Old 21st May 2015, 18:07   #5191
techiecal's Avatar
Thanked: 62 Times
Default Re: The Home Appliance thread
I see lot of action from the stabilizer in the morning (between 9 and 10:30 AM). I took my volt meter and saw that the voltage from the supply company fluctuates between 160 and 440 Volts.
Am I reading this right 'between 160 and 440V'. I think you mean 240V.
techiecal is offline   Reply With Quote
Old 21st May 2015, 20:53   #5192
vsrivatsa's Avatar
Thanked: 566 Times
Question Re: The Home Appliance thread
I am trying to decide between the two Microwave Ovens and looking for advice on the same:
1. Panasonic NN-DS592B Inverter based MW Oven:
http://www.panasonic.com/in/consumer...nn-ds592b.html
2. LG Charcoal, Lightwave Heater MW Oven:
http://www.lg.com/in/microwave-ovens/lg-MJ3283BKG
I have read lot of good things about the Inverter Technology which is not available in both LG and Samsung. But the Panasonic model called out is not much customized in terms of Indian Menus etc. What do people on team bhp recommend/advice?
vsrivatsa is online now   Reply With Quote
Old 22nd May 2015, 01:28   #5193
Thad E Ginathom's Avatar
Thanked: 7,460 Times
Hmmm... 440 is the voltage across two phases, and very nasty indeed for humans or equipment. I've seen it indoors, but it was the result of an outside-the-house EB fault. Luckily, I didn't have very much blow up.
I would certainly call the EB engineers if I saw it going that high: it is just too dangerous!
Did I ever tell you about the time I got a 440v shock on the head?
--- Ahem, shut up, Thad, old man, yes you did!
Old 22nd May 2015, 09:21   #5194
sgiitk's Avatar
Thanked: 3,793 Times
Infractions: 0/1 (5)
@Thad; 440V across two phases adds up to 440/1.73 volts between a phase and neutral. Actually across two phases you should expect about 415V.
Old 22nd May 2015, 18:25   #5195
techiecal's Avatar
Thanked: 62 Times
Yes, but he is talking about the voltage that powers his TV so it must be between phase and neutral and 160 - 440 between phase and neutral is shocking and unbelievable.
Old 23rd May 2015, 00:20   #5196
Is it? I guess it is a simple sum, and I seem to remember some explanation with diagrams too. I plead innumeracy!
Old 23rd May 2015, 11:04   #5197
sgiitk's Avatar
Thad it is easy. You have 120 degrees between phases, which is what leads to the 1.73 factor. In fact it is 415 at 240V or so, at 220V it is more like 380V.
Old 23rd May 2015, 13:44   #5198
I know that it hurts! And that I might possibly be lucky to be alive and uninjured from my brief encounter with a fault that made the EB meter casing live at the full 3-phase difference!
Old 23rd May 2015, 14:24   #5199
sgiitk's Avatar
Even 230V can be tricky. Once I got it on my forearm and fortunately there was a student who promptly pulled me out. Thanks RR Arya.
Old 23rd May 2015, 21:03   #5200
a quick touch of 230V I have experienced many times, usually as a result of being stupid. Just because I'm still alive, though, I'm not claiming that it is safe. Not at all.
The weird thing about the 440 (that's what my meter said, case to ground, was it was not like an electric shock: it was like being hit with a blunt object. <POW> just like in the cartoons.
Old 24th May 2015, 10:24   #5201
Thanked: 1,011 Times
It all depends on how much current the source can pump through your body. Mains is dangerous as it can pump in quite a lot of current. Geysers and water coolers are also dangerous. But small leaks from appliances, generally are not that fatal. Anyway shoes and chappals prevent direct connection with earth, hence reduce the intensity of current.
Old 24th May 2015, 11:18   #5202
dre@ms's Avatar
Thanked: 172 Times
I am in lookout for a gas stove. Received a brochure from Prestige on their new Hobtops. Any reviews on it? How difficult it is to clean? They are dual purpose, can be housed as a stove or hobs.
http://www.prestigesmartkitchen.com/...urner-pht03-ai
dre@ms is offline   Reply With Quote
Old 24th May 2015, 15:26   #5203
Probably repeptition, but perhaps it is worthwhile as a safety warning:
I was fixing wire mesh to the cable entry points of our EB board, which is enclosed in a cupboard, to keep out rats and moonj elis (shrews).
This is the big, big stupid: Because I wasn't doing electrical work, or even touching electrical components, I did not give a thought to electrical safety.
I wasn't even wearing shoes. Of course, nobody expects an appliance case to have become live, especially the main meter itself, but the lesson is to observe electrical safety even when working near electricity, especially when two or more phases are present within easy reach.
...but I'm alive, and I'll try not to be so stupid again.
Old 24th May 2015, 15:43   #5204
fine69's Avatar
Thanked: 867 Times
I got LG's F1296WDL24 6.5 kg front load yesterday. The manual doesn't contain any instructions on which detergent to use.
What's the best detergent to be used for this machine and do I have to change it based on type of clothing or some other factor? What about woolen clothes on which I used to use genteel when using my old semi-automatic machine?
fine69 is offline   Reply With Quote
Old 24th May 2015, 16:28   #5205
DieselFan's Avatar
Thanked: 233 Times
Front load wash mahines need different wash powders specifically meant for them. These are clearly marked in their cartons. These powders have low froth forming property which is important for all front loading machines.
DieselFan is offline   Reply With Quote
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
