Old 3rd February 2010, 23:15   #751
Spitfire's Avatar
Thanked: 692 Times
Infractions: 0/1 (7)
Had a very good experience with LG Service. Our top loading washing machine couldn't hold the water. Sometime early morning the problem was detected. It was the 26th Jan and we thought LG wont be working anyways gave a cal lto their customer care.
The guy on the other end took the complaint and gave me a number and said a technician will call in 2 hours.
I asked its a public holiday today, you will get one?
He said yes. Surprised I said ok.
Wonder of wonders the technician calls in 1 hour and is at my residence in another couple of hours.
Finds out the faulty part. Says it needs to be replaced. Goes away comes back in another 2 hours and our machine is back to its chores.
AMAZING and FIRST CLASS SERVICE. I am a LG customer for life.
Spitfire is offline   Reply With Quote
Old 4th February 2010, 02:14   #752
navan49's Avatar
Thanked: 69 Times
Good on Site Service by Samsung,
Just a month before the warranty expires my Samsung LCD Tv was blown up due to fluctuation. I called the call center and lodged a complain. Immediately the next morning a service person came and checked and told the spare is gone and needed to get it and with regret asked a week's time. But to our surprise on service person came with the spare and made the tv function. I di not have the bill or warranty card but they were very co operative and done the job with out a cup of tea.
navan49 is offline   Reply With Quote
Old 4th February 2010, 03:06   #753
JMaruru's Avatar
Thanked: 103 Times
Default LG it is..
LG seems to have the best customer satisfaction. No doubt they are the market leaders in most of the consumer durable segments. I have a LG top loading washing machine for almost 8 years now, and there has been not even one single issue, as of now. Touchwood!
JMaruru is offline   Reply With Quote
Old 4th February 2010, 09:12   #754
Latheesh's Avatar
Thanked: 2,691 Times
Yes,
My friend was looking for a refrigerator and top loading washing machine few weeks back. Got LG and he is happy with it.
Latheesh is offline   Reply With Quote
Old 4th February 2010, 13:42   #755
Edsel Rulez!'s Avatar
Thanked: 9 Times
LG seems to have the best customer satisfaction. I have a LG top loading washing machine for almost 8 years now, and there has been not even one single issue, as of now. Touchwood!
I can second that. My LG top-loader was bought in 2000 for about Rs 10K and it's worked for a decade without a single repair or service job. All I do is clean out the lint bag once a month. I use it at 4-5 times a week. It's time to upgrade to a larger unit, but I'm worried a modern replacement may not prove as durable!
Edsel Rulez! is offline   Reply With Quote
Old 4th February 2010, 16:27   #756
DieselFan's Avatar
Thanked: 233 Times
I haven't yet replaced my LG front loader which is already 9 years old for the same reason. Even though the noise levels have gone high I am prolonging the replacement till it brakes down.
DieselFan is offline   Reply With Quote
Old 4th February 2010, 16:31   #757
sgiitk's Avatar
Thanked: 3,794 Times
Infractions: 0/1 (5)
@DieselFan: You can get the bearings replaced from LG. Will cut the noise drastically.
Old 11th February 2010, 20:40   #758
Raccoon's Avatar
Thanked: 105 Times
Originally Posted by abhipuru16 View Post
Hi fellows!
I recently bought an IFB Neptune dishwasher but am facing a problem. I see a yellow blackinsh layer on some stainless steel utensils , the heavy ones and ones in which we boil our tea. I do rinse the utensils before loading them into it. Whats the problem? What level do I need to adjust? Detergent or Rinse-Aid? I am confused.
Help!
May be due to iron. Do you include iron vessels in the washload? Try avoiding them and check. May be due to Fe in the water too. Also make sure the salt setting is just right for the degree of hardness in your tapwater. Don't take the technician's world for this unless you check for ourself.
You don't really have to rinse all vessels before putting them in. It wastes a lot of water and is not really required. Just make sure there are no chunks of food, seeds, etc. Mostly light scraping is enough for most vessels.
Old 11th February 2010, 20:44   #759
lohithrao's Avatar
Thanked: 163 Times
Folks i need to pick few stuffs very soon, need some suggestion..
Fridge 300lts: Samsung or LG?
Grinder: Morphy richards or Philips?
Water filter: Aqua guard or Philips?
lohithrao is offline   Reply With Quote
Old 11th February 2010, 21:12   #760
Thanked: 1,000 Times
Fridge - Have LG at home 2 door [not sure if is 300 lt though] and is really good with door cooling etc. Its also 5 star rated by BEE
Grinder - No idea. From hearsay, both are equal.
Water purifier is what you meant probably - Have an aquaguard with e-boiling [no RO]. Has been serving well for the past 1.5 years. the service was done very recently where the candle was changed for 450 bucks.
abhinav.s is offline   Reply With Quote
Old 12th February 2010, 09:27   #761
mithun's Avatar
Thanked: 49 Times
Fridge : Samsung
Grinder: Also try Panasonic
Water filter: Also try the one from HUL
Old 12th February 2010, 10:21   #762
DieselFan's Avatar
Thanked: 233 Times
thanks SG will check this out.
Old 12th February 2010, 10:31   #763
shishir_bn's Avatar
Thanked: 104 Times
Dude for water filter go for a RO system if the water connection in your house is a bore well.I suggest for KENT RO system if going for RO.If it is not a bore well water where the ppm is less than 220ppm then you can go for Aqua guard.If the ppm is more than 400-500ppm then it is better and good to go for RO. Usually bore well water has more than 600-700ppm salt.Think about it.I have KENT RO from past 3 years as the water in our building is bore well water and it has salts upto 780ppm.After using RO the new reading is 50-60ppm.So think and buy.
shishir_bn is offline   Reply With Quote
Old 12th February 2010, 12:47   #764
benbsb29's Avatar
Thanked: 3,532 Times
Lohith, both Samsung as well as LG would give you reliable operation, and so its wise to choose either of the two. I have a Samsung refrigerator since the past 3+ years, which has been functioning really well. Personally, i would go for a Samsung.
Old 12th February 2010, 13:05   #765
lohithrao's Avatar
Thanked: 163 Times
Thanks guys for all the inputs.
Benny, even am keen on "Samsung", guess will pick it.
AM pretty confused about "water filter", we have had "Aqua guard(RO) at home for a long time and are very happy with it. just that their service is not very good!
Home Construction/Makeover/Maintenance Thread Latheesh Shifting gears 739 17th January 2018 17:14
Building a truck camper : Home away from home DKG Modifications & Accessories 140 18th February 2016 18:40
Bringing home the Mahindra Scorpio LX. EDIT : Scorpio finds a new home! benbsb29 Test-Drives & Initial Ownership Reports 168 8th January 2015 11:22
Joining a domain: XP home Vista Home Premium johy Shifting gears 0 22nd November 2007 17:14
Home Audio thread with inputs from the ICE forum gunbir Gadgets, Computers & Software 13 3rd August 2006 11:45
