
Thanked: 149 Times
Tried blue harpic on my taps and hobs and was impressed with the results. I now smell like a toilet but the taps are sparkling!
Let's see if my wife notices (the sparkle and the smell)
BenjiRoss is offline   Reply With Quote
Old 11th November 2014, 23:07   #4751
audioholic's Avatar
Thanked: 5,875 Times
Harpic is quite good for removing scales on the taps and shower. My maid uses it once a month to even clean the tiles in the bathroom since they get scaled lightly. Our water supply is a little hard so this is a routine. However be careful with sensitive surfaces apart from glass, ceramic and test it on metals before you gun it!
audioholic is offline   Reply With Quote
Old 12th November 2014, 08:18   #4752
Thanked: 279 Times
Blue Harpic works well, but I do not like the smell (kitchen smells like toilet).
Cif is pretty neutral and does not have strong odour and I use quite regularly.
I agree mate.
Old 12th November 2014, 12:23   #4753
tsk1979's Avatar
Thanked: 15,847 Times
Planning to go for a new fridge. After owning a few korean products(LG/Samsung etc.,) ranging from Washing machines to Air conditioners, I have come to the conclusion that they are built to last 4-5 years at most. Rubbish QC.
Our 40 year old Kelvinator works better than a 10 year old samsung/whirpool etc.,
Does anybody make build to last home appliances anymore? I am okay with paying 4-5K more, but want something that does not leak gas every 5 years.
Old 12th November 2014, 12:50   #4754
joybhowmik's Avatar
Thanked: 1,915 Times
Try Godrej. I have owned one for several years. No complaints.
And they have a very responsive home care.
Old 12th November 2014, 12:57   #4755
saket77's Avatar
Using Panasonic for last 2.5 years. Though it has still to undergo the test of time, but surely it feels much better built than the regular LGs & Samsungs. The finish quality is great. And the bottom freezer is a boon and so practical.
Sharp is another very reputed brand when it comes to refrigerators & televisions.
Saket
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 764 26th April 2018 11:37
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
