Old 14th June 2007, 23:56   #16
rjstyles69's Avatar
Thanked: 791 Times
Please read complimentary charger .
Its available in Europe, yet to see one in India. Will PM you if I can source one.
Old 15th June 2007, 00:17   #17
devarshi84's Avatar
Thanked: 119 Times
I know that most companies are releasing new USB cables to help charge via USB's but I guess with proper drivers (sometimes hacked) usually do the work.
my last 4 phones have had the capacity to charge from the laptop.
Siemens S65 and sxg75
Motorola E680i
nokia N91
devarshi84 is offline   Reply With Quote
Old 15th June 2007, 23:14   #18
sreenivass's Avatar
Default Razor can be charged
Originally Posted by vivekiny2k View Post
on the other hand, my motorola razr had a mini USB but would not charge when connected via laptop. same port used by it's own charger worked though.
Motorola E680i
nokia N91
I can charge mt Moto Razor on mini USB when I have accompanying software installed.
sreenivass is offline   Reply With Quote
Old 15th June 2007, 23:50   #19
shyamhegde's Avatar
I tried a so called USB charger - an unbranded chinese stuff for Nokia phones from SP Road Bangalore (for 100Rs. I guess) but it did not charge my 8310, 6610 and any phone other than 3310 and 3315 (all of them Nokia). Did not try on N72 as I did not want to take a chance with that.
shyamhegde is offline   Reply With Quote
Old 16th June 2007, 15:31   #20
Thanked: 43 Times
I can charge my wife's Razr and my L7 slvr on USB, but only from a desktop. I think from a laptop it does not charge.
filcord is offline   Reply With Quote
Old 16th June 2007, 15:43   #21
suren181's Avatar
I have a Blackberry pearl and it does charge of the PC and a Laptop, however please note that the laptop itself should have been connected to the mains, for the need of a USB charge is a Powered USB source.
suren181 is offline   Reply With Quote
Old 16th June 2007, 17:07   #22
Jaggu's Avatar
Thanked: 7,674 Times
its available in ezone (koramanagla) and made by HP, has a whole set of cables for phones from nokia to sont ericson to assortment of PDA's in the same pack. didnt check the price coz i was in a hurry
Old 16th June 2007, 17:26   #23
cooldude1988765's Avatar
Thanked: 106 Times
nokia N91
how did you charge the n 91 via usb ???
cooldude1988765 is offline   Reply With Quote
Old 16th June 2007, 17:56   #24
sreenivass's Avatar
Default It is a laptop
I use a laptop regularly, A few months ago I charged it from desktop too. The only requirement being phone software required.
Old 16th June 2007, 18:31   #25
devarshi84's Avatar
Thanked: 119 Times
I just plugged it in my laptop USB port..
Old 17th June 2007, 08:56   #26
Thanked: 106 Times
Mine does not get charged ... :(
Old 17th June 2007, 11:37   #27
sreenivass's Avatar
It may have to do with USB 1.1 or 2.0, may be worth checking out. Many models from a couple of yrs ago do not have 2.0 USB. I am sure speeds supported are different, can not recall if charging capability was there in 1.1
Old 17th June 2007, 14:37   #28
Thanked: 106 Times
Mine is a brand new laptop and all usb 2.0 ports.
Devarshi are you sure the n91 charges via usb ???
Old 17th June 2007, 22:53   #29
Thanked: 43 Times
To charge the slvr one needs only the cable, software is only if you want to back up the phonebook, etc. I use the cable on my office PC where I have no Motorola software, it charges the Slvr just fine.
Old 17th June 2007, 22:56   #30
devarshi84's Avatar
Thanked: 119 Times
cooldude, I am 100% positive. It was a silver N91 with 4gig HDD and a cradle. I used it in Canada and it was a middle eastern version. Dont have the phone anymore but will try to give you more details if needed.
Car Battery to 220V AC convertor / inverter for charging laptop etc sreeku In-Car Entertainment 169 19th January 2018 15:42
Impact of charging devices via USB on FE and emissions libranof1987 Technical Stuff 17 28th January 2016 16:38
Using ICE to talk on the phone (via AUX In) Atul-C In-Car Entertainment 7 17th July 2012 10:05
Laptop Battery charging? VMG Technical Stuff 1 17th August 2007 15:26
