Old 21st June 2007, 20:59   #1
clipto333's Avatar
Default HELP!! installing windows xp without cd-rom drive.
hi,
i need to install win xp without cd drive as the drive on my laptop is not working. i have an external hard disk(laptop HDD with usb casing).
guys please help me out as buying a new cd drive is out of question rightnow.
can anyone let me know the price of a cd dvd combo drive and a dvd writer for compaq presario 2203al?
thanks
clip
clipto333 is offline   Reply With Quote
Old 21st June 2007, 21:10   #2
abhibh's Avatar
Thanked: 33 Times
You got USB pen drive ? If yes then can your laptop boot from a USB storage if yes then i can help you.
Do laptop currently have any windows installed ?
Old 21st June 2007, 21:20   #3
unknown's Avatar
Thanked: 13 Times
Download the Window's Xp off net on to your hd & run the setup from there !
unknown is offline   Reply With Quote
Old 21st June 2007, 21:26   #4
abhibh's Avatar
Thanked: 33 Times
TeamBHP does not encourage illegal stuff. lol... I am taking the probability here that laptop HDD has no windows on it.
Old 21st June 2007, 21:47   #5
esteem_lover's Avatar
Thanked: 447 Times
Copy the WinXp files to your external HDD using a friend's computer & change the bootup preference in the BIOS on your comp to boot from the USB port. I think that should work.
Old 21st June 2007, 23:34   #6
tsk1979's Avatar
Thanked: 15,684 Times
There are various ways possible, but I suggest do it the correct way.
For this to work you need to have a USB drive so that you can load the relevant files.
1. Step 1, make an .iso from the XP CD which you have on another computer
2. Step 2, make a virtual CD rom drive(google for this, its easy, free softwares available)
3. Transfer .iso to your PC and load the .iso in your virtual CDrom drive. Simple. Run the setup and off you go
If you want to do via floppy disk(I dunno why)
Install Windows XP without booting to CD
If your BIOS can boot from USB drive, then its simpler
Installation on ThinkPads without CD-ROM drive - ThinkWiki
Old 21st June 2007, 23:44   #7
Thanked: 294 Times
the above methods are the most easy way to do it...
Old 22nd June 2007, 00:01   #8
Thanked: 11 Times
I dont know the prize but you can get a Usb Cd/Dvd writer.
Mugen_Power is offline   Reply With Quote
Old 22nd June 2007, 00:57   #9
Zappo's Avatar
Thanked: 2,017 Times
Ok, there you go. Tsk has already given you the key. The most straightforward way to do it.
By the way even a network install is possible if you can map your external USB HDD as a network drive. This of course takes into consideration that you have at least one OS currently running on the laptop (Even a free DOS will do).
Zappo is offline   Reply With Quote
Old 22nd June 2007, 09:24   #10
cooldude1988765's Avatar
Thanked: 106 Times
Doesnt the virtual cd software need windows for you to run it ??
cooldude1988765 is offline   Reply With Quote
Old 22nd June 2007, 10:19   #11
Thanked: 294 Times
yes. it is a simulation one so it require windows...but if you a bit of DOS you can load a CD drive drivers but it is a different thing...
Old 22nd June 2007, 10:21   #12
DerAlte's Avatar
Thanked: 2,877 Times
Clip, is your laptop already booting from the current HDD (i.e. you are trying to repair the current installation) or has something hopelessly gone wrong that you want to completely reinstall it (maybe after a format)?
If it is booting, copying the install CD contents to a directory in the USB HDD (or any other USB storage) will allow you to run the "autorun.exe", which will take care of the reinstall (repair option). The install program copies all relevant files to the main HDD during the install process so that rebooting in between (does it a couple of times) does not cause problems with removable drives.
Post-install, It is normally a good policy to copy the CD contents in a directory in the main HDD (from where the machine boots), so that for problems other than in HDD you can reinstall easily.
Another method is to make a 'ghost' of the boot image after an install, so that you can simply copy the 'ghost' over the previous faulty image in case something goes wrong in future. Of course, you can't copy a ghost from a different machine to the one under repair - the settings, drivers and registry will be different.
Old 22nd June 2007, 11:39   #13
tsk1979's Avatar
In non CD drive laptops(newer ones) install from USB drive is a good option.
Most modern laptops support boot from USB drive.
Old 22nd June 2007, 18:26   #14
clipto333's Avatar
hi guys,
thanks for the replies. i was really busy with work so didnt have time to re install windows.
ok let me clarify a few things.
my laptop is 3 years old with the following config -
1.5 ghz pentium m centrino with 512mb ram 40 gb seagate hdd. there was a cd-dvd combo drive but now its not working at all. i have a 30 gb laptop hdd with the usb casing.
im using win xp and there is no trouble in booting. im getting a lot of errors which im not able to fix so i want to format my primary partition (c:\) and install win xp.
if there is any way to repair the os then its great cause its a pain to re install all the drivers and programs again.
thanks
clip
Old 22nd June 2007, 19:28   #15
abhibh's Avatar
Thanked: 33 Times
Clipto,
There is windows repair but it does not work very well. I will suggest you to copy the files of Windows CD in a folder in yer laptop HDD via your external HDD.
Then boot up in dos via USB / Floppy if it has one into dos. Don/t forget to have copy 2 files DELTREE.EXE and SMARTDRV.EXE in you laptop HDD as they will make your work easier for deleting old windows folders.
Then when u boot up in DOS just type: SMARTDRV.EXE once and then use DELTREE.EXE to delete windows, program files, system etc files and folders which u dont need.
After that just go to that folder where you copied the files of windows installation and run setup.exe.
P.S. can write the full steps with help url where to get the stuff once i reach home as i m on mobile lol..
Smartphone ROM flashing: HTC Touch 3G (Jade) RX135 Gadgets, Computers & Software 2 19th August 2010 14:55
Installing Windows XP on a 400 Mhz PC!!! ramki067 Gadgets, Computers & Software 21 28th August 2009 11:13
DVD rom/CD R-W drive busted vivekiny2k Gadgets, Computers & Software 8 14th October 2007 15:48
Cd Rom in a Cielo? eagle_f1 In-Car Entertainment 40 26th June 2006 20:22
