| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Jun 2004 Location: Chennai
| I want to connect my laptop ( Toshiba A105S4084) to LCD (Samsung 40R81). Pl. tell me how to do it. Head phone audio jack from laptop to tv will give a good sound quality or any other way of do it. Thanks |
| | #3 (permalink) |
| BHPian Join Date: Mar 2007 Location: Delhi
| for display, if your laptop has s-video out port, connect a s-video cable(i am not sure if s-video transfers sound too), for sound it depends upon output of you sound card, if it only has headfone jack outlet, then that is the only option.
__________________ Arun |
| | #5 (permalink) |
| Newbie Join Date: Aug 2005 Location: Bangalore, IN
| Hi there... I have the same LCD TV too (fantastic, isnt it??). To connect your laptop, use any monitor cable and connect it b/w your laptop's monitor out and the LCD's PC IN. To get audio, you need to use a stereo cable and connect it b/w your laptop's headphone port and the audio in of the LCD. Note: Connect the stereo cable to the audio in right next to the PC IN of the LCD. And it works great. I use this setup to view movies that are on my desktop comp at home. My laptop is wireless enabled and is connected to the home wireless network. This way, I can access movies on the desktop via the laptop and play it on the LCD. Just ensure that the resolution on the LCD is set appropriately. Hope this helps. |
| | #8 (permalink) |
| Senior - BHPian | VMG there is a cable in you samsung LCD which u connect to your PC use that same cable to connect to your laptop video out port. The post is blue in colour and have 15 small holes so that the cable from lcd goes in perfectly. I use this all the time ![]()
__________________ Tyres will screech & Engines will roar - WOM |
| | #9 (permalink) |
| Connected my laptop and the LCD thru 25 pin and also the audio thru head phone in my laptop. Tried S video also. Did the settings as mentioned in the user manual for Samsung. Sound works great. But no video at all. I can see the mouse movements in my LCD but no picture at all. Is there any setting to be done in my PC? In fact, I changed the resolution in 'Display' under control panel also. But no luck. Can some one help me on this pl. Thanks |
| | #10 (permalink) |
| OK. Let's try this.... Connect the laptop using the monitor cable and stereo cable to the right ports. Put your laptop into presentation mode (Fn-F4) on most laptops. Doing this once should display an image on the LCD as well as the laptop. Doing this again will display image only on the LCD. You have to do it yourself and see when this happens. The idea is to display the image only on the LCD TV and not on the laptop. The LCD TV should go through a auto-resolution setting process (you'll see a message to that effect on the TV). This should make your laptop display the image in a 16:9 mode. Let me know how this works. Also, the manual gives a more detailed way of connecting a PC on pg 39. See if that helps too. If nothing works, lets see if we can do a telecon and get this done over the weekend. PM me if you would like to talk about this. Best. |
| | #11 (permalink) | |
| BHPian | Quote:
After connecting your TV through the VGA cable, go to display properties and set monitor 2 as the primary display You can choose to disable the Laptops' LCD altogether while you are wartching movies | |
| | #12 (permalink) |
| Senior - BHPian | VMG is display coming on laptop when u plug in it with the LCD. there is a option when u write click on the desktop and go to graphics property there is a option output to: 1. Notebook Only 2. Monitor Only 3. Notebook + Monitor. Select the Notebook + Monitor and it should work.
| | #14 (permalink) |
| BHPian Join Date: Jan 2008 Location: Mumbai
| I was using a monitor cable to transmit video from my laptop on my LCD (LG32LC7R). However, after wall mounting, the gap is not sufficient to plug in the monitor cable. Hence, I am thinking of using S Video cable to connect. I found this all-in-one cable on ebay. Ebay cable ![]() It has S Video and 3.5mm audio jack on one end (for connection into the laptop) and S Video and Audio jacks (red+white) at the other end (for TV). Anybody has any experience with this kind of cable? Or should I stick to just an S Video cable?
__________________ This is your life and it's ending one minute at a time. |
| | #15 (permalink) |
| BHPian Join Date: Feb 2005 Location: Loveland, OH (cincinnati area), jabalpur, chennai
| As far as I know, using this cable you will not get a PC type resolution, you will get TV type resolution. Stick to VGA cable if you like the clarity seen earlier. see if you can fiddle with the wall mount a little.
__________________ ______________________________________ with great power, comes great responsibility. bigger the car, longer the cleaning time. |
| Thread Tools | |
Similar Threads | ||||
| LCD TV or (LCD montior+VGA Box) for Wii? | ashwin489 | Gadgets, Computers & Software | 0 | 20th July 2009 15:33 |
| Car pc using old laptop and LCD screen for santro | haithereitsme | Ask the Gurus | 0 | 25th February 2009 21:04 |
| Problem connecting Laptop to TV | RX135 | Gadgets, Computers & Software | 13 | 25th May 2006 11:16 |
| Connecting Sub to HU? | kvish | Ask the Gurus | 4 | 25th April 2006 12:31 |
| Connecting 2 amps to a HU. Impossible?? | nitrous | Ask the Gurus | 8 | 1st March 2006 17:23 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
