Old 20th February 2009, 19:43   #76
JMaruru's Avatar
Thanked: 107 Times
Default Refrigerator plan.. worked.
Thanks Alec.
I kept the HDD in the refrigerator for couple of hours, and then connected the same back to the laptop. Voila! it got detected.. now i have taken the backup of the data. Also the whirring noise is absent now.
Did speak to some of the technicians, and they seem to suggest OS might have got corrupted and i might have to reload the OS again. So thinking of formatting the HDD and loading the OS (XP).
Please suggest.
JMaruru is offline   Reply With Quote
Old 21st February 2009, 11:17   #77
Thanked: 660 Times
Yeah! try to reinstall the os!
Old 21st February 2009, 11:21   #78
Thanked: 253 Times
If you are able to reboot with success, then the bad sector, if any, has already been flagged and taken care of.
What does the SMART log reveal?
You could run check disc and then a full surface scan.
Re-install of the OS will depend on these initial findings.
Old 21st February 2009, 16:38   #79
JMaruru's Avatar
Thanked: 107 Times
Default SMART Log
I have run the "chkdsk" and the log did show lots of bad segments and some indexes were deleted. So, will this help ?
I have put up the SMART log.
Please advise.
Old 21st February 2009, 17:17   #80
Thanked: 253 Times
I'd say please buy a new HDD. An HDD with bad sectors is just going to get worse. It's useful life is over.
HDD prices are very low these days.
If you plan on a larger capacity HDD, do check whether your Laptop supports sizes larger than 120 GB. You could run into the 48 bit logical block address problem with anything larger than 120 GB!
Old 21st February 2009, 17:28   #81
Thanked: 660 Times
only sata are cheap. old ide drive are hardto find and expensive.
Old 21st February 2009, 17:36   #82
Thanked: 253 Times
In Delhi, Seagate 2.5" IDE 80 GB is available for approx Rs. 2000/-.
Inexpensive enough, I should imagine!
Old 21st February 2009, 19:04   #83
JMaruru's Avatar
Thanked: 107 Times
Default Logical Block Address ...
In sp road, got a quote of Rs 3400/- for seagate 2.5" IDE 160GB. But now with this LBA problem, am confused.
Laptop is dell inspiron 6000/pentium M 2.0 GHz and am running XP Pro. SP3. Is there a way around for this issue ?
Old 21st February 2009, 20:20   #84
Thanked: 253 Times
To be safe, go for 120 GB.
Old 21st February 2009, 21:02   #85
Thanked: 660 Times
SInce its Pentium M (centrino). possibly you will have 855 chipset. which will take 160gb easily.
@ anup.
thats a good price, but i doubt it. Also In delhi you have to be careful.
Old 21st February 2009, 23:57   #86
JMaruru's Avatar
Thanked: 107 Times
Default 160GB HDD on 915GM chipset ?
@ anup.
I checked under device manager > system devices. I am on 915GM chipset. Hope this should support 160GB.
The HDD price is from sp road, b'lore. He said it is a box piece, with warranty. Please let me know, if you know of a place to get genuine spares.
Old 25th February 2009, 13:02   #87
JMaruru's Avatar
Thanked: 107 Times
Default It might not be HDD.. after all
It seems the laptop getting heated, may not be coz of the HDD issue. Dell support made me to update the bios version. But even then, the "heat issue" surfaced. Now, it seems it might be coz of the dust getting clogged in the heat sink. Could someone guide me on opening up the dell inspiron 6000 laptop ?
Please advise.
Old 25th February 2009, 13:26   #88
Thanked: 253 Times
Most probably it is due to the cooling passages being clogged.
It would be advisable to take your laptop to a professional and let him do the cleaning/vacuuming while you watch. It it no more than a 20 minute affair.
Cost should be Rs. 300/- or less.
Old 1st March 2009, 21:34   #89
JMaruru's Avatar
Thanked: 107 Times
Default 2.5" IDE 160GB HDD in B'lore ?
The dust has been cleared off the heat sink, and the heat issue has subsided. But i have been advised to replace the HDD. I had been to SP road, but couldn't find anyone having stocks of 2.5" IDE HDD of more than 100GB.
Please advise.
Old 2nd March 2009, 00:38   #90
pranavt's Avatar
Thanked: 274 Times
Please advise.
Notebook Hard Drives - TechShop.in - Buy Tech Online Now!!!
USB Hard Disk to Home Theater autoenthusiast Gadgets, Computers & Software 0 20th August 2008 21:36
Help to fix my hard disk in my car raajsree In-Car Entertainment 2 30th June 2008 00:37
Need Urgent "HELP" on Hard-Disk ramie2400 Gadgets, Computers & Software 21 31st May 2008 17:34
How to ADD a Hard Disk partition in Vista kb100 Gadgets, Computers & Software 21 14th May 2008 21:13
Help: DVD rip to hard disk v1p3r Shifting gears 25 11th January 2006 18:33
