Old 23rd July 2007, 13:34   #1
abhibh's Avatar
Thanked: 34 Times
Default Windows SETUP unable to find HDD
Hi Guys,
I just got myself a 160 GB SATA HDD. Its being detected in BIOS but when i run windows setup it says it cannot find the HDD
Can some one tell me whats wrong ?
Old 23rd July 2007, 13:39   #2
abhibh's Avatar
Thanked: 34 Times
Oh got it guys lol. i need to have that SATA drivers installed first damn. I dont even have a FDD :(. Any other way to install it.
Old 23rd July 2007, 13:42   #3
Thanked: 294 Times
Are you making a RAID array? as if single SATA drive is used no need for drivers is required.
Old 23rd July 2007, 13:51   #4
abhibh's Avatar
Thanked: 34 Times
Nah i am not doing any raid... I just got a new SATA HDD and installed it and ran setup. I just checked at BIOS it shows are RAID in the BIOS under boot devices....
Old 23rd July 2007, 13:56   #5
zakaaaaasss's Avatar
it happened to my collougue once....he then formatted his new Ext HDD and it worked.....you may want to try that
zakaaaaasss is offline   Reply With Quote
Old 23rd July 2007, 14:08   #6
esteem_lover's Avatar
Thanked: 451 Times
where did you install the drivers without an operating system ?
Old 23rd July 2007, 14:09   #7
madan80's Avatar
Thanked: 73 Times
which version of windows are you trying to install?
madan80 is offline   Reply With Quote
Old 23rd July 2007, 14:12   #8
abhibh's Avatar
Thanked: 34 Times
I am installing windows XP and esteem_lover when we are installing windows xp it gives you option to install drivers. It says the following "Press F6 if you want to install third party RAID / SCSI drivers"
Old 23rd July 2007, 14:35   #9
Thanked: 294 Times
no need to press F6 it is not required for a single drive...
Old 23rd July 2007, 14:41   #10
abhibh's Avatar
Thanked: 34 Times
LBM ji i am not pressing anything. I was just letting esteem lover know. The drive is single and i have not even partitioned it or anything. Plugged in ran windows setup and it said cannot FIND drive. I had SATA earlier too and this message never came. This is the first time. I am unable to understand what to do.
Old 23rd July 2007, 14:43   #11
Thanked: 294 Times
Is the drive showing in the BIOS.
Old 23rd July 2007, 14:46   #12
abhibh's Avatar
Thanked: 34 Times
The drive is not showing in BIOS as in primary IDE / SECONDARY IDE but it showing in Boot devices. My mainboard / motherbaord is ASUS K8SMX Asus K8SMX mATX SiS760GX chipset 754
Old 23rd July 2007, 16:17   #13
Thanked: 17 Times
How many SATA slots do you have on your Motherboard? Try switching the slots if you have more than one.
Please check if the SATA configuration is set to IDE instead of raid in BIOS.
It is necessary the drive shows in the first screen of BIOS in the listing of your drives. If it is not, then there is some conflict/mistake somewhere.
You can also try resetting all the BIOS settings to default.
Old 23rd July 2007, 16:26   #14
abhibh's Avatar
Thanked: 34 Times
Switched the slots too. Have rested the bios too. I will check it he SATA config. The drive doesn't show up in PRIMARY IDE etc.
I will try to to check the SATA settings now.
Old 23rd July 2007, 16:43   #15
abhibh's Avatar
Thanked: 34 Times
Guys here are the screen shots what i have in BIOS:
Copying large number of folders from windows XP to windows 7 laptop tsk1979 Gadgets, Computers & Software 28 18th June 2010 22:47
Backup Solutions : Windows 2003 compatible External HDD ? Need help ! FlyingSpur Gadgets, Computers & Software 36 11th November 2009 15:35
Unable to lock the steering wheel...Help! DRC Technical Stuff 7 6th September 2006 19:05
