Old 8th June 2015, 18:44   #5251
naveenroy's Avatar
Thanked: 707 Times
Default Re: The Home Appliance thread
If you have space, buy another 200-300L refrigerator. I have done that.
Yeah, this isn't possible as space is a premium. Otherwise, the idea makes sense.
We had a Zanussi three door (bought in the UK) for about a decade. We did not find the veggie tray that useful. What we loved (in India on some brands) is the freezer at the bottom. Saves a lot of bending down. My son's Panasonic has it.
Yes, I went window-shopping for fridges last weekend. Good that I went and your recco was correct - the 3 door fridge doesn't really make sense. But I saw some good Samsung models and even a Bosch one that seems to fit the bill perfectly. Any feedback on Bosch fridges?
naveenroy is offline   Reply With Quote
Old 8th June 2015, 21:22   #5252
nareshov's Avatar
Thanked: 165 Times
Window shopping refrigerators here as well. Plan is to purchase one in mid-July.
So far, we've liked this particular EcoNavi Panasonic fridge. SHARP, Hitachi and Bosch were the other brands we checked out but none of them came close to our liking. Panasonic had the largest vegetable box of them all.
Anything else I should watch out for?
nareshov is offline   Reply With Quote
Old 11th June 2015, 11:12   #5253
Thanked: 1,047 Times
Originally Posted by ::CMS:: View Post
How can they blame on voltage fluctuation for their product to conk off unless it is a very high voltage and resulted in lot of other damages?
Ask him to prove that and if it is indeed due to power fluctuations then its the design flaw, how can somebody else than the manufacturer know what kind of power supply is required for the refrigerator to work unless it is mentioned in the manual? In all other cases its their fault to allow the power fluctuation to enter into their board, its supposed to have proper power supply. Ask them to replace under warranty if it is active.
In general you can argue till you are blue in face, but voltage dependent malfunction is a fact of life, and an excellent scapegoat for the manufacturers. When you design electronics to run where the voltage is stable, you skimp a lot of things and the cost is much lower. That is why consumer grade electronics is half the price of "Industrial Grade" electronics and 1/10 that of "Military Grade".
The long and short of it is if you are using "Foreign" technology consumer electronics in India, you better have a lot of protection against "normal" voltage fluctuations and spikes.
Old 11th June 2015, 11:30   #5254
::CMS::'s Avatar
Thanked: 469 Times
Its not always true, eg TV has its own powersupply with a pretty good stabilizer.
How? I am not aware of a reliable one than an inline ups which is pretty expensive, none of the so called stabilizers are not going to help, the ripples will anyway reach the circuitry before it detects / corrects. Its a myth that the stabilizers will protect always.
::CMS:: is offline   Reply With Quote
Old 12th June 2015, 10:27   #5255
ramki067's Avatar
Thanked: 25 Times
Originally Posted by ramki067 View Post
Guys,
Power cuts are errant in our area which is in somewhat outskirts of the city where even Kaveri water is also not available.
Need to buy an inverter and battery to light up 4 tubelights and 3 fans. Kindly suggest good ones and also the capacity of inverter and battery i need to buy.
Thanks,
Ramki
Hi Guys,
Any help will be much useful.
Thanks,
Ramki
ramki067 is offline   Reply With Quote
Old 12th June 2015, 10:31   #5256
NPV
NPV's Avatar
Thanked: 5,185 Times
Check out the Whirlpool refrigerators as well, they have a smaller freezer compared to other manufacturers, so more space in the refrigerator
Hi Guys,
Look at Su-Kam or Luminous inverters, they're good. For Batteries Su-Kam is good too.
NPV is offline   Reply With Quote
Old 12th June 2015, 13:28   #5257
ramki067's Avatar
Thanked: 25 Times
Thank you NPV. For my requirement, how much capacity inverter/battery is needed?
Ramki
Old 12th June 2015, 13:29   #5258
civic-sense's Avatar
Thanked: 841 Times
Stupid question, maybe. But....
Is it possible to run a refrigerator (a small one at least) off a UPS/Inverter? If yes, what should be an ideal VA rating?
Same with an aircon?
civic-sense is offline   Reply With Quote
Old 12th June 2015, 14:18   #5259
NPV
NPV's Avatar
I couldn't find the sheet I had prepared during my search for a home use Inverter/Battery but if I remember correctly I have a Su-Kam 850 VA Inverter and a Sukam 1800AH battery (Sumo) - your needs might be satisfied by 650VA Inverter and 1200AH battery, but not too sure on this
Also, I suggest you don't go for something much lower based on your present needs and find it is under-powered few months later since your requirements changed
I think a better reference would be the UPS/Inverted thread - here (Which UPS to buy ?)
Old 12th June 2015, 14:38   #5260
SchumiFan's Avatar
Thanked: 742 Times
On the topic of Batteries and Inverters, I have a question. I am using a Microtek inverter (850 VA I suppose) and a Exide tubular battery for the past 4 years.
These days since I have moved into the city, there isn't a lot of power outages and less need for the Inverter itself. But if for some reason the power is off for 30 minutes, the battery is getting charged for almost hours after power is restored.
Is this a sign of weak battery or issue with the inverter? 4 years, is it time to replace the battery? We add distilled water every time we see the float dropping below the red line. That is the only maintenance we have done so far with regards to both the battery and inverter.
Originally Posted by Chetan_Rao View Post
Don't batteries trickle-charge for the final few % to avoid over-charging? Your battery being 4 years old may well be on its last legs (depends on usage too), but you may want to test its charge-holding capacity before changing anything.
How about turning the mains power off and testing how long the battery holds up under usual load (fans, lights etc.)? That will give you a fair idea.
I am not sure of this trickle charge detail but considering the usage I had in my previous home and now, the battery does seem to get charged very slowly. We have not had a chance to test the backup of the battery for some time now (Touchwood ). Maybe I shall do it this weekend to understand whether it is as efficient as before.
Thank you for the tip.
SchumiFan is offline   Reply With Quote
Old 12th June 2015, 14:52   #5261
Chetan_Rao's Avatar
Thanked: 4,233 Times
Originally Posted by SchumiFan View Post
......the battery is getting charged for almost hours after power is restored........
Chetan_Rao is offline   Reply With Quote
Old 12th June 2015, 16:01   #5262
naveenroy's Avatar
Thanked: 707 Times
Thanks, finally went ahead with a 2-door fridge - the Samsung RT36JSRZESP. A 345 liter fridge that will suit me just fine. I can use the freezer also as a fridge if need be. Good buy.
Old 12th June 2015, 16:27   #5263
techiecal's Avatar
Thanked: 62 Times
Hi Guys,
Thanks,
Ramki
Go for 850 VA with a 150 AH Battery. My preferred brand is Sukam-have been using it for a decade. If you have frequent power outages then go for tubular battery otherwise standard battery will suffice. For battery I prefer Exide.
techiecal is offline   Reply With Quote
Old 15th June 2015, 22:18   #5264
hellmet's Avatar
Thanked: 638 Times
What light fixture would you guys recommend to light up a large 12X14 bedroom that currently looks dark and dim with TWO 20W CFLs on ? One of the walls is a dark color so it doesn't make matters any better either.
I'm contemplating fixing an additional tubelight in the room, hoping that it alone would be sufficient to light up the room under normal usage. The two CFLs could then be used for tasks requiring more lighting. Should I go with the traditional fluorescent tube or an LED tube fixture? What wattage should I choose?
hellmet is offline   Reply With Quote
Old 15th June 2015, 22:49   #5265
Eddy's Avatar
Thanked: 4,975 Times
I have a similar room lit up by a traditional tubelight + two LED bulbs (5W, 10W). Initially we had two 5W LED bulbs, but decided to upgrade one of 'em my dad reads in that area of the room.
Our room is quite well lit naturally also, so if yours is not please consider two 10W LEDs. But one tublight is a must since bulbs do not spread the light as much as a tube does.
Eddy is offline   Reply With Quote
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 764 26th April 2018 11:37
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
