Old 17th July 2007, 13:57   #16
Josh's Avatar
Your color component chip is gone kaput.
If its not too old a moniter you can have it done in warranty.
Otherwise call their toll free number and they will pick the moniter from your house with 50 Rs extra charge in case of LG.
Both moniters at my home ( LG ) have the same problem of going pink in between. Have replaced the color chip in both within warranty.
Josh is offline   Reply With Quote
Old 17th July 2007, 13:58   #17
deep_bang's Avatar
Thanked: 343 Times
it happenned to my PC long back. Bad soldering on some connections within the monitor. If monitor works ok sometimes, degaussing wont help. If it works when u bang the monitor, it is definitely a dry solder issue.
deep_bang is online now   Reply With Quote
Old 17th July 2007, 14:01   #18
simply_sunny001's Avatar
Thanked: 15 Times
i have seen this problem with old monitors and most people bang their monitors or the cable connecting CPU to onitor and it works
so please go ahead tighten the cable if its loose or change it and i hope it will work
simply_sunny001 is offline   Reply With Quote
Intermittently Silent Horn nura Technical Stuff 50 19th April 2018 07:56
Air-con works intermittently biyer Technical Stuff 13 16th October 2017 13:23
Engine "drags" intermittently namit Technical Stuff 48 19th June 2015 18:03
Air Recirculator intermittently switches off in Polo TDI layndrivr Technical Stuff 4 19th May 2011 18:53
