Old 23rd June 2007, 00:19   #16
esteem_lover's Avatar
Thanked: 447 Times
There are various ways possible, but I suggest do it the correct way.
For this to work you need to have a USB drive so that you can load the relevant files.
1. Step 1, make an .iso from the XP CD which you have on another computer
2. Step 2, make a virtual CD rom drive(google for this, its easy, free softwares available)
3. Transfer .iso to your PC and load the .iso in your virtual CDrom drive. Simple. Run the setup and off you go
If you want to do via floppy disk(I dunno why)
Install Windows XP without booting to CD
If your BIOS can boot from USB drive, then its simpler
Installation on ThinkPads without CD-ROM drive - ThinkWiki
Originally Posted by low_bass_makker View Post
yes. it is a simulation one so it require windows...but if you a bit of DOS you can load a CD drive drivers but it is a different thing...
Aren't you both suggesting the most complicated & sometimes nonviable option ?? come on kids, get out of that complexity, free your mind & enjoy life.
Old 23rd June 2007, 00:29   #17
Thanked: 294 Times
Hahahaha...ya E_L some times we go the hard way but there is a easy way out also....
Old 23rd June 2007, 14:16   #18
clipto333's Avatar
Originally Posted by abhibh View Post
Clipto,
There is windows repair but it does not work very well. I will suggest you to copy the files of Windows CD in a folder in yer laptop HDD via your external HDD.
Then boot up in dos via USB / Floppy if it has one into dos. Don/t forget to have copy 2 files DELTREE.EXE and SMARTDRV.EXE in you laptop HDD as they will make your work easier for deleting old windows folders.
Then when u boot up in DOS just type: SMARTDRV.EXE once and then use DELTREE.EXE to delete windows, program files, system etc files and folders which u dont need.
After that just go to that folder where you copied the files of windows installation and run setup.exe.
P.S. can write the full steps with help url where to get the stuff once i reach home as i m on mobile lol..
hi,
thanks for the help. my laptop cannot boot from usb. i just checked. the only options are hdd,cd-rom,network and floppy(not sure about floppy).
cheers
clip
clipto333 is offline   Reply With Quote
Old 23rd June 2007, 15:19   #19
Thanked: 294 Times
Originally Posted by clipto333 View Post
hi,
cheers
clip
Do you have a floppy drive..??
You can also copy the setup files on the HDD and then install it from there.
Old 23rd June 2007, 19:41   #20
Thanked: 447 Times
Borrow an external HDD/CDD & do the job.
Smartphone ROM flashing: HTC Touch 3G (Jade) RX135 Gadgets, Computers & Software 2 19th August 2010 14:55
Installing Windows XP on a 400 Mhz PC!!! ramki067 Gadgets, Computers & Software 21 28th August 2009 11:13
DVD rom/CD R-W drive busted vivekiny2k Gadgets, Computers & Software 8 14th October 2007 15:48
Cd Rom in a Cielo? eagle_f1 In-Car Entertainment 40 26th June 2006 20:22
