View Poll Results: Do you face any Problems with TATA Sky?
Yes 117 37.50%
No 195 62.50%
Voters: 312. You may not vote on this poll
Old 16th April 2011, 08:43   #226
mayankk's Avatar
Thanked: 3,223 Times
Default Re: TATA Sky..Do you face any problems?
Originally Posted by kamalnv View Post
Note from Support: Please avoid excessively dotty posts. Thanks!
I second that, TS has awesome quality especially with HD+ ... and with Star HD on it...wow...
The HD+ has a Signal meter indicating both Signal Strength and "Signal Quality", hidden inside the service menu i dont have the settings upfront but googling should get it...With this menu option we should be able to Adjust the Antenna's direction for optimum signal.
i'd suggest do NOT touch that dish to make any adjustments.
eve a minor degree of shift will have you communicating with the next nearest planet instead of the intended satellite...
mayankk is online now   Reply With Quote
Old 19th April 2011, 18:51   #227
I haven't tried my hand on DTH dish but done that with bigger dishes for almost 15 years. One time helped to my local DD transmitter Engineer too while they lost their spectrum analyzer cum signal meter. Just putting TV in front and adjusting by taking clue from magnetic needle compass and satellite coordinates. Just try and error with gut fill.
So no fears.
omishra is offline   Reply With Quote
Old 19th April 2011, 19:03   #228
Tejas@perioimpl's Avatar
Thanked: 4,766 Times
Anyone else facing an issue with sound going off for a few seconds on the HD channels? Happening every 15-20 min since the past couple of days.
Tejas@perioimpl is offline   Reply With Quote
Old 19th April 2011, 20:04   #229
Thanked: 979 Times
Used to happen on our HD+ box. Add to that freezing of the box five to six times a day. Finally got Tata Sky technicians, who promptly changed the box yesterday. Since then no problems.
Old 19th April 2011, 20:22   #230
mayankk's Avatar
hey, anybody been able to figure out the USB slot's function?
really wish tata release its functionality.
I'll tell you one thing, though.
if you keep your dabba on standby, you can use it fro charging phones.
Old 19th April 2011, 21:35   #231
hemanth.anand's Avatar
Thanked: 5,352 Times
I enquired the TATA technicians and they told that they have disabled the USB.
Yes, it would have been good if the USB functionality was active.
Hey anybody noticed that the TATA SKY HD user interface(UI) has changed.
I don't know about the normal TATA SKY UI.
This new HD UI looks cool-especially the fade effects to all the menus.
Good thing is the classifications of the channels are now in the main screen itself.
The number of digits for a channel number is 4 instead of the earlier 3..might be because of the increase in the no. of HD channels.
Have anybody noticed any other change apart from the look?
hemanth.anand is offline   Reply With Quote
Old 19th April 2011, 22:32   #232
Vid6639's Avatar
Thanked: 18,804 Times
Yes the UI has been upgraded with the faded effect but theres a problem. Channel changes are delayed and slower, theres a lag while surfing.
Old 19th April 2011, 22:54   #233
Channel changes are delayed because now we can enter 4 digits for a channel.
so after we enter the 3 digits of a channel, it waits for us to enter the 4th digit if any.
I have started to use '0' before the channel (for example 0305 for set max) to make the channel change faster.
Old 19th April 2011, 22:58   #234
Vid6639's Avatar
I'm not saying those type of channel changes. More like while surfing through favourites or just the ch +/-.
Old 19th April 2011, 23:14   #235
Yes, You are right, a small delay with a black screen is appearing.
Its slower than in the previous UI.
Old 20th April 2011, 12:20   #236
It is sequence as follows -
press "Organizer" -> "System Settings" -> "0" -> "1" -> "Select"
Now follow instructions. Do it at your own risk and do not blame me.
Old 20th April 2011, 12:23   #237
mayankk's Avatar
you have given directions to a bhpian.
you think he wont do it?
to teh OP:do let us know how it goes!!
Old 25th April 2011, 18:13   #238
ssadwelkar's Avatar
Thanked: 60 Times
Yes, I have a similar issue, the sound does not go off completely but the volume reduces for a few seconds and comes back to normal.
ssadwelkar is offline   Reply With Quote
Old 25th April 2011, 19:19   #239
It happened 2 times in yesterday's match.
On Saturday I was facing a peculiar problem in my TSHD.
After every channel change, the channel info on the bottom was staying on till I press the back button. Also the volume indicator used to stay permanently.
On Sunday however it was back to normal
Old 25th April 2011, 20:06   #240
ssadwelkar's Avatar
Thanked: 60 Times
Tata Sky has just added the eagerly awaited Ten Action Sports channel and my kids are very excited as now they can watch their favorite football matches.
Open Face vs. Full Face Helmets : How Safe are they? Rehaan Motorbikes 73 28th May 2015 15:13
Face to face with an angry tiger drkakkilaya Travelogues 49 22nd June 2012 18:46
Tata SKY / Dish / CAS what is your choice .... all south delhi BHPians whatcanthisbe Gadgets, Computers & Software 1 29th December 2006 10:31
How many of you face problems with electronics in your car? frankmehta Technical Stuff 15 15th April 2006 10:15
