Old 24th November 2015, 21:29   #5716
sgiitk's Avatar
Thanked: 3,855 Times
Infractions: 0/1 (4)
The electronics differs totally. You can buy a neon pilot lamp, break the housing and then use it.
Old 24th November 2015, 22:01   #5717
saket77's Avatar
Thanked: 4,804 Times
Default Re: The Home Appliance thread
Originally Posted by hellmet View Post
Thank you. Now I know what it is! Can I replace it with an LED bulb somehow? Not sure where I'd find them.
You may try fixing an LED with a 100K resistor. It should work in my opinion. Expert's comments always welcome.
saket77 is offline   Reply With Quote
Old 25th November 2015, 03:43   #5718
Thad E Ginathom's Avatar
Thanked: 8,208 Times
I suppose this pilot light must have one leg to live, and one to neutral. The consequences of getting it wrong could be unpleasant. I don't think trial and error would be good here.
Old 25th November 2015, 07:54   #5719
techiecal's Avatar
Thanked: 62 Times
Can someone help me with what this bulb is called? This is a green color bulb that conked off in our water heater recently - I've not been able to find these in the usual electrical shops.
Back in the good old days I used to get these bare neon lamps in red and green color in the electronics market. They used them in all electrical goods as a power indicator. Lately, they are not available bare but you will still get them as panel indicator lights in the electronics shops. Just pull the lens of the assembly and you will be able to get the neon lamp out. They do not cost much either.
techiecal is offline   Reply With Quote
Old 25th November 2015, 09:43   #5720
Prowler's Avatar
Thanked: 300 Times
A LED requires a lot more components for such a simple job. Getting a neon bulb shouldn't be much of a problem. Or ask for a neon mains indicator from an electrical shop and remove the neon indicator and its series resister from the plastic unit. You can source one from here: https://www.industrybuying.com/indic...SW.IN5.414160/
These neon gas bulbs are not polarized unlike semi conductors. As long as you have a current limiting resister in series which restricts the current, they are happy to lead a long life.
LEDs are good in a low voltage DC application and when connected directly across the AC mains, they tend to fail unless you use an elaborate circuit.
Sorry about the back to back posting.
Last edited by Gannu_1 : 26th November 2015 at 08:48. Reason: Back to back posts merged. Please use the multi-quote feature (QUOTE +) to quote and respond to multiple posts.
Prowler is offline   Reply With Quote
Old 25th November 2015, 18:08   #5721
It would be getting the resistance right that would worry me. Could they explode if overpowered?
Old 25th November 2015, 18:30   #5722
SunnyBoi's Avatar
Thanked: 2,826 Times
Nope, they will heat, to an extent that it will melt plastic.
Since we're taking about a single LED here, even the basic quarter watt resistor will suffice and wont cause heat issues.
SunnyBoi is offline   Reply With Quote
Old 25th November 2015, 18:49   #5723
Prowler's Avatar
Thanked: 300 Times
The original NE2 would be good to sink up to 20 mA and here we barely pass about one milliampere with a 150k series resister.
These neon gas tubes work like this:
Until a predetermined voltage across their terminals occurs they are open (not conducting). Once their threshold voltage occurs, the gas starts conducting and presents a low resistance across the terminals. This can be useful in many applications : Surge arresting, voltage stabilization to name a few.
Old 26th November 2015, 08:35   #5724
sgiitk's Avatar
Resistance value barely matters as long as it is 120k or more. I used 270k - slightly lower brightness, but that barely mattered.
Old 26th November 2015, 14:50   #5725
fine69's Avatar
Thanked: 868 Times
Can someone explain to a layman (me) why is it advisable to use a surge protector than a voltage stabilizer with a TV.
Using a time-delay stabilizer makes sense for something like a fridge because we don't want the compressor starting stopping starting in a difference of 1 or 2 seconds but why wouldn't a stabilizer protect the TV from low voltage and high surges?
fine69 is offline   Reply With Quote
Old 26th November 2015, 16:04   #5726
Prowler's Avatar
Thanked: 300 Times
Modern TV (as well as a computer) uses a Switch Mode Power Supply (chopper power supply) which 'transforms' the AC mains input at 240 V in India at 50 Hz/220 V in Europe/ 110 V at 60 Hz in the USA to lower DC voltage using high speed semiconductor devices operating at higher frequencies for better overall efficiency as well reduction in size.
As a result, these TVs can operate from about 110-240V without any external assistance. A relay based stabilizer - the kind you use for Airconditioners and Refrigerators tends to chatter at some voltage levels and don't switch fast enough to the next level - resulting in momentary over voltage. This causes transients in the supply to sensitive semiconductors which may breakdown. A surge protector has no moving parts like a relay or any inductive component like a transformer to cause any transients. Thus it is safer to use a well designed surge protector than a simple stabilizer.
A metal oxide Varistor (MOV) in a surge protector shorts the supply at its designated voltage protecting the devices downstream from any over voltage, line transients and lightening surges. They can pass high currents from 20 A to a lot more when they start conducting tripping a MCB or a fuse before the device. They are usually padded with suitable capacitors to bypass dangerous RF transients.
Old 26th November 2015, 17:01   #5727
mtnrajdeep's Avatar
Thanked: 100 Times
Voltage stabilizers have a reaction time that is longer than the duration of a surge (which are of milli/micro second duration). By the time they can react & stabilize the voltage, the surge would have passed through to the connected devices and destroyed them.
Hence, it is better to have a surge protector first. It can be followed by a voltage stabilizer in the circuit.
This is the most plausible explanation that I could find after searching a lot on the internet. Makes sense as well to an electrical engineer like me.
mtnrajdeep is offline   Reply With Quote
Old 26th November 2015, 17:16   #5728
saket77's Avatar
Thanks for the post. Can you please do us a favour of posting a link of one such surge protector being sold online. Would like to have it to protect my analog rig. Please do it in leisure.
Thanks.
Old 27th November 2015, 08:21   #5729
mobike008's Avatar
Thanked: 8,160 Times
Bought this microwave from Amazon. Ordered on Monday and received it yesterday. Pretty good service
Overall happy with delivery time. Hope the product works as per the user reviews
Old 27th November 2015, 10:26   #5730
Thanked: 1,047 Times
Voltage surges are of very short duration - milliseconds so they rarely burn normal electrical gadgets - irons, bulbs motors. The voltages are high at times going beyond 1000V. For electronics that is death.
Surge protectors "Blow" very fast isolating the downstream circuits. In contrast voltage stabilizers are slow with reaction of few tenths of a second at the most. By the time they react to the surge voltage, it has passed through and done its damage.
As most of the appliances today (TV, AC, Refrigerators, MW etc) have electronics for control and optimum operation, a surge protector will protect them against failure of the "Mother Board".
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 764 26th April 2018 11:37
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
