| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more! |
| | Thread Tools |
| | #17 (permalink) |
| Newbie Join Date: Jun 2006 Location: Bangalore
| hey.. most cases the disk is not detected because of corruption of file system (like MBR etc). Best way to determine this is to check if the drive is displayed (My Computer->Manage->Disk Management). If the hdd is detected, the volume info can be passed to chkdsk which may help to recover the file system. All said, if there is h/w issue with hdd, then I think u need professional help like other have recommended. |
| | #19 (permalink) |
| Distinguished - BHPian ![]() | I am using my cell phone to access Team-BHP. Thanks for the replies. Chkdsk: The HDD is not detected at all even in safe mode. Due to this you cannot perfor any operations on it. Its as good as if its not connected. Freezer trick: This seems quite risky. Wouldn't try it myself. Data recovered till date: Zero. About Backup: That was my biggest mistake. I was waiting till i get a dvd writer since it has more storage capacity and requires less dvds. Will take frequent backups henceforth. Anyways, the engineer gave me a contact who is an expert in data recovery. Will call him today and check his rates.
__________________ Team-BHP.com > Motorbikes > Yamaha Cafe Racer |
| | #22 (permalink) |
| Team-BHP Support ![]() Join Date: Oct 2005 Location: Hyderabad
| Gordon, maybe you can try one trick. Nowadays, there are USB casings available for normal HDDs. These enable a hard-disk to be hot swappable and obviates the need for pre-detection in the BIOS. Check if you can reach the drive using USB. If there is some problem in the board (slot) because of which the HDD is not getting detected then this trick may help. Also, if there is an adjacent slot available (some boards do have two HDD slots) maybe you can take the cord out from its current slot and try putting it in the other vacant slot and see if that works. |
| | #23 (permalink) |
| BHPian Join Date: Oct 2005 Location: NA
| I friend has given me a Laptop to look at as it does not run properly. I have run HDATA2 on it and it looks as if the HDD is faulty. There are lots of Unrecorrectable CRC or ECC errors on read. Is there any software out there that could mark these as bad and allow the HDD to be used ? Thanks in advance. |
| | #25 (permalink) | |
| Quote:
Thanks. I just needed a stopgap arrangement to be able to use the laptop. I have ordered another one but it will take another week to arrive. There is no data on the HDD that I need. I just wanted to get it up and running so he can access internet etc. Last edited by bigman : 17th October 2007 at 14:16. | |
| | #26 (permalink) |
| BHPian Join Date: Feb 2007 Location: Kolkata
| I am not sure if I'm posting this too late. Have you tried HDD Regenerator? It's available as a free download.
__________________ The most exciting phrase in science is not "Eureka" (I found it) but probably "That's funny...."! |
| | #27 (permalink) |
| BHPian Join Date: May 2007 Location: Delhi ---- Noida
| Hii bhpians For all kinds of computer related softwares go on to the site MajorGeeks.com - Download Freeware and Shareware Computer Utilities. the site has all the essentials softwares & freewares that will solve your computer related problems.. ![]()
__________________ “Champions aren´t made in the gyms. Champions are made from something they have deep inside them - a desire, a dream, a vision.” |
| | #28 (permalink) |
| BHPian Join Date: Oct 2006 Location: Bangalore
| Fellas, my computer screen just went blank yesterday. The LCD monitor turned off. I tried restarting in normal mode/safe mode/ last settings that worked mode. In all cases, windows startup screen showed up but after that the screen would again go blank. I have never had an encounter of the HDD crashing kind before but Vid tells me this is what it is. Need some help guys. Please suggest how I could try and recover the data. Thanks |
| | #29 (permalink) | |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay / New York
| Quote:
However, recovering data should be easy > just put your current HDD in an external enclosure / or set it up as a secondary drive (not a boot drive) and boot from something else. You should be able to access your data then. cya R | |
| | #30 (permalink) |
| Some other symptoms, don't know if its connected in anyway. My UPS has been making strange noises last couple of days. When I start it up, for about 3 min there is a loud grinding sort of a noise, of the type that would be characteristic of a winding rotatating. Slowly the sound fades away |
| Thread Tools | |
Similar Threads | ||||
| Hard disk upgrade query | mohit | Gadgets, Computers & Software | 7 | 11th September 2008 19:03 |
| USB Hard Disk to Home Theater | autoenthusiast | Gadgets, Computers & Software | 0 | 20th August 2008 21:36 |
| Help to fix my hard disk in my car | raajsree | Ask the Gurus | 2 | 30th June 2008 00:37 |
| Need to recover Data from my Extnl 200 GB USB Hard Disk | muni | Gadgets, Computers & Software | 7 | 14th March 2006 22:19 |
| Help: DVD rip to hard disk | v1p3r | Shifting gears | 25 | 11th January 2006 17:33 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
