Old 9th November 2015, 21:03   #5686
Thanked: 222 Times
Talking Re: The Home Appliance thread
mvadg, I wish I could thank posts in this thread: I love that you are "pig headed" in insisting on getting results from your toaster that you want, whether it is right use or not.
Wishing you many happy rounds of buttered toast --- made for you, just the way you like it
Let's celebrate our stubbornness!
Actually, all you "Rightist" people goaded me into trying out an OTG:
In celebrating our pig-headedness, I solemnly record my observations:
  1. OTG was supposed to be 'preheated' (already disqualified?!) for 10 min.
  2. Did not preheat, but set temp to 155 deg C and timer about 5 min and placed the bread slices for a little stiffening up to apply butter. (4 slices at one go)
  3. Removed hardened slices of bread, buttered them up both sides
  4. Replaced on grill, restarted timer (this OTG has top and bottom heaters)
  5. Watched the slices for a bit, no change, increase temp to 180
  6. Saw it turn a nice brown, hurriedly switched off - 2 burnt, 2 in the front were browned.
Total time nearly 25 mins - may be with experience 15 minutes? for toasting
4 slices. This was a cooking project! Not a toast and tea and get going thing.
My biased report: A toaster is best suited to toasting - quick, and once timed correctly, it will stop toasting and save your toast from burning and if not golden, another short cycle and its done.
The OTG is best for those gourmet cooks making something exotic with bread or baking something really delicious, umm...
Don't get me started on the energy consumption of the OTG vs toaster...
QED - Buttered bread MUST be turned into perfect golden toast in a toaster.
mvadg is offline   Reply With Quote
Old 9th November 2015, 22:16   #5687
Thad E Ginathom's Avatar
Thanked: 7,452 Times
Default Re: The Home Appliance thread
I can't give any comparative figures, because, even if it is going to end up as cheese-on-toast, I make the toast first, in a toaster.
Way back then, though, I used to have a stand-alone cooker with a separate grill, and I think it was fairly quick. It would have been gas, not electric, and some gas grills work but others are dreadful.
The worse problem with grill toasting is... burnt toast.
For my taste, toast will be buttered after toasting. I like the butter to melt in, but with some left on the surface. If you apply the heat to bread and butter, then you are cooking the butter and, partly frying the bread. I think there will be quite a difference, and I can understand that you have a strong preference.
Old 10th November 2015, 12:12   #5688
Thanked: 1,011 Times
Yes, I'll be much more careful with my new grinder, when I get one. The dead one was only a few weeks old. I am now fed up with crushing a pinch of mustard seeds in a mortar. I want them powdered in a second, like that grinder did. and I'm pig-headed enough to spend another 2.5K or more getting this exact same grinder again.
I would not advise using a power dry grinder for mustard seeds. The chemical which gives the mustard its characteristic flavour is destroyed when heated, that is why traditional wet grinding of mustard seeds is preferred. In fact seeds ground dry in a mortar, then mixed with water and strained to get rid of the skin is what is used in all our Mustard Fish preparations.
Old 10th November 2015, 23:15   #5689
That's interesting, thanks. The thing is, I am generally grinding for a fairly dry mixture like cheese-on-toast.
I had wondered if mustard seeds should be toasted (but not in a bread toaster ) but, from what you say, that would be a no-no.
I use yellow mustard seeds, by the way: I prefer the flavour to the more usual black.
Old 11th November 2015, 13:29   #5690
Mustard releases a chemical that has that characteristic mustard taste when the powder comes in contact with water. There is a slight difference between various varieties of mustard - sarso (smaller size), rai (larger size) and yellow. For Fish we use sarso and for dip the yellow one. For Kashondi I think it is rai. For Achar and Kanji I mix both in equal proportions.
Mustard is fried for tadka both for normal cooking and for Dhokla, never heard of it being toasted.
Old 11th November 2015, 13:32   #5691
archat68's Avatar
Thanked: 239 Times
Nowadays we're using Sunrise Mustard Powder. Quite good. It is readily available in Kolkata.
May be purchased online too:
http://mygrocery.co.in/grocery-stapl...wder-40gm.html
archat68 is offline   Reply With Quote
Old 12th November 2015, 01:17   #5692
Thank you, Aroy, for the Mustar Primer!
Old 12th November 2015, 17:04   #5693
diyguy's Avatar
Thanked: 123 Times
Need some advice - deciding between Samsung Side by side 580+L gross and 538 nett capacity vs Samsung two door 555L gross. The first one costs 76500 and the second one 54500. First one is fancy and is http://www.samsung.com/in/consumer/h...RS554NRUA1J/TL while the second one is traditional and here http://www.samsung.com/in/consumer/h...RT56H667ESL/TL
Any thoughts/experiences with these or similar models? I have two Samsung 320L ones at the moment and thought would replace one with this.
diyguy is online now   Reply With Quote
Old 12th November 2015, 20:17   #5694
If you have the space for it, keep two. I have two and found them much more useful than one large one. All that I know of the larger sizes is that they are fully imported and that their spares cost a bomb, hence smaller sized which have much better spares inventory (due to larger numbers sold) and cheaper repairs.
Old 12th November 2015, 20:48   #5695
hellmet's Avatar
Thanked: 637 Times
Anyone know if (and where) I can find spare parts for a Whirlpool refrigerator? I need to buy a new defrost timer but I wasn't able to find any information on Whirlpool's website about part distributors. Not sure if they have over-the-counter sale of parts.
hellmet is offline   Reply With Quote
Old 12th November 2015, 21:30   #5696
diyguy's Avatar
Thanked: 123 Times
Default The Home Appliance thread
Thank you for the reply. I have two and intend keeping two yet. Just getting the 17 year old one out for a better looking one and hopefully more efficient one. I am hoping I won't need repairs as both my fridges so far haven't needed any (touch wood). The 17 year old is actually a made in Korea import and was the first frost-free from Samsung when we purchased it...
Old 15th November 2015, 19:32   #5697
Thanked: 33 Times
Default Geyser & Room Heater
The cold, clammy weather that has persisted for more than a week has gotten under my skin by now. Plus its been a week since my solar water heater gave hot water. Driven to despair, I am seriously thinking of buying a geyser for the first time in my 10 years at Bangalore.
Can someone suggest some good brands/models to look into?
Since I expect the solar water heater to start working once there is some sunshine, I am looking for a long lasting, reliable model that would last for years even if used for only up to a month every year.
While in this situation, I am also wondering whether I should buy a room heater or leg warmer. Any tips would be appreciated.
nowwhat? is offline   Reply With Quote
Old 15th November 2015, 20:12   #5698
This is a bad time for our solar water heater too. Essentially, it... isn't.
However, it is a very short season, here in sunny Chennai, during which it does not give hot water. We fall back on the stove and buckets
Old 15th November 2015, 20:23   #5699
diyguy's Avatar
Thanked: 123 Times
Actually I was in Yelagiri from the 8th to the 12th and was surprised that it was giving us boiling hot water. They had solar panels and in muggy and rainy conditions it was still working well! In fact this made me think I should be getting one for our home
The staff confirmed that it is only a solar heater for each building in the resort! It rained nonstop from the 9th to the 12th.
Old 15th November 2015, 23:17   #5700
mobike008's Avatar
Thanked: 8,036 Times
Guys : Need urgent help in suggestions for a Microwave < 10K
Any brands/model no's with source info (online/brick & mortar) would be really helpful
Thank you !!!
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
