Old 27th July 2015, 22:06   #5341
madbullram's Avatar
Thanked: 75 Times
Default Re: The Home Appliance thread
Would that make a difference to the food? BTW, how does it compare with food prepared in oil?
We use Philip. This will not be as great oil fried foods. Its a compromise. Some foods like frozen foods comes out really nice but when you fry vegetables or french fries, they tend to become hard after some time.
Net result, oil consumption has come down 15% in my house initially we thought we can cut oil by 50% though!
madbullram is offline   Reply With Quote
Old 28th July 2015, 10:05   #5342
Prowler's Avatar
Thanked: 286 Times
Sure it does. Oil by itself gives some taste. Deep frying in oil gives you a unique taste which is not there in air frying. But for French fries, chicken nuggets and Veg Spring rolls it is okay. I have been using my Air-fryer for some time only for the above items and I can save oil. When you try that for sea food the difference in taste is noticeable.
Prowler is offline   Reply With Quote
Old 28th July 2015, 15:26   #5343
Thanked: 222 Times
Arrow Re: The Home Appliance thread
Originally Posted by techiecal View Post
Here is a ready reckoner. Check the Lumens per Watt on the CFL specs before you make the decision, though.
There are many many factors to consider. My query to Philips India about the availability of EnergyStar rated bulbs in India went unanswered and they removed the question on their website comments section stating that since I had not bought their product, it was not feedback.
Here is an article from Gizmag [Do read the comments at the site, some are very informative]
A tale of two tests: why Energy Star LED light bulbs are a rare breed
By James Holloway
How do you measure the life of a light source that could last decades?
Just over a week ago we reported that Philips' 22 W LED light bulb, designed as a like-for-like replacement of a 100-W incandescent light bulb, was the first LED bulb of its type to receive the stamp of approval from Energy Star. But looking at the Energy Star requirements reported by Philips in its press release, it seemed a little strange that Philips' product is the only one to have been certified given that products long on the market appear, at face value, to meet those requirements. Since then, Gizmag has spoken to LED light bulb makers Switch Lighting and other industry players to find out why they're apparently playing catch-up.
"Those who do not remember the past "
It turns out the reason is simple, but has a little bit of back-story attached. Unlike Energy Star certification for other types of appliances, an Energy Star-certified LED light bulb signifies reliability and performance as well as energy-saving performance. The reason for the difference is down to the problems faced by ordinary people when compact fluorescent bulbs first appeared. "Originally, the Department of Energy was very concerned about what happened with compact fluorescent lighting when it first entered the market in that there were all kinds of variations of quality, reliability and performance," Gary Rosenfield, EVP of Marketing & National Accounts at Switch Lighting told Gizmag. (Though the lighting aspects of Energy Star now fall under the jurisdiction of the Environmental Protection Agency, when it came to specifying Energy Star criteria for LED products, it was the DoE.)
Compact fluorescent light bulbs are often criticized for being dim and slow to warm up
The result has been something of a minor backlash against compact fluorescent lighting, though in reality this was more down to the shortcomings of individual products and the misleading ways in which they were sometimes sold. The DoE was keen to avoid a repeat performance when LEDs arrived, since LED products also vary enormously in quality. The relevant tests, devised by the Illuminating Engineering Society, are known as IES LM-79 and IES LM-80. A manufacturer that wants to apply for Energy Star certification must first pay an approved independent laboratory to carry out the tests on its behalf. With the results in hand, the manufacturer can then apply to the EPA (provided they're up to scratch, that is).
There is no fee for applying for Energy Star certification, nor for using the label. In fact the tests in themselves do not specify pass or fail results, but instead simply quantify performance and lifespan. It's the EPA that decides the benchmarks. Light output depends on the bulb's spec, but is a minimum of 1,600 lumens for bulbs purporting equivalence to a 100-W incandescent bulb. Among the other criteria are color rendering index of at least 80, and a rated life of at least 25,000 hours more on that in a moment.
"The LM-79 is basically the test that defines the photometrics, in other words that defines what the light performance is," Rosenfield said. LM-79 quantifies light output and distribution, as well as electrical power, allowing the calculation of the all-important efficacy in lumens/watts. It also identifies the light's color characteristics, such as its appearance, and its ability to render colors accurately.
"That's a fairly short test to run," Rosenfield explained. "It's done with spheres in independent labs. You put the product into these spheres, very expensive test equipment that basically encloses the entire fixture, and it tests all those variables." Easy peasy.
An Integrating or Ulbricht sphere used for photometric testing of lamps and light fittings
Ageism
"The other test [] is purely a life test," he added. "And in our category that test is run for 6,000 hours, so it's effectively nine straight months of testing." Life test is a useful if loose euphemism for what the test actually measures, which is lumen depreciation: the extent to which the lamp's light output falls over time. "All LED lights at some point are going to start losing the amount of lumens that come out of the light," Rosenfield said. "The industry has set a number, called L70, which basically represents 70 percent of the original light output, as the end of life for an LED." So, the industry defines an LED light bulb as dead when its output falls to 70 percent of what it was to begin with.
The problem, Rosenfield explained, is that LED light bulbs haven't been around long enough for the industry to have a good understanding of how their performance degrades over time. Instead an algorithm is used which, after 6,000 hours of testing, projects the number of hours remaining before the LED will reach L70. The 25,000-hour rated life of Switch's and other LED products has not been tested in full because doing so would take nearly three years. Instead this number is a projection based on the algorithm used. Even so, it's still a test that takes a significant amount of time. Depreciation, by the way, is non-linear, and light output can at times increase as well as fall away, Rosenfield explained.
There is a semi-shortcut, though. LED light bulbs are effectively electronics packages in which the LEDs are but one type of component. Being solid state lighting products themselves, the LEDs are eligible for testing under IES LM-80. If Cree, one of the LED manufacturers Switch has used for its bulbs, has its LEDs tested to 6,000 hours, Switch doesn't have to repeat the entire test. Switch's product can instead undergo a 3,000-hour (4.5-month) test to check that depreciation follows the expected pattern. "It's still an advantage to test for the entire 6,000 hours because we may be able to run longer than what the LEDs actually are claiming," Rosenfield said.
Quality control
Though LEDs may not generate heat to the extent of other light sources, they are very sensitive to heat, so equally, just as a well-designed light bulb might extend an LED's longevity, might a poorly designed one compromise it? "I think that many companies fall out of the Energy Star qualification process because of that, because they don't have sufficient thermal management which is one of our big advantages," Rosenfield said, alluding to the LQD liquid cooling system employed in Switch's bulbs.
"Also companies fall out because they don't have the full light distribution required. For example, with an 'A lamp,' you have to have, to get the full Energy Star standard, 170 degrees of radial flux or light distribution all around the product at generally the same intensity all the way around," he added.
To pass the Energy Star benchmarks, Rosenfield concludes, products must perform robustly as well as demonstrate long life. He also explained that the EPA will pick up Energy Star-certified products in the market place to ensure that their performance matches what was certified that the products are what they're being sold as, effectively.
The floodgates open?
But why is Philips' product the only "100-W equivalent" to have been certified? "They won't necessarily be the only one, because it's just a matter of when companies are able to start their testing," Rosenfield said. "The longest lead time of this whole process is the four and a half months initially for the LM-80 testing for at least a half the full test [] assuming you're working with an LED manufacturer that has already done their testing." Are Switch products going to be certified in the near future? "As a matter of fact we'll shortly be announcing the first set of our products that will be Energy Star qualified," said Rosenfield. "We're within days of that."
Though Switch has had products on the market for some time, it's worth bearing in mind that Switch is a start-up company whereas Philips is one of the world's largest lighting manufacturers not to mention one which manufacturers its own LEDs.
Osram Sylvania is another company with apparently eligible products. We asked it if Energy Star certification was on the cards. "The EnergyStar qualification is a very rigorous test with tight parameters," a spokesperson told Gizmag. "Some of the screw-based LED bulbs need to be tested for at least 6,000 hours (for example) and this can take up to nine months which is why some of our bulbs have not been qualified yet."
Though we also reached out to GE about its LED products, they declined to respond.
Official line
In an email to Gizmag, an EPA spokesperson confirmed the certification process. "To earn the label, the manufacturer of the product must be an Energy Star partner and obtain third-party certification of the product based on testing in an EPA-recognized lab," the EPA said. "The requirements for LED bulbs address efficiency as well as a number of performance related metrics such as light distribution, durability, lumen maintenance and color quality (both initially and over time). Higher lumen products are eligible for certification, as long as they meet all the requirements and complete all the necessary testing." It sounds as if a number of Energy Star LED products, 100-W equivalent A-lamps and otherwise, are headed for the market. This can only be a good thing. For LED products, Energy Star has set robust guidelines that should ensure that an Energy Star bulb is of high quality. Provided consumers know what to look for, perhaps LED can avoid the demonization that befell compact fluorescents.
Dont forget to read the comments
http://www.gizmag.com/energy-star-le...t-bulbs/27027/
mvadg is offline   Reply With Quote
Old 29th July 2015, 08:00   #5344
dre@ms's Avatar
Thanked: 172 Times
Originally Posted by CrackedHead View Post
I have used both and the Pigeon one is a little inferior when it comes to the material for the inner metal basket - BUT - I would buy it again in a heartbeat. Total VFM.
Isn't the size/volume of pigeon lower at 2.2 liters? It seems philips is around 3 liters.
Thanks all for the suggestions. Air fryer is being marketed on basis of,
1. Usage of no oil
2. Fry items which can be fried without oil
3. Health conscious
Believe me, we are planning to get the air fryer only to taste the McCain frozen foods. Not to experiment on food which we generally cook on a Sunday. Fish fry, Chicken 65 et al.
I have also seen in some videos that we can use a drop or two oil to make the food more tastier.
Fact is, if Pigeon can sell something for 4k, why a similar technology product being sold double the rate? Except for the capacity, what are the other pros and cons?
dre@ms is offline   Reply With Quote
Old 29th July 2015, 09:44   #5345
Prowler's Avatar
Thanked: 286 Times
I don't know about other units. I have a Philips fryer where the internal tray and the outer tray are coated with teflon. I would believe they would use better quality motor and heating element. This unit can run for up to one hour. Would all these justify the extra cost ?
Old 29th July 2015, 10:25   #5346
mayankk's Avatar
Thanked: 3,507 Times
I would suggest, if someone is in a quandary about air fryers, or even micros and otgs. Go for a halogen oven. It's the best thing for cooking and baking, and air frying. Slight issue with the "heat-food-instantly" function, you may miss a micro then. I've kept a small micro separately for that.
It's brilliant.
mayankk is online now   Reply With Quote
Old 29th July 2015, 15:46   #5347
dre@ms's Avatar
Thanked: 172 Times
Agree!! May be its too early to assume which one is long lasting. All reviews in online stores are based on the first cooking they have made. Moreover, Philips when launched was 15k and now its around 8k. So we may expect a price drop in the future?
Old 1st August 2015, 06:41   #5348
BenjiRoss's Avatar
Thanked: 116 Times
I was surprised to see the Needs supermarket in Gurgaon full of Finish. I do not think they will vanish without a trace. May be they are reorganizing.
Finally got intimation that the Finish items were shipped. Hopefully will receive it on monday. They sent it through some unhurt courier - Dotzot!
I have started using Fortune Dishwasher Tabs as they seem quite good too. They have recently increased their prices to about 13 Rs./tablet which is expensive.
I remember getting the Finish All In One tabs in Australia for 20 cents or less each - about Rs. 10 and they were way better than the dishwasher powder or these Fortune tabs. And Australia is supposed to be an expensive country!
Price of dishwasher cleaners in India will continue to be expensive till the demand picks up.
BenjiRoss is offline   Reply With Quote
Old 1st August 2015, 08:08   #5349
diyguy's Avatar
Thanked: 124 Times
Been buying finish from Bigbasket and get it same day usually. Earlier was buying off the finish website direct.
diyguy is online now   Reply With Quote
Old 3rd August 2015, 09:57   #5350
rajeshsundaram's Avatar
Thanked: 452 Times
Default JUICER Recommendations please...
I am searching for a good Juicer in the market.Heard Philips, Black & Decker are fine. But read mixed reviews about juicers from both brands. So I am even more confused.
Can anyone enlighten me with some recommendations for a no-nonsense, pocket friendly juicer?
My requirements are
- Easy to operate
- Reliable Construction
- Should extract juice from Carrots, Musk melons, oranges etc.
rajeshsundaram is offline   Reply With Quote
Old 3rd August 2015, 10:40   #5351
diyguy's Avatar
Thanked: 124 Times
I've always wanted to buy this Sujatha brand that I see in many cafeterias and juice shops. It's got to be tough as it makes 50-100 juices a day and has never broken down, atleast in my office. It's been there for 10 years now in the juice stall and works just great!
Old 3rd August 2015, 19:28   #5352
My 12 year IFB front loading Washing Machine at home has started giving problems.I am planning to discard it and buy a new one.
I am inclined towards the same brand as it has served me well over these years without a glitch, inspite of multiple home shiftings.
I am looking for a 5 to 6 kg machine without too much tech in it as mostly I tend to use only one or two options of wash programs.
Narrowed down the choices to LG, IFB, Panasonic.
http://www.flipkart.com/lg-f7091mdl2...NEFJBSC47Z4XUS
http://www.flipkart.com/panasonic-na...NE8XQF6RRXYXNW
Has anybody used Panasonic front loaders here, any reviews?
Secondly is it OK to buy such large appliances from FK? Any pointers will be of great help.
n.arun01 is offline   Reply With Quote
Old 6th August 2015, 12:59   #5353
Prodigy07's Avatar
Thanked: 277 Times
Hi All,
We are planning to replace our 5 yrs old Samsung Front Load washing machine.
Requirements:
a) 6.5 to 7 kg
b) Hard water resistant (or) capable of hard water intake
c) Fully Automatic
d) Front Load
e) Excellent after sales support/service and parts availability
f) Long Lasting (minimum 6 years)
g) Price range below 32K
I'm looking at Bosch and IFB.
Please throw in your suggestions!
Prodigy07 is offline   Reply With Quote
Old 6th August 2015, 17:21   #5354
Thanked: 1,011 Times
Originally Posted by Prodigy07 View Post
Hi All,
Requirements:
a) 6.5 to 7 kg
c) Fully Automatic
d) Front Load
I changed from IFB to LG. Got an extended warranty. Not a single problem in the last 3 years.
Modern WM have a lot of electronics, so are prone to vagaries of Voltage. The older IFB were purely elecromechanical, but their motor was prone to problems.
Aroy is online now   Reply With Quote
Old 6th August 2015, 17:44   #5355
Rodie09's Avatar
Thanked: 108 Times
Looking to buy an OTG for a 5 member family (if that count matters in determining the size).
Size wise will be going for 28 - 30 ltrs. I hope its fine for the family size.
Bajaj and Morphy Richards were the options most available but somehow am not comfortable with the Bajaj brand as they are not the best in any areas they operate. Morphy Richards, I came to know is also manufactured by the same Bajaj plant (even specs are same) and serviced by same people. So, didn''t want to go for that either.
Anyone has experience with GLEN of KAFF?
GLEN GL5030 is available on pepperfry for R7130/-
Rodie09 is offline   Reply With Quote
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
