Old 15th February 2015, 13:40   #4966
Thanked: 195 Times
1. Big idea: Use the sun to generate as much power as I use in ACs during the day
or
2. Small idea: Use to sun to generate at least the 150-200 Watts that me and my computer corner is using all day.
I don't think that either is financially feasible with the current cost of technology.
Search for SuKam Solar Conversion kit. A 16 amp solar controller will cost ~ 3000 in ebay. Add 100watts solar panel and you can charge your inverters using solar to an extend. This should take care of your small idea.
Running AC on solar though possible is not at all cost effective as of today.
I am running a low cost setup for my router and other small 12v accessories using a chinese 10A solar controller (Rs 700) directly connected to battery. No inverters or ups involved since my requirements are 12v.
Holyghost is offline   Reply With Quote
Old 15th February 2015, 14:04   #4967
Thad E Ginathom's Avatar
Thanked: 7,684 Times
Default Re: The Home Appliance thread
I did look at the Sukam stuff a while back. They have this setup called a brainy: a hybrid mains-power/solar inverter. Nice, but if I remember right, I'd need to add one more panel to meet my needs, and that put it beyond budget.
Originally Posted by diyguy View Post
I would think charging inverter batteries should be possible and is probably available now. We have two inverters at home and not sure how much power they consume to keep them going. Chennai is kind of blessed offlate with almost no power cuts. A friend of mine disconnected his inverter to save power.
Hee hee, our power was off for the whole of yesterday afternoon! But no, it wasn't a power cut, but a cut cable.
Beware of speaking "too soon" about the power situation. We are still in the easy part of the year. Let's see how things are as next month brings us higher temperatures, more AC use, etc etc.
Both my projects would be possible. To support one or more Ac machines using solar power would probably cost about the same as a diesel generator of similar capacity (guessing here, although I have looked at prices of both in the past). One would not have to buy diesel, but then it wouldn't work at night without a stack of batteries.
I wonder how much an inverter costs just sitting there keeping the batteries charged. I have a feeling it may add as much as 5% to the bill?
Old 15th February 2015, 15:29   #4968
diyguy's Avatar
Thanked: 138 Times
I hope not 😟
I have a plug watt meter, will hook it up and check.
diyguy is offline   Reply With Quote
Old 15th February 2015, 17:09   #4969
sgiitk's Avatar
Thanked: 3,814 Times
Infractions: 0/1 (5)
I guess it may be more like 5% of the inverter rating and not overall.
Old 15th February 2015, 18:29   #4970
condor's Avatar
Thanked: 4,548 Times
That's the cost of just keeping the batteries charged. But the other cost to watch out for is when the invertor is supplying power - in the absence of regular supply. Invertors are supposed to be only about 70% efficient. I do not have the exact numbers, though.
Old 15th February 2015, 21:09   #4971
sgiitk's Avatar
@condor; You are right. The older square wave units did cross 80%, but with a sinewave 70% is probably as high as you will get.
Old 16th February 2015, 00:05   #4972
drsingh's Avatar
Thanked: 473 Times
I hope not ?de1f
I think its about 1-1.5 units/day
drsingh is offline   Reply With Quote
Old 16th February 2015, 11:20   #4973
Pallavi's Avatar
Thanked: 38 Times
Have you tried, as a practice to change the program every time you start? I.e start with a dummy program and then do what you usually do as above? Does it work consistently? Sounds like a logic board issue to me. Try and get a second hand board and attempt a replacement.
Originally Posted by Pallavi View Post
Sounds logical. Will try this and check.
Tried this and it worked. Problem recurs but not as often as earlier.
This brings me to the next question: repair or replace?
The IFB has served us well for 7+ years. This is the first issue we had. Recent buyers of dishwashers, please give your inputs.
Pallavi is offline   Reply With Quote
Old 16th February 2015, 11:31   #4974
diyguy's Avatar
Thanked: 138 Times
A 7 year old washer is probably not a good idea to spend too much on. In Chennai there is a second hand spares market for Washing Machines and Refrigerators etc. Here you get all used spares really cheap. Find a mechanic who can get you a spare easily for a few 1000s. Alternately IFB are notorious for paying AMC and they will replace the spare for you, free. My friend just did this recently. They claim the spare against some other customer who is in AMC and redirect that to you. Its a win-win for all, except IFB I imagine.
Old 16th February 2015, 11:51   #4975
Jaguar's Avatar
Thanked: 149 Times
or
See this video about running an AC on solar power https://www.youtube.com/embed/SnL4YCIEiTc
Jaguar is online now   Reply With Quote
Old 16th February 2015, 12:58   #4976
manim's Avatar
Thanked: 386 Times
Post Re: The Home Appliance thread
My 800va APC Sine-wave UPS consumes 20 watts at trickle-charge.
I measured this with the digital energy-meter fitted recently in my house.
This is less than half an unit per day so a small price to pay to keep the battery fully charged and on standby.
manim is online now   Reply With Quote
Old 17th February 2015, 00:33   #4977
diyguy's Avatar
Thanked: 138 Times
Alternatively if you can find a way to update the firmware on the board, may work too!
Old 17th February 2015, 01:32   #4978
Thank you.
I think I got confused between the standby cost and the drain/recharge cost. The former is very small, whereas the latter is much more than I thought.
Old 17th February 2015, 23:42   #4979
condor's Avatar
Does any washing machine have an over-load indicator ?
eg: If the machine has a 6kg capacity, will it indicate that the capacity has been reached ?
Old 18th February 2015, 13:11   #4980
Thanked: 1,019 Times
I checked the manual of my LG - F12B4ND25 (6kg direct drive). There are two codes for "Motor Over Load" - CE and LE.
Though I have not encountered the codes, it can mean that the Machine will not start if the codes are displayed. Reducing the load will clear the codes.
The machine does a startup check to detect the dry load and to redistribute the clothes evenly. Only after that does it display the total was time. For normal wash the time varies from 1 hour for a light load to 2.5 hours for a heavy load, every other setting being same.
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 745 16th February 2018 21:47
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
