Old 23rd July 2007, 17:00   #16
Thumbs up
Hey Abhi.. As In Ur Screenshots U Have Disabled Ur Sata Controllers Pls Enable It 1st The Go To Advance In Advance U Will Get Ide Configurations. In That See Sata Setting. Change The Sata Settings From Sata Raid To Sata Ide. Then U Can Install Ur Windows Easily..
Try It...all The Best..
$ENIGMA$ is offline   Reply With Quote
Old 23rd July 2007, 17:26   #17
abhibh's Avatar
Thanked: 33 Times
Enigma thanks for the reply. I was just fiddling with the setting so i just disabled it and forgot to enable it while taking pics. I have no setting In Advance for IDE etc. I have checked all the settings.
Please check this screen shot for options i have in advance.
Old 23rd July 2007, 17:27   #18
Thanked: 16 Times
You have setup the SATA drive as raid. You have to change it to SATA IDE!
Go to advanced tab in the BIOS setup and find the SATA settings under onboard devices. Switch it to SATA IDE.
Then you would be able to see the drive on the first screen of the BIOS setup and you would be able to install XP without any hiccups on this department.
Good luck!
Old 23rd July 2007, 17:33   #19
abhibh's Avatar
Thanked: 33 Times
speedzak check this, i have no option to set it to IDE :(
Old 23rd July 2007, 17:46   #20
Thanked: 16 Times
Abhibh!
Then you've got to look for it in the other tabs too baba! Look under chipset.
Old 23rd July 2007, 17:53   #21
Thanked: 294 Times
You have made the RAID enabled. this is causing the conflict...disable the RAID to proceed further.
Old 23rd July 2007, 17:57   #22
abhibh's Avatar
Thanked: 33 Times
speedzak paji i have checked in each and every section. The friend of mine who installed the windows earlier has shifted to US and i am unable to get hold of him. I am gonna try to install the drivers via F6 option and if that lso doesnt work then i gonna either get PATA or new MOBO.
Old 23rd July 2007, 18:03   #23
Thanked: 16 Times
Pressing f6 won't work baba! And you would be making the biggest mistake if you are going to buy another PATA HDD or Motherboard.
Simple. Just reset the BIOS settings in the last BIOS screen and save and see what happens.
Old 23rd July 2007, 18:06   #24
Thanked: 143 Times
IIRC, XP does not support all sata chipsets. Please look up Microsoft's support pages.
Old 23rd July 2007, 18:07   #25
bottle's Avatar
Thanked: 133 Times
hey abibh from the screenshots it does look like you have connected the new drive as a raid hdd.
which motherboard are you using by the way. that will help use guide you better
some motherboards provide additional sata ports by using a 3rd party controller which do require drivers to get detected. so try using the native sata ports on the mobo and you should be fine.
bottle is offline   Reply With Quote
Old 23rd July 2007, 18:07   #26
Thanked: 294 Times
yaar they are simple settings no big deal. read the manual it might help you. changing the mother board for this small thing is not good. try to learn thing.
Old 23rd July 2007, 18:22   #27
Thanked: 16 Times
Exclamation It is simple!
He doesn't have to connect it as Raid. And this has to be done in the motherboard BIOS. Simply explained in the manual.
He has posted earlier about the Motherboard he is using.
I don't think this Motherboard provides 3rd party controllers.
SIMPLE! As LBM told, read the manuals. It would help you.
Changing the motherboard/HDD for such a small thing??
What is world coming to????
Old 23rd July 2007, 18:36   #28
bottle's Avatar
Thanked: 133 Times
sorry meant configured not connected and yes looking at that mobo it only has 2 sata ports so what i mentioned is a non issue
abibh , on the main screen can you set onboard pci sata controller to ide in bios rather than disabled ?
Old 23rd July 2007, 19:48   #29
jazzy_2cool's Avatar
You can use a software called nliteos (www.nliteos.com).
You can use this software to integrate the drive in the windows and make another windows CD.
If you use that CD, it should not ask for the driver.
All the Best
jazzy_2cool is offline   Reply With Quote
Old 23rd July 2007, 20:14   #30
Thanked: 16 Times
I think Abhibh went to buy what he posted.
Copying large number of folders from windows XP to windows 7 laptop tsk1979 Gadgets, Computers & Software 28 18th June 2010 22:47
Backup Solutions : Windows 2003 compatible External HDD ? Need help ! FlyingSpur Gadgets, Computers & Software 36 11th November 2009 15:35
Unable to lock the steering wheel...Help! DRC Technical Stuff 7 6th September 2006 19:05
