Old 21st June 2007, 20:58   #1
abhibh's Avatar
Thanked: 33 Times
Default NTFS problems
My laptop HDD is NTFS and i just for the first time ran disc cleanup lol and it took like 5 mins to open the disc cleanup. It hanged on "Compressed old files". I have turned off the compression on the drive and even after the window opened and i click cleanup it stuck on "Cleaning Compressed Old Files" for around 10 mins +. Is this normal for NTFS.
Also should i shift back to FAT32 or NTFS ok my hdd is 40 GB
Old 21st June 2007, 21:00   #2
manikjeet's Avatar
Thanked: 109 Times
arre bhai you always end up in trouble
will let you know if its normal
manikjeet is offline   Reply With Quote
Old 21st June 2007, 21:05   #3
abhibh's Avatar
Thanked: 33 Times
Kya karun teri DOSTI KE SIDE EFFECT HAIN j/k
Old 21st June 2007, 21:51   #4
msdivy's Avatar
Thanked: 842 Times
NTFS is a better filesystem than FAT32. It more robust & reliable too. Also it has better security features.
AFAIK, you can't convert NTFS to FAT, without formatting.
msdivy is online now   Reply With Quote
Old 21st June 2007, 22:22   #5
moralfibre's Avatar
Thanked: 6,210 Times
Yes Abhibh it is normal behaviour. I learnt this from the sys admin in my office. It usually takes time.
Old 21st June 2007, 22:47   #6
rishibravo's Avatar
its normal...dont worry..
rishibravo is offline   Reply With Quote
Old 21st June 2007, 23:41   #7
Thanked: 294 Times
in file clean up the system is asking the user to compress the unused file which are not access for a long time...this is the reason when the system is reading the files it get busy in heavy harddisk activity which make it slow and look that it hang..
Old 21st June 2007, 23:56   #8
Thanked: 11 Times
It is normal so Stick to NTFS and get a better tool for disk cleanup and defragment.
Mugen_Power is offline   Reply With Quote
Old 22nd June 2007, 00:24   #9
abhibh's Avatar
Thanked: 33 Times
Ya i am gonna stick to NTFS only its faster than FAT32 for me. I have diskeeper for defragment and i installed ccleaner now
Thanks all for clearing it up.
Old 22nd June 2007, 00:24   #10
manikjeet's Avatar
Thanked: 109 Times
arre ab mei kya karu cheers:
and its normal as everybody says
Old 22nd June 2007, 13:21   #11
chetan's Avatar
no it can be done i had done it myself but i have forgotten it now its been long time since i did that...why dont you post a query on techenclave
chetan is offline   Reply With Quote
Old 25th June 2007, 10:59   #12
Run you laptop in safe mode, when your laptop starts press F8 key and the option will come to start in safe mode. in safe mode most of the windows services do not run. it will help in the disk cleanup fast.
search the *.tmp files in c drive and delete all the temp files.
amit_delhi is offline   Reply With Quote
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Mahindra Scorpio CRDE 2007 - Problems 'n' Problems chandrda Technical Stuff 3 13th November 2009 09:59
HELP !!! (NTFS encrypted data causing a pain in the neck) motorheadinc Gadgets, Computers & Software 19 24th January 2008 10:59
Mighty Honda has Quality problems too! amit The International Automotive Scene 7 20th April 2004 11:11
