Gadgets, Computers & Software PDAs, Laptops, Digi-Cams, Softwares and more!
Thread Tools
Old 8th July 2007, 22:07   #1 (permalink)
revvedup's Avatar
Default Help in dual monitor setup
I have a nvidia 6200 graphics card (256 mb 64 bit) with vga and dvi outputs.Now at presnt it is running a 19 inch widesccreen@1400*900 resolution running via the dvi port,I also want to connect my old 15 inch running at 1024*768 via the vga port.The problem is that whenever I connect the two monitors to the card and set it up only the primary monitor runs properly and has all the icons on it ,but the secondary one does not display properly the image seems to be zoomed moreover I do not get any icons on it.I am running the latest version of the nvidia drivers 94.24.
__________________
The journey is more important than the destination
Living life@8500 RPM
revvedup is offline   Reply With Quote
Old 8th July 2007, 22:54   #2 (permalink)
low_bass_makker's Avatar
Infractions: 0/1 (5)
all you have written is absolute correct it happens like this also. but there is a second option in which the same clone
Old 9th July 2007, 05:00   #3 (permalink)
speedzak's Avatar
Some more details needed.
Which scheme do you run? Clone? Parallel? Extension?
Yes, I'm asking about the 2nd display. What is it figured as?
What is the main purpose You're looking at?
__________________
Chitty Chitty... Bang... Bang... Boom!!!
27th October 2008.
Old 9th July 2007, 12:17   #4 (permalink)
bottle's Avatar
you can run a dual monitor setup without any 3rd party software but check out ultramon.. its a pretty good app to configure multiple monitors, google for more info
bottle is offline   Reply With Quote
Old 9th July 2007, 14:53   #5 (permalink)
merve_extreme's Avatar
your second monitor is in span mode.go to nvidia control pannel(display section-setup multiple displays) and set nview display mode as clone.
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 9th July 2007, 23:12   #6 (permalink)
revvedup's Avatar
I am not using it in clone mode since I don't want both of them to display the same image on both moinitors and want to run both of them as seperate monitors at seperate resolutions.
__________________
Old 9th July 2007, 23:50   #7 (permalink)
then choose the span mode...
Old 10th July 2007, 00:09   #8 (permalink)
span mode just stretches the main screen onto the 2nd monitor.
then use Dual View mode.
__________________
Old 10th July 2007, 00:17   #9 (permalink)
revvedup's Avatar
thats the problem I am running it in dual view mode but the start menu and icons display only on the primary but the second one does not have any of them.
__________________
Old 10th July 2007, 00:21   #10 (permalink)
you dont get icons and start menu on second monitor in dual view.what you get is,if you enable the nview manager then you can open different applications on different monitors.like Movie on 2nd monitor and word on first one.
There is primary and secondary monitor right.only the primary monitor can have taskbar and icons.
__________________
Old 10th July 2007, 00:38   #11 (permalink)
revvedup's Avatar
^^thanks got that
Any wallpaper which I set on the secondary desktop irrespective of resolution gets cut off from the all sides moreover when I open an application on one of the displays it gets opened on the other one ,can I not make some setting which allows me to open the window on the display on which the mouse cursor is located something in the nview settings.
__________________
Old 10th July 2007, 03:40   #12 (permalink)
keep both the displays at same resolution.see if it works.
there are some overscan issues in clone mode.happened with my Tv too.works fine in clone mode.
__________________
Old 10th July 2007, 10:34   #13 (permalink)
if both the monitors are of same or having same resolution only then it can take both the same resolution..
Thread Tools
TATA sky on LCD monitor neoonwheels Gadgets, Computers & Software 16 27th August 2008 19:43
Best LCD monitor? johy Gadgets, Computers & Software 35 7th November 2007 17:56
Roof monitor & DVD player VMG Ask the Gurus 6 18th December 2006 16:21
Which CRT monitor DCEite Gadgets, Computers & Software 8 1st June 2006 08:23
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
