| Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Mar 2006 Location: Mumbai
| Dear All, We have seen gradual but definite increase in broadband penetration after BSNL and MTNL came out with minimum 2 MBPS speed with reasonable affordable package..... Purpose of this thread is to find ways & methods to improve performance of broadband connections............ Here is what I found & implemented & benefited.... 1)With Automatic IP address assignment router keeps on searching new IP address every 12 minutes and this hangs connection without our notice...with assigning manual IP address we are pointing exact IP address in TCP/IPin right directions..... What We need to do?.......we need to assign IP address manually...we can get details by double clicking Boradband icon then "Support" then "Details".....this displays IP address & other details.....or we can get details by clicking "Start"....then "Run".....typing "cmd" will give black screen whre we need to type "ipconfig/all" to get full details of our connections... After finding Ip address & other details we need to assign it this way... Click Broadband connection icon then "Propertie" then "Internet Protocol TCP/Ip.....in next window of TCP/IP protocols tick "use the following IP address" and manually assign P address like 192.168.1.2and subnet mask like 255.255.255.0 and Default Gateway like 192.168.1.1...... Also check "Use Following DNS Server Addresses....and input address which may be same as Default Gateway..... Then click "Advanced" and highlight Gateway address and click "Edit".....A small window of TCP/IP address is opened....here uncheck "Automatic Metric" and assign a value of 1 in the box of Metric...... Close all windows vby clicking "ok" and reboot machine..... We get improved performance in surfing....... If for any reasons this doesnt work then go back to "Internet Protocol Properties" and click"Assgin IP address Automatically"......and reboot....you will be back to normal setting.....I hope this wil help all.... Here is an excellent website duscussing all these in details..... broadbandnuts - cablenut Enjoy... Last edited by finetuning : 8th July 2007 at 21:28. |
| | #2 (permalink) |
| Senior - BHPian Join Date: Jun 2007 Location: Kochi
| This router (and most routers provided by VSNL too) can be used as ordinary modems - you have to install and use PPPOE (ppp over ethernet) software - pppoe and pppoeconf on linux boxes, and rppoe on boxes running microsoft. The configuration you are talking of - the router is running a DHCP server, and assigns a local IP address to your computer. The public IP address is assigned to the router. This is the right thing, if you are using microsoft OSes, because your computer is securer. But I use exclusively linux here, and I use the router as a modem and run a pppoe software, with the public IP address assigned to the computer, I have better control. One of the best things with this pppoe setup is that I can access the files on my computer like when I am on tour. I simply call up my home to switch the computer, and with some "little tricks", I can find up its IP address. Next, I login through SSH, and can read the file I want. I have set this up very securely, that even if he gets the root password, a third person cannot login. I bet.
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq |
| | #3 (permalink) |
| Hi All, Found another good way improve browsing speed with whatever connection we have at no extra cost and easy to implement. Its OpenDNS.It improves the DNS resolution so fast making surfing really faster.I m using it since few days and working great. What we need to do? Just click Network connection icon--->properties---->Internet Protocols(TCP/IP). Here we need to type Preferred DNS Server : 208.67.222.222 Alternate DNS Server : 208.67.220.220 Rebooting will take effect.See the difference in browsing Need to check this OpenDNS | Providing A Safer And Faster DNS |
| | #4 (permalink) | |
| Team-BHP Support ![]() | Why do you want to reboot all the time? Just restart you network, unless you are talking about "Save/Reboot" on the router itself. Actually when you have a single or just 2-3 computers, you do not need to have DHCP, you can just have static IP address. As for open DNS, its a faster DNS server better than what Airtel/MTNL etc., provide. It will improve the initial wait time while opening a site, if you have a download on, it will not make any difference in the download speed. DNS servers are just used once while resolving the site, once the IP address is resolved DNS server is out of window. Another thing can be increasing MTU as close to 1500, but this breaks windows update, so 1452 is the most commonly used setting. Quote:
In PPPOE setting I suggest you use shorewall or something, since you have the ssh port open.
__________________ Reclaimed, wrung dry and recycled....! Last edited by tsk1979 : 11th July 2007 at 10:35. | |
| | #5 (permalink) |
| Hi We need to reboot pc as we are changing network properties and not making any changes at router configuration. Many times websites just takes more time to load because of dns resolution.This makes browsing fast.Rightly said it doesnt improve download speed.In the normal course of surfing we are hitting so many dns queries so that way its helpful.Apart form faster browsing this blocks phishing attempt,blocks ugly contents and much more. |
| | #6 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| With the cable cut fiasco my BSNL connection had gone into snail mode, to the extend half the time TBHP wont load. Remembered about open DNS and that i had not configured it in the new router. Enter open dns and voila am baaaack ![]()
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #7 (permalink) | ||||
| BHPian Join Date: Mar 2006 Location: Bangalore
| There is nothing like free lunch, if you need more bandwidth, you need to pay for it. ![]() Changes to MTU etc used to make some minor difference in dial up days, but with the current slew of DSL connections, they hardly make any perceptible difference. Unless you are using a wireless based internet connection for the last mile... Quote:
For Airtel, it makes no sense to use it. Their DNS servers hardly ever go down. But for BSNL, since their DNS servers keep going down, I use OpenDNS. And that does not speed up browsing, instead slows down domain name resolution. Quote:
| | #10 (permalink) | ||
| Team-BHP Support ![]() Join Date: Feb 2004 Location: Bombay
| Quote: Quote:
cya R
__________________ The memory of you will ride by our side forever. | ||
| | #11 (permalink) |
| Open DNS works for my BSNL that much i know, atleast was proven yesterday at home. OR same time sea line issue was repaired will check again today evening and see. In BSNL i have noticed there will be an marginal improvement in speed during normal times (multiple test with speedtest.net). Dont know about other DSL's.They do have some inbuilt restrictions and blocks where by warning pages are issued for certain sites which are fraudulent in nature.
| | #12 (permalink) |
| BHPian Join Date: Sep 2005 Location: Chennai
| Hmm, here I was thinking this was about pouring boric acid/ethylene glycol/toluene/$industrial_solvent into the router, or drilling "speed holes" into my network cable. How boring, this computar stuff :( |
| Thread Tools | |
Similar Threads | ||||
| BSNL BroadBand Issues | rjstyles69 | Gadgets, Computers & Software | 172 | 2nd November 2009 13:19 |
| BSNL broadband 20% discount? | hrishig | Gadgets, Computers & Software | 7 | 26th July 2009 22:59 |
| BSNL Broadband Wireless Configuration | carboy | Gadgets, Computers & Software | 63 | 10th March 2009 15:39 |
| A question to all BSNL Broadband Unlimited Plan users | adya33 | Shifting gears | 28 | 21st December 2008 20:25 |
| Team-BHP is extremely slow with BSNL-Broadband! | SumitB | Shifting gears | 20 | 4th June 2008 00:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
