Old 26th May 2007, 18:53   #1
Bass&Trouble's Avatar
Thanked: 71 Times
Default Sony Ericsson W550i problem
After some upgrades to my PC recently, nothing involving any USB ports however, when I connect my phone to the PC with the USB cable, it says 'device is not recognized'. I am not trying to use the PC sync software, I am merely trying to put the phone in file transfer mode to take files off it.
Can anyone recommend a POA?
Cheers all!
Ajay aka B&T
Old 26th May 2007, 19:42   #2
Thanked: 294 Times
Sir what is this POA
Old 26th May 2007, 19:47   #3
Vid6639's Avatar
Thanked: 19,554 Times
POA = plan of action.
Old 26th May 2007, 20:19   #4
Godfather's Avatar
Thanked: 65 Times
Try to connect another device like a pen drive or something.. see if that is getting recognised.
Godfather
Godfather is offline   Reply With Quote
Old 26th May 2007, 23:19   #5
Thanked: 294 Times
Godfather
I think he said his phone is not work....but I think rest of the usb stuff is working...
Old 27th May 2007, 02:58   #6
esteem_lover's Avatar
Thanked: 447 Times
Exactly what kind of upgrades did you do ? If you are still on Win XP , there should be no trouble whatsoever (Unless your usb cable has gone kaput).
Old 27th May 2007, 04:40   #7
v1p3r's Avatar
Thanked: 27 Times
It's happened to me a few times. A reboot normally solves my issues. Do check if your USB driver is working right, though I'm assuming your keyboard and mouse are USB and are working, hence the post.
Old 27th May 2007, 11:27   #8
kvish's Avatar
Thanked: 136 Times
I dont know if this is a valid explanation, but let me explain what happened when using the Razr V3...All of a sudden, it said device not recognized. However, when I connected it to the ACTUAL USB port which it was initially connected to, it worked!!... I dont know why thats the case, I think its because, usually in laptops 2 USB ports are detected as USB hub and 2 ports as actual ports. I am not sure, its a wild guess.
kvish is online now   Reply With Quote
Old 27th May 2007, 12:39   #9
moralfibre's Avatar
Thanked: 6,206 Times
Try this after connecting your phone to USB (and after you get "Device not recognized):
1) Right click on "My computer" and select "Properties"
2) Select Hardware and then click on Device Manager
3) On the hierarchy you will see the name of your computer, right click on it and select scan for hardware changes.
4) If the manager finds any device which has a problem it will show a red or yellow sign (like the one seen on report bad post icon here on the left of this post). Chances are that your phone will be shown under USB devices.
5) Right click on that device and choose "Update Driver". A pop-up window will open which will give you an option to
a) Install the software automatically
b) Install the software from a specific location
Select option b.
6) Click next twice and it will install your hardware.
Hope this helps. Let me know.
Cheers,
Kiran
Old 27th May 2007, 17:00   #10
Thanked: 71 Times
Ok, I've tried everything suggested by everyone but to no avail.
Godfather: I connected a pen drive, my handycam etc, everything works fine.
E_L: Two upgrades - Office 2007 running on Win XP, but this has been a while back, and the phone used to work fine then I think. Added a 500 GB hard drive, this has also slowed down my machine considerably.
v1p3r: Reboot didnt help. I uninstalled the PC Suite and re-installed it too.
kvish: My PC has about 6 USB ports. I have tried connecting to all of them. ALso on other PCs.
moralfibre: updated the driver etc. etc. Still at square one.
Hellllppppppp!
Old 27th May 2007, 17:24   #11
moralfibre's Avatar
Contact Sony Erricson service and see if your phone is doing fine or not.
Old 27th May 2007, 17:48   #12
Thanked: 71 Times
I forgot to mention: I have tried using a different USB cable with the phone to connect it to the PC also.
Old 27th May 2007, 18:10   #13
WasavaTyres's Avatar
Thanked: 240 Times
I've had this issue with my 700i earlier. For starters try using a diffrent software like My phone explorer,it's much more easier to use than the SE PC suite,a search on google will throw up the link. If it doesn't work with that either,I guess there's nothing else to do but carry it to the SE service centre and ask them to re-install the software.
WasavaTyres is offline   Reply With Quote
Old 27th May 2007, 18:15   #14
Thanked: 71 Times
Didn't work either. Any other options? Going to the Sony service station would be the last.
Old 27th May 2007, 20:08   #15
Thanked: 294 Times
Ajay Bhai bang the phone on the floor once or twice...it think it will work...and I am serious, sometimes this technique works.. laato ke bhoot bato se nahi manate
which sony ericsson 2fast4u Gadgets, Computers & Software 81 19th November 2007 12:08
Sony Ericsson P-990i unknown Gadgets, Computers & Software 110 20th October 2007 11:34
Sony Ericsson owners, please suggest... Zappo Gadgets, Computers & Software 8 11th December 2006 03:53
Nokia N80 or Sony Ericsson P990i ??.. srasania Gadgets, Computers & Software 27 28th October 2006 04:23
Any reviews on the Sony ericsson P910i?? jigarmuni Gadgets, Computers & Software 15 26th May 2005 04:08
