Old 7th March 2015, 18:00   #5011
govigov's Avatar
Thanked: 452 Times
Default Re: The Home Appliance thread
My mother has a top loading diamond drum washing machine - its inlet is blocked. Has anyone ever cleaned it themselves? Is there a DIY we can do, or should we call samsung only? or can I call my neighborhood chappie?
The inlet usually has a filter that you can pull out and then remove the dirt. The wire gauze used is very fine, so clean gently.
govigov is online now   Reply With Quote
Old 7th March 2015, 18:20   #5012
Engine_Roars's Avatar
Thanked: 437 Times
How are these air fryers? Are they useful in kitchen? I see lots of ads of 'Kenstar'.
Hi, We have been using the one from Philips. Does its job well. The food tastes not exactly like the oil fried food but kinda close. After all, you need to lose something to gain something or I should say, you need to lose something to not gain something(weight and fat).
Engine_Roars is offline   Reply With Quote
Old 7th March 2015, 18:23   #5013
Thanked: 437 Times
Originally Posted by sheetumanu View Post
Friends,
Need help in deciding between Panasonic and IFB Top loader washing machine. Here are the models and I live in Noida
My in laws have been using top loading from IFB since more than 10 years now and I must tell you that they are pretty happy with it. Have not heard much about Panasonic. I have LG's and that is working pretty well too. IFB's are on the higher side of price range though.
Old 7th March 2015, 19:20   #5014
ramki067's Avatar
Thanked: 25 Times
Our IFB front loading washing machine has started giving problems every other day. So, want to change it to a top loading washing machine.
Looking out for options for a 6.5 to 7Kg one having a plastic/fibre drum. Also, this machine will be used one or two times on a daily basis.
Kindly suggest reliable machines if anyone has experienced/known.
Thanks,
Ramki
ramki067 is offline   Reply With Quote
Old 7th March 2015, 20:19   #5015
diyguy's Avatar
Thanked: 123 Times
I had purchased the top end whirlpool top loader 8kg and it was nothing but money down the drain. It wouldn't mix the detergent properly due to using ground water though the front loader never had this issue. Had to switch to expensive liquid detergents due to this. The water sensors kept failing and very often needed support. Small clothes would get stuck in the outlet. The logic board got spoilt twice and the second time was out of warranty. Scrapped it for 1000rs by the end of its 4th year. Long story - do not consider a whirlpool
diyguy is offline   Reply With Quote
Old 7th March 2015, 21:46   #5016
Thanked: 282 Times
Thanks,
Ramki
My LG 6.5 kg Top Loader is now nearing 10 years. My use is around 4-5 times a week. After 1st year of warranty, I must have spent a total of 700-800 Rs on it till now - average of 300 Rs once in 3 years. And each of those times, the LG technician has landed up within 24 hours.
carboy is online now   Reply With Quote
Old 7th March 2015, 22:38   #5017
JMaruru's Avatar
Thanked: 103 Times
Thumbs up Re: The Home Appliance thread
+1. Our LG Top loader could have been 15+ years now. I had to change the top control panel once, the cost being around 1K. We almost have a load, every day. No complaints!
JMaruru is offline   Reply With Quote
Old 8th March 2015, 16:32   #5018
Pallavi's Avatar
Thanked: 38 Times
One more happy LG customer. Our front loader is 8yrs old with only one major problem fixed within 12hrs. The drain pump failed and cost Rs.870 to replace. Paid Rs.1380 including service charges, taxes etc. The best part is if the problem repeats within a month of logging the call, the repair will be done free of cost.
AMC option is available and is cheaper than IFB.
LG also has many DIY videos on youtube. If you are facing any problem with the machine, most of the times these videos will help you troubleshoot without calling the customer care.
Need help with Eureka Forbes customer care.
We have the Bravo model and its Hepa filter is blocked. Need a replacement.
All the calls to the customer service center are sheer waste of time.
The "technician" visits, checks the vacuum cleaner as if it were alien tech. When i point out the hepa filter and ask for the replacement, he says he will check the availability and vanishes. No follow up.
When i call the customer service again, a new call is logged and the cycle repeats
Meanwhile lots of calls from the Eureka Forbes retailers asking us to purchase a new vacuum cleaner and exchange the old one
Is there a way to break this cycle? Contact details of a technician who can get the replacement Hepa filter is much appreciated.
Pallavi is offline   Reply With Quote
Old 8th March 2015, 17:32   #5019
phamilyman's Avatar
Thanked: 3,454 Times
It's the same thing for my mother's Samsung top loader. The water sensor has failed in three years of usage (in contrast our Whirlpool semi is rock solid but noisy dancing after seven years) and costs 5000+ for the machine which costed 12700!
Choose the brand which has a company owned service center in your area.
The panel wiring for the water control is bust. I'd already cleaned the filters.
This particular motor is not getting current which has been diagnosed as a panel failure.
My mom's Samsung WA82BSL was quoted a panel replacement for 5000 bucks!
How much can I fetch for a 3.5 year old Samsung top loader that is in perfect condition except the water inlet? It costs 12700 new.
Old 8th March 2015, 18:27   #5020
Pallavi's Avatar
Thanked: 38 Times
On the same note, any contact info of reasonable second hand washing machine/AC dealers.
The ones spoke to offered ₹500 for the window ac
Old 8th March 2015, 20:28   #5021
JMaruru's Avatar
Thanked: 103 Times
Unhappy Re: The Home Appliance thread
For old washing machines, the max offer is around 1K from these dealers/service shops.
It is better to post it on online channels like OLX or Quikr.
Old 8th March 2015, 21:41   #5022
diyguy's Avatar
Thanked: 123 Times
I took out some sensors and valves from my whirlpool when I gave it away for 1k. Should have taken out the motor too as it was perfectly fine. Could have used it as an automatic gate opener or something. I plan to use the water inlet relay to setup timed water sprinkling for the plants in our garden...
Old 9th March 2015, 10:05   #5023
Thanked: 59 Times
Originally Posted by khoj View Post
Hi, sorry for the delayed response. So the model i have is CEWHR 50 L
Racold is one of the better brand for geysers. I am using it almost everyday, except for peak summers, for last 2.5 years with no issues whatsoever.
Regards.
Have visited a few shops to get information on AO Smith SDS model for 15 litres. Almost finalised the same, but one respectable dealer was requested to go for "morphy richards" water heaters.
http://www.aosmithindia.com/HSE-SDS.html#
Haven't heard of Morphy richards water heaters till date.
Would you guys recommend Morphy over AO Smith ? Any pro's and con's.
Dealer says that it is much resistant to Hard water compared to AO Smith. Always take it with a pinch of salt when it comes from dealer's mouth.
Let me know your guidance on it. Need alteast 2 heaters in short duration.
lambuhere1 is offline   Reply With Quote
Old 9th March 2015, 10:11   #5024
latentpotential's Avatar
Thanked: 377 Times
AO Smith is super resistant to hard water. In one of our houses, where only ground water is available, we change the taps every 2 years as the hard water settles inside. But the AO Smith keeps going on without any issue. Earlier we would need to get the geyser opened and cleaned every year, now its approx 4 years.
AO used to be sold under the Jaguar brand earlier, very expensive when we got it, dont know pricing now.
latentpotential is offline   Reply With Quote
Old 9th March 2015, 15:05   #5025
ramki067's Avatar
Thanked: 25 Times
I had purchased the top end whirlpool top loader 8kg and it was nothing but money down the drain...
One more happy LG customer. Our front loader is 8yrs old with only one major problem fixed within 12hrs. The drain pump failed and cost Rs.870 to replace. Paid Rs.1380 including service charges, taxes etc. The best part is if the problem repeats within a month of logging the call, the repair will be done free of cost...
Thanks very much guys. Will definitely go for LG.
However, when asked about LG plastic drum to Pai International they said LG has stopped giving out plastic drum option machines in 6.5 or 7 KG.
Any LG washing machine direct dealer contact would be helpful in knowing about the products they are offering.
Thanks,
Ramki
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
