Old 9th June 2007, 11:31   #1
abhibh's Avatar
Thanked: 33 Times
Default LAN card to LAN card sharing
A friend of mine needs to share 2 computers without hub he has 3 lan cards. 2 are in one PC and one is in another PC. He is sharing PC just for file sharing and not internet (as of now). I know it can achieved via getting a Switch/Hub but i think he is trying to be a LAN expert lol...
Help him lol
Old 9th June 2007, 11:36   #2
kooldude's Avatar
I suppose the lan cards are used to share the internet connection rather than sharing files correct me if i m wrong
kooldude is offline   Reply With Quote
Old 9th June 2007, 11:44   #3
Thanked: 11 Times
If you do not want to share the internet than there is no need for 3rd lan card.
All you need is cable and ip settings.
Mugen_Power is offline   Reply With Quote
Old 9th June 2007, 11:47   #4
kpzen's Avatar
Thanked: 1,615 Times
Get a lan wire with two ends like this n connect the lan cards of both the PC's.Set consecutive IPs for the PCs n start sharing.....
kpzen is online now   Reply With Quote
Old 9th June 2007, 11:50   #5
toiingg's Avatar
Thanked: 73 Times
I might be wrong in here, im not an IT guy, but if we are going to connect 2 computers directly, we would be needing a 'Cross cable' and not a 'Straight' one. However if you are planning to connect the PC's with a hub then straight cables will be needed.
IT Guru's pls correct me if i'm wrong.
toiingg is offline   Reply With Quote
Old 9th June 2007, 11:54   #6
merve_extreme's Avatar
Thanked: 12 Times
Yes 2 lan cards are sufficient.i think he must be using third one for Broadband router.
1)what you need is a cross lan cable(cat5e or cat6e if both machines have gigabit lan adapters)(Modern lan adapters can also work using Straight through cable).connect the 2 lan cards using this cable.
assuming win XP
2)goto network connections-lan properties-TCP/IP
3)set ip in 1st machine as manual to 192.168.0.1,subnet 255.255.255.0, gateway and DNS can be left blank.
4)in the same way set ip in 2nd machine as manual to 192.168.0.2,subnet 255.255.255.0, gateway and DNS can be left blank.
5)run the setup home network tool from the network connections in Control Pannel and your done.Remember that both machines should have the same workgroup say "HOME" to share files.
6)share a folder each on both machines to transfer the files.they can be viewd from my network places.
7)To share internet use ICS.Can be accessed in connection properties,advanced tab.
merve_extreme is offline   Reply With Quote
Old 9th June 2007, 12:00   #7
Thanked: 11 Times
2 Lan cards with cross cables like this one and ip settings posted by merve_extreme.
Old 9th June 2007, 12:07   #8
Thanked: 12 Times
make your own cross cable:
Old 9th June 2007, 12:29   #9
kpzen's Avatar
Merve...
Pretty useful info shared....I didn't know the exact funda of making the LAN sharing wire
Thanks a lot...
Old 9th June 2007, 18:15   #10
safari_lover's Avatar
Thanked: 377 Times
if u want to transfer files between systems in a simple way, there's a software called 'ipmsg'. But you need to connect the 2 systems using a cross cable and assign the ip addresses as explained by merve_extreme. If you use this software then there's no need of sharing. If you want the software then pm me.
safari_lover is offline   Reply With Quote
Old 9th June 2007, 19:43   #11
Jaguar's Avatar
Thanked: 148 Times
Infractions: 0/1 (5)
And one more thing, Make sure both the PCs are in the same workgroup.
Jaguar is offline   Reply With Quote
Old 10th June 2007, 01:11   #12
abhibh's Avatar
Thanked: 33 Times
Thnx all ya got his lan working. Crossover was required.
Old 10th June 2007, 02:34   #13
Thanked: 11 Times
Thats Good..
All the information you needed was posted in only one hour after thread started.
Old 10th June 2007, 07:57   #14
Thanked: 294 Times
Guys latest LAN card does not require cross cable to communicate even a simple patch cable can work also.....but check with you hardware before proceeding.....
Old 19th December 2008, 22:50   #15
aah78's Avatar
Thanked: 1,646 Times
Default XP -> Vista
Guys,
The WLAN card on my HP Pavilion tx1420us (running Vista Home Premium) conked off. Seems it's a common problem on these laptops.
I need to buy a USB adapter but before that I'm looking for a quick solution.
I have a Dell Inspiron B130 running WinXP Home, which has WLAN and a LAN port.
The WLAN is connected to a D-Link DI-524 Router (192.168.0.1). I can use the internet, and access files from other computers (Shared Documents, printers - no servers used). The router provides Static DHCP addresses to all computer.
Using ICS and a crossover cable to connect the LAN port on the HP to the one on the Dell. Now I can access the internet from my HP. Windows Mail and IMs work alright too.
However, I can't access Shared Documents on other computers. Can't access any network printers either.
The Dell and the HP have the same WORKGROUP. Other computers in the network have a different WORKGROUP.
Configurations:
Dell
WLAN IP: 192.168.0.111
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
DHCP Server: 19.168.0.1
LAN IP: 192.168.0.2
Default Gateway:
HP
IPv4: 192.168.0.35 (Preferred) - Changes as per connection, I think.
Default Gateway: 192.168.0.2
DCHP Server: 192.168.0.2
Yes, I'm aware that ICS requires 192.168.0.1, but I can't change the router IP to something else.
If I enable a firewall (even the basic Windows Firewall) on the Dell, then I lose
internet connection on the HP.
I want to use a firewall on the Dell, and be able to access the internet (and if possible Shared Documents on other computers) from the HP.
Any ideas? Thanks!
aah78 is online now   Reply With Quote
Which cities in U.P. can issue Smart card or Plastic card driving license (DL) ? zook09 The Indian Car Scene 11 24th November 2010 15:21
HELP - Office LAN / Internet / E-mail Solution needed normally_crazy Gadgets, Computers & Software 13 25th July 2006 19:46
lan transfers dadudeonfire Shifting gears 25 5th February 2006 05:50
Need help to setup LAN ported_head Gadgets, Computers & Software 51 28th October 2005 17:58
Wireless LAN protocol sandeepmdas Shifting gears 3 22nd September 2005 12:15
