Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 9th November 2007, 17:24   #121 (permalink)
netarchie's Avatar
New Firmware Update is finally done. Everthing seems to be ok. GPS is the only major improvement. Apart from that i really did not find any noticeble difference as of yet.
As for backup, I formated the phone before firmware upgrade. I will sync with my Outlook for the PIM and apps, I will be installing fresh.
__________________
netarchie
netarchie is offline   Reply With Quote
Old 9th November 2007, 19:18   #122 (permalink)
harjeev's Avatar
Thats good news. Maybe I would update mine tomorrow.
What is the improvement in the GPS.
Does is lock on quicker?
harjeev is offline   Reply With Quote
Old 9th November 2007, 20:54   #123 (permalink)
hydrashok's Avatar
I heard the Assisted GPS will now also use the Data Connection to help get a real fast lock on the satellites. Apparently you get a lock in 20 secs (max) now.
@Netarchie do let us know if this is the case with your phone too. And thanks for the info about your FW update
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
Old 9th November 2007, 21:09   #124 (permalink)
netarchie's Avatar
Ya..it locks a lot quicker.. Just to cite an example..with the previous version of firmware..if i wanted to test an gps app , it used to take atleast 7 - 8 minutes, If i was lucky, to get a fix ..sometimes longer too., if i held it near my window. Now with the new firmware upgrade , i got my first fix in flat 40 seconds (I timed it) from the same place (near the window).
__________________
netarchie
Old 14th December 2007, 11:02   #125 (permalink)
Sahil's Avatar
Whats the current price of E90 in Mumbai?
__________________
______________
__________
______
__
Old 14th December 2007, 12:26   #126 (permalink)
jesal's Avatar
Infractions: 0/1 (4)
36kkkkkkkkkkkkkkkkkkkkkkkkkkkkkk
__________________
Јєşåł Åŕỳā
Modifying Gone Mental
jesal is offline   Reply With Quote
Old 14th December 2007, 12:44   #127 (permalink)
harjeev's Avatar
I updated my E90 firmware earlier this week.
Like netarchie said the major improvement is the lock on time for the GPS. Rest everything seems the same.
Another thing that I have noticed is that when the backlight on the inside screen switches off is switches off with a slight smooth delay and not abruptly. I dont know whether this was there earlier or not !
Rest everything was smooth. No issues with the backup and restore of the complete backup too.
Old 14th December 2007, 13:16   #128 (permalink)
hydrashok's Avatar
I'd forgotten to post this earlier.
Be careful about putting anything with magnets near the E90. I'd bought an Organizer with a magnetic closer-clasp, and walked a while with the phone on the organizer, just above the clasp. (The E90 was in the leather-slip-case that came with it). What happened is, that the magnet switched off the external screen and the external keypad!
Apparently the transfer of focus between the internal and external screen (and keyboards) takes place through some magnetic switch inside the flip of the phone. When we open the phone the magnet-switch detects the open flip and transfers focus to the internal screen.
Any strong-enough magnetic field from outside interferes with this process. That is how my external screen (and keypad) switched off.
What made things worse is that the phone was locked, and the locked state remained even when the flip was opened. Without a way of unlocking the phone from the internal keyboard, the phone was truly "locked".
After a bit of googling and forum-trawling and I knew this was a known issue. I also got the fix (thank god for the Internet).
I passed the same magnet over the phone again. This caused the internal screen to shut off and the external screen & keyboard to be activated. And everything was back to normal.
So it would be a good idea to not use even a belt case with a magnet closer strap. The problem area is in the side of the phone near the hinges.
__________________
Old 22nd December 2007, 07:21   #129 (permalink)
hydrashok's Avatar
I just bought Epocware's HandyCalendar for the E90. Excellent bit of SW. It uses the database of the Symbian Built-in Calendar, but adds a WHOLE LOT of usability. It lets us keep the Today screen plugin active also.
It works perfectly with the internal screen and makes very good use of the entire internal screen's real-estate.
I've just started using this SW now, but it is worth the money for sure. It is as good as the 9500's excellent calendar app. Lots and lots of additional functionality gets added.
- Notes can be attached to all types of entries.
- Alarms can be easily added to all types of entries.
- Editing the enrties is much much better an intuitive.
- Contacts can be easily integrated with the calendar.
- If we use Epocware's HandyProfiles, it will integrate with the Calendar, and the phone-profiles can be automatically managed based on the calendar entries (auto-switch to Meeting mode or Silent mode or a custom profile etc based on the calendar entry and time of the entry).
- "Busyness" indicator bar in colour, showing what times you are busy on a particular day.
- Etc, etc. Lots more.
They have a 50% discount going now, so I got this 40$ app for 20$. I test-drove it for 3 days and knew this was the One I tries SBSH's Papyrus also, but IMHO Handy Calendar is much superior.
__________________
Old 29th December 2007, 22:25   #130 (permalink)
hydrashok's Avatar
I love the holiday season! Perfect time for picking-up good SW for less
I just bought 4 software apps for my E90. These apps are available for all S30 3rd edition phones. They work just great in the internal screen of the E90 also.
1) Epocware's HandySafe: A nice, secure wallet-like program to store sensitive data securely.
2) Epocware's HandyTaskMan: A great way to control all the SW installed on your phone (including the default software). It works like the Symbian taskswitcher, except this one has more. We can start/access any SW installed on the phone by typing in the first few chars of the SW's name. No moving around the menu icons and clicking thru folders. This also displays the memory status (RAM & Phone Memory), and how much memory each app uses up.
3) Resco PhotoViewer: I used to use this with my PPC phone and it was hands down the best image viewer I'd used. The SYmbian version has most of the same stuff, but not all. But it is 100 times better than the defauly Symbian "Gallery".
4) Resco News: A really good RSS aggregator. I'd been looking for one app like this for a while, and the Resco News SW does all I want. Small, fast app (Can't say that for most RSS readers).
All this stuff came with "seasonal" discounts, open till the end of the year. I love discounts for SW.
BTW, Handango gave away the app I'd mentioned in my previous post (Handy Calendar) for FREE (!!!) today (Friday in the US), for one full day :(
And am I the only guy reading/posting on this thread?
__________________
Old 30th December 2007, 12:29   #131 (permalink)
I am reading your posts but its useless for me now as i sold my E90.
Mugen_Power is offline   Reply With Quote
Old 30th December 2007, 17:15   #132 (permalink)
V-16's Avatar
Im reading your posts too buddy. please go on. I learn something new every time i read your posts.
__________________
SINGH IS KING!!!!
V-16 is offline   Reply With Quote
Old 30th December 2007, 21:52   #133 (permalink)
hydrashok's Avatar
Hey, thanks guys! That was said jokingly in part, but well...
Looking for a 6GB/8GB MicroSD now. I'll upgrade the FW as soon as I get one.
The reason I'm waiting for a 6GB/8GB card is that I'll be reinstalling everything afresh anyway after the upgrade, so I'd rather install most of the apps to the card, and keep it in the phone for all time. I'm using two 2GB microSDs now, with all apps installed to phone memory, so that switching the cards will not compromise functionality.
__________________
Old 3rd January 2008, 15:57   #134 (permalink)
hydrashok's Avatar
I got this nice, small and fast (and yes, FREE) Screenshot utility the other day: Screenshot 2.
It works with all Symbian S60 phones, and works like a charm with the E90. Very nifty for grabbing some info off the net when you don't want to type it into the notepad separately, or when you don't want to write it down (we still can't copy stuff off a webpage, pity). (And yes, I'm laaaaazy). Now all I need is an OCR utility for Symbian that reads the data off the screenshot to text
The utility takes a screenshot of whatever is displayed on the screen when you press the "Edit" + "OK" key. (That is, the "Shift" + D-Pad "Enter" on the internal screen of the E90). It shoots to JPEG. We can adjust the quality and size of the file across 3 levels.
Here's an actual screenshot of the developer's website, grabbed off my E90.
Did I mention it was Free?
__________________
Old 5th February 2008, 13:16   #135 (permalink)
a4_attitude's Avatar
any idea about th current price of nokia e90 officialy and grey market?
W.ajay
__________________
To live is not just to survive, but to thrive with Passion, Compassion, some Humor & your own Style !
a4_attitude is offline   Reply With Quote
Thread Tools
The latest fashion from Nokia - new Nokia 8800 khanak Gadgets, Computers & Software 29 26th March 2008 00:56
nokia 7610 v/s nokia 6600 normally_crazy Shifting gears 2 21st August 2004 18:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
