Old 10th December 2016, 06:38   #6226
BenjiRoss's Avatar
Thanked: 148 Times
Default Re: The Home Appliance thread
Originally Posted by diyguy View Post
Did you go for the Wipro one? Am considering LED tubes myself but would like a philips one if there is one.
Yes, I bought the wipro tube light from Snapdeal.
BenjiRoss is offline   Reply With Quote
Old 10th December 2016, 16:03   #6227
diyguy's Avatar
Thanked: 175 Times
Thank you for the confirmation. Are the other colors apart from pure white good for health or the eyes in some form? Reason I ask is I read a lot at nights and used to get eye pain when using a book light clipped to my book. Then I moved to my iPhone to read and it didn't help. Recently I started using the night mode on the phone and this removes blue color from the phone's screen and this has helped me significantly. I don't get the eye pains anymore. If the tube's alternate colors help I would still prefer to use a normal book and use the night mode (one of the colors) of a led tube light.
diyguy is online now   Reply With Quote
Old 10th December 2016, 17:02   #6228
khoj's Avatar
Thanked: 1,256 Times
I am looking to buy a four burner built in hob with maximum cut out dimensions of 60cm 60cm. Fuel will be piped natural gas, any recommendations on makes & models and suggestions/pointers on what to look out for.
Old 10th December 2016, 17:42   #6229
diyguy's Avatar
Thanked: 175 Times
Have a look at Elica, they have a great looking and performing range. I went for them mainly due to the looks and the fact that they have a 5 jet burner in the set of 4 or 5. The flame is always blue and the brass burners were elegant in black. It is now two years or so since we purchased and very happy with the decision.
This is similar to one we have
Old 12th December 2016, 14:51   #6230
diyguy's Avatar
Thanked: 175 Times
Found this useful guideline on my fb wall on how to select the right LED for your home. It's quite scary that fb seems to know my search and interest outside of the app as well.
Old 12th December 2016, 21:07   #6231
Thanked: 255 Times
Why not just use a white incandescent bulb? No need to worry about CRI and other complicated parameters. And cheap too! Enjoy the tungsten bulb while it is still available, soon these will be sold at fancy "classic" prices.
mvadg is offline   Reply With Quote
Old 12th December 2016, 21:45   #6232
Guite's Avatar
Thanked: 182 Times
Attachment 1584276
While colour is subjective, I would go for combination of high as well as low colour temperature for the living room. Depending on the guests you are entertaining and the mood you want to create, switch on a set of 3000k or set of 6000k lights or combination thereof. The range available in the market is very limited. You get mostly 3000k and 6000k, not much else.
Similar scheme can be done in the bedroom, to create a personal and private mood lighting.
Guite is offline   Reply With Quote
Old 13th December 2016, 18:21   #6233
TorqueyTechie's Avatar
Thanked: 1,128 Times
Folks, any suggestions for a good table top wet grinder?
TorqueyTechie is online now   Reply With Quote
Old 17th December 2016, 20:35   #6234
kmsithan's Avatar
Thanked: 51 Times
Ultra is my choice. I bought one for my mom and it is working pretty well for last 5 years. My mom uses it everyday.
I have bought the same and it is going good for 3 years now. It has a timer too.
kmsithan is offline   Reply With Quote
Old 17th December 2016, 21:28   #6235
Thanked: 80 Times
Guys better to install a 3 litre instant geyser for immediate hot water or install a 15 litre regular geyser and turn it on 15 min before washing dishes?
rana_kirti is offline   Reply With Quote
Old 18th December 2016, 00:51   #6236
Thanked: 226 Times
Depends on how cold the water is?
In Chandigarh we used to use an instant geyser. The same turned out to be ineffective in Himachal so shifted to a 6L regular geyser which works fine for our use.
rdst_1 is offline   Reply With Quote
Old 18th December 2016, 02:45   #6237
khoj's Avatar
Took a look at Elica, Faber, Kaff, Whirlpool & Siemens while searching for a desirable built in hob.
Does anyone here have experience with Siemens hobs, in terms of availability of service, spares etc.
Old 18th December 2016, 02:49   #6238
Thanked: 226 Times
Most of the experiences I have heard of are bad when it comes to built-in hobs.
Why don't you take a look at cooktops which, when placed properly can achieve the same look as a built-in hob without the inherent issues.
Old 18th December 2016, 08:20   #6239
diyguy's Avatar
Thanked: 175 Times
I saw all these brands (except whirlpool) as well but the price of Elica was far lower than equivalent in Siemens.
Forgot to mention I purchased the hob but attached legs to it and use it as a cooktop. The hobs look far more refined than the cooktops out there.
Old 18th December 2016, 08:36   #6240
NPV
NPV's Avatar
Thanked: 5,163 Times
Well, then it's time to hear about a good experience as well
Back in 2002, we bought a Faber chimney and it came with a Hob free. Had that installed after cutting the granite slab of the kitchen counter to accommodate it. We have had zero issues in 12 years. Only the rubber switch cover for the stove ignition (Rs.5) has been replaced a few times. The labels beside the knobs (indicating which burner the knob is for) have disappeared but that's about it, works perfectly.
Cooktops cannot match flush fit and finish of hobs, not to mention ease of maintenance and optimisation of available space on the counter.
NPV is offline   Reply With Quote
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 764 26th April 2018 11:37
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
