Old 13th April 2009, 11:05   #136
JMaruru's Avatar
Thanked: 107 Times
Originally Posted by ImmortalZ View Post
Well fine. I guess my laptop has a magic elf in it just making the 250GB HDD work fine without a LBA48 bit addressing compatible BIOS.
I'll say this for the last time. You can use whatever size HDD in your laptop without the BIOS support as long as you have a WinXP SP2 or later OS and partition sizes less than 128GB.
That sounds too good , but is there any site where the same information has been verified.
JMaruru is offline   Reply With Quote
Old 13th April 2009, 12:11   #137
ImmortalZ's Avatar
Thanked: 312 Times
Here's one :
48-bit LBA (Dell Inspiron 6000) [Archive] - boards.ie
Old 14th April 2009, 17:45   #138
JMaruru's Avatar
Thanked: 107 Times
@ImmortalZ: Thanks
What is the reasonable price for 160GB IDE 2.5" HDD in b'lore ?
Old 15th April 2009, 02:00   #139
Nitin's Avatar
A quick question:
I had mentioned earlier that my desktop's HD crashed a long time ago.Fellow BHPian Mohit was kind enough to send me all the info I needed on the Dell Dimension 2300 system I have.
I'm sure its possible to use an external hard drive on a desktop.How feesible is this? What are the pros & cons? Also, assuming the connection is through a USB cable, won't the system be real slow (and probably hang a zillion times) ?
Nitin is offline   Reply With Quote
Old 16th April 2009, 00:21   #140
Thanked: 660 Times
Originally Posted by Nitin View Post
A quick question:
You can use external hdd for storage. For instance i have 5. 3 for movies. 2 for backup. But you will need USB 2 interface. Does above system has USB2?
Old 16th April 2009, 00:38   #141
Nitin's Avatar
yes, it does. Anyway, its probably a better idea to have an internal HD, and use an external HD for backup of files. Will look into it and get back if I face any other issues. Thanks,SirAlec.
Old 17th April 2009, 07:07   #142
Thanked: 124 Times
Default Hdd
As per your post your HDD spins for around 2 minutes or so
I suggest you take out your HDD, put in a air tight zip lock bag, put in in the freezer for 3-4 hours. Make sure the bag is airtight, otherwise there will be condensation and more damage.
You can extract around 20 minutes of life.
The best way to do this is to use the HDD in an external casing. Keep the computer booted up, plug in the extern casing through USB, and start transferring.
If this does not work you need expertise in using programs like ddrescue(open source hence free), otherwise you will need to pay someone to do it for you.
If you know somebody proficent in linux, I suggest you try something from here
10 Best Security Live CD Distros (Pen-Test, Forensics & Recovery)
List of LiveDistros - Wikipedia, the free encyclopedia
The Freezer Trick may sound insane, But it has worked for me!
YaeJay is offline   Reply With Quote
Old 17th April 2009, 13:49   #143
Thad E Ginathom's Avatar
Thanked: 8,377 Times
My hard disk crash...
I put my computer on it's side, removed the side panel, and thought I'd power up one more time. Wonder of wonders, the disk started up without the horrible clunking noises, was recognised, and I was able to recover all the data from it to another drive.
Worth a try!
I was lucky: it was the absolutely last breaths for that drive.
Old 17th June 2009, 15:43   #144
Thanked: 2,522 Times
Need help guys,
Dropped my external 250GB HD and as I feared, it is no longer being detected. I keep hearing this faint beep 2 seconds apart. Is it gone? or can the data be still recovered? It was filled to the brim, if I may say so.
Dry Ice is offline   Reply With Quote
Old 18th June 2009, 01:11   #145
Thanked: 660 Times
Its a portable one or desktop one? If desktop one try to open it up and connect to the SATA or ide port of your PC.
in both cases open it up and chek if it got deatch to its controller.
Old 18th June 2009, 01:47   #146
Thanked: 11 Times
Need help guys.. I have the hp pavilion dv6928us laptop.. it is not at all booting. when i ran the diagnostics in bios, it says 'replace the hdd'. I can change the hdd but my concern is about the data. I have around 200GB of data in it. Is there a way to recover the data?
Ford_madhan is online now   Reply With Quote
Old 18th June 2009, 07:47   #147
Thanked: 253 Times
Take the HDD out of the laptop, put it in an external enclosure and plug it into another computer. You'll know whether the HDD works. It could be a software problem preventing the laptop from booting.
Old 18th June 2009, 19:05   #148
Portable, SATA.
My desktop is quite old, no SATA port, features the previous gen HDs ( -ATA I believe??) Opened it up, connections are all fine. But just to be sure, disconnected and re-connected it. No luck!!
Will try doing what you said on someone else's PC who has a SATA port.
Thanks for the help.
In the worst case, can the data still be recovered? If so, what kinda figures am I looking at?
Old 18th June 2009, 19:47   #149
NetfreakBombay's Avatar
Thanked: 402 Times
7 - 10k.
basically "recovery" would involve extracting disks out of current HDD, putting it onto another HDD (with same controller / electronics).
usually this will get most of data since only the area where head as actually scratched the disk would be bad.
Old 18th June 2009, 20:36   #150
Thanked: 660 Times
Portable, SATA.
You do that! and post the result here.
Data recovery is an expensive work. find nearby places. on last resort send it to me will be happy to do it for u.
USB Hard Disk to Home Theater autoenthusiast Gadgets, Computers & Software 0 20th August 2008 21:36
Help to fix my hard disk in my car raajsree In-Car Entertainment 2 30th June 2008 00:37
Need Urgent "HELP" on Hard-Disk ramie2400 Gadgets, Computers & Software 21 31st May 2008 17:34
How to ADD a Hard Disk partition in Vista kb100 Gadgets, Computers & Software 21 14th May 2008 21:13
Help: DVD rip to hard disk v1p3r Shifting gears 25 11th January 2006 18:33
