Old 17th October 2007, 13:04   #31
Thanked: 21 Times
Default Faulty Laptop HDD
I friend has given me a Laptop to look at as it does not run properly. I have run HDATA2 on it and it looks as if the HDD is faulty. There are lots of Unrecorrectable CRC or ECC errors on read.
Is there any software out there that could mark these as bad and allow the HDD to be used ?
Thanks in advance.
bigman is offline   Reply With Quote
Old 17th October 2007, 13:51   #32
spadival's Avatar
Thanked: 16 Times
I suggest you change the HDD instead of trying to fix it. Atleast, right now you are able to recover the data on the drive. It will soon reach a point where the HDD will stop working all together.
spadival is offline   Reply With Quote
Old 17th October 2007, 14:12   #33
Thanked: 21 Times
Thanks. I just needed a stopgap arrangement to be able to use the laptop. I have ordered another one but it will take another week to arrive. There is no data on the HDD that I need. I just wanted to get it up and running so he can access internet etc.
Old 4th November 2007, 15:44   #34
nura's Avatar
I am not sure if I'm posting this too late. Have you tried HDD Regenerator? It's available as a free download.
nura is offline   Reply With Quote
Old 5th November 2007, 12:48   #35
Awaiting Email Confirmation
Hii bhpians
For all kinds of computer related softwares go on to the site
MajorGeeks.com - Download Freeware and Shareware Computer Utilities.
the site has all the essentials softwares & freewares that will solve your computer related problems..
Nos007 is offline   Reply With Quote
Old 8th November 2007, 18:04   #36
MC Mayank's Avatar
Fellas, my computer screen just went blank yesterday. The LCD monitor turned off. I tried restarting in normal mode/safe mode/ last settings that worked mode. In all cases, windows startup screen showed up but after that the screen would again go blank.
I have never had an encounter of the HDD crashing kind before but Vid tells me this is what it is.
Need some help guys. Please suggest how I could try and recover the data.
MC Mayank is offline   Reply With Quote
Old 8th November 2007, 23:19   #37
Rehaan's Avatar
Thanked: 24,828 Times
This could be due to a lot of things, not neccessarily your HDD crashing.
However, recovering data should be easy > just put your current HDD in an external enclosure / or set it up as a secondary drive (not a boot drive) and boot from something else. You should be able to access your data then.
cya
R
Old 9th November 2007, 08:25   #38
MC Mayank's Avatar
Some other symptoms, don't know if its connected in anyway. My UPS has been making strange noises last couple of days. When I start it up, for about 3 min there is a loud grinding sort of a noise, of the type that would be characteristic of a winding rotatating. Slowly the sound fades away
Old 9th November 2007, 09:19   #39
sfilinto's Avatar
To me this looks like a hardware issue & no software will help you until the harddisk is detected in the bios.
i have used the refrigirator trick to some level of sucess in the past. you could try that if the issue is with the spindles. if this is an issue with the board then the only way would be to replace it from a working hdd.
sfilinto is offline   Reply With Quote
Old 9th November 2007, 11:02   #40
Rehaan's Avatar
Is that coming from your UPS or your HDD ?
Have you tried plugging the computer directly into mains?
Originally Posted by sfilinto View Post
To me this looks like a hardware issue & no software will help you until the harddisk is detected in the bios..
If this is a reply to MC mayank, his computer is detecting the HDD in the bios (since its starting to boot windows), if its a reply to the earlier problems, then ignore my message.
cya
R
Old 9th November 2007, 11:50   #41
MC Mayank's Avatar
The sound is from the UPS. I'll get back home and confirm. And ya was thinking of plugging the computer to the mains directly. Will try to do that as well and let you guys know
Old 9th November 2007, 12:05   #42
gopz's Avatar
Try this FREEWARE program for data recovery (including formatted drives)
Freeware file recovery software to undelete files or recover lost files
gopz is offline   Reply With Quote
Old 11th November 2007, 19:31   #43
MC Mayank's Avatar
I connected the PC to the mains directly, it works fine and thank God for that. So looks like the UPS is gone. Why would the UPS cause such an effect on the windows starting up? The CPU still remains powered up so what could be causing this sort of behaviour.
PS:While fiddling around with the cables at the back, I dropped the CPU. Since then, the mouse has stopped working. What do I do?
Old 11th November 2007, 23:42   #44
Amey's Avatar
Thanked: 189 Times
Try resetting the CMOS, see if the Mouse works, is it a PS2 or USB mouse ?
Tried connecting another Mouse ?
Amey is offline   Reply With Quote
Old 12th November 2007, 10:57   #45
MC Mayank's Avatar
I connected a USB mouse and it works fine. The PS2 is not working. How do you reset the CMOS?
USB Hard Disk to Home Theater autoenthusiast Gadgets, Computers & Software 0 20th August 2008 21:36
Help to fix my hard disk in my car raajsree In-Car Entertainment 2 30th June 2008 00:37
Need Urgent "HELP" on Hard-Disk ramie2400 Gadgets, Computers & Software 21 31st May 2008 17:34
How to ADD a Hard Disk partition in Vista kb100 Gadgets, Computers & Software 21 14th May 2008 21:13
Help: DVD rip to hard disk v1p3r Shifting gears 25 11th January 2006 18:33
